Go to Post I wonder if Dave thinks the Chief Delphi kids are pimp... - Mike Ciance [more]
Unread 16-06-2008, 18:27
DanielR. DanielR. is offline
DanielR. is an unknown quantity at this point
WPILib and Ultrasonic sensors
Ok, I have an easy one.
I am trying to get ultrasonic sensors to work on a Vex using WPILib.
This is my code:
#define _VEX_BOARD
#include "API.h"
#include "BuiltIns.h"
#define UltraOnePing	1
#define UltraOneEcho	1
int sonicValue;
void main(void){
StartUltrasonic(UltraOneEcho, UltraOnePing);
PrintToScreen("Start");
	while(1==1)
		sonicValue = GetUltrasonic(UltraOneEcho, UltraOnePing);
		PrintToScreen("Ultra returns %d. \n", sonicValue);
I get nothing. I have tried also with RobotC and had success, so I know the sensor works. I cannot figure out what is wrong.
Do I need to set port direction (tried that, didn't work, maybe I did it wrong)?
Does it have something to do with DefineControllerIO()?
Is it a conspiracy? I just don't know.
Unread 16-06-2008, 18:39
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: WPILib and Ultrasonic sensors
Assuming you're using the Vex Ultrasonic sensor, then the input(echo, sensor output) and output(ping, sensor input) ports should be different.
If you're using non-vex sensors you may need to use the analog input, and bypass the wpilib functions.
Eric Haskins KC9JVH
Unread 16-06-2008, 18:51
Thank you for the response. Using vex sensors. The echo is on (interrupt port 1), and the ping is on (analog/digital port 1). Also, I have tried it with echo=1 and ping = 1 -11.
The current configuration is the one that worked in RobotC. I have not changed the sensor's wiring.
Unread 16-06-2008, 22:42
AKA: Eric Haskins
I forgot the Vex has the interupts and the digital I/O pins seperated.
I don't see any obvious problems with the code. Hopefully someone who has more experiance with WPILib/RobotC can answer your question.
Eric Haskins KC9JVH
Unread 18-06-2008, 08:58
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
By default
Ports 1-4 Are Assigned to Analog Inputs
Ports 5-10 Are Assigned Digital Inputs
Ports 11-16 Are Assigned Digital Ouputs
So you either need to re-assign that port (see documentation) or move the
pulse port to I/O Port 11 or higher.
Unread 18-06-2008, 15:27
Originally Posted by Kingofl337 View Post
By default
{ The following is the post I was in the process of writing when I had an idea I felt the need to verify. }
Thanks, I guess I didn't see that in the documentation. However, I did try moving the input connection to Digital Output 11 and 16, with no change in results.
Well, not exactly . . . once when I turned the Vex back on to upload a code modification it started outputting the Ultrasonic value to the terminal. It did it really fast as well, instead of the slow crawl it does when it is not working.
I really wish I knew what was going on here.
{End post}
Umm, what ... I am now confused and mystified.
It works now. Sort of. Here is what happened...
1) changed #define UltraOnePing from '1' to '11'
2) moved 'input' from port 1 to port 11
3) uploaded code
4) nuthin'
5) changed #define UltraPingOne from '11' to '16'
6) moved 'input' from port 11 to port 16
7) uploaded code -->terminal popped up while uploading and Vex was outputting expected values, upload completed, no more good output.
8) Wrote response on CD...had a thought.
9)changed #define UltraPingOne back to '11'
10) left 'input' plugged into port 16
11) uploaded code
12) Now it works.
If I set the Ping port to 11 and plug the wire into port 16 it works. The echo (output) wire is still plugged in to interrupt port 1.
I have nothing more to say about that.
Unread 18-06-2008, 16:44
Kingofl337's Avatar
AKA: Adam
Try this.
#define _VEX_BOARD
#include "API.h"
#define UltraOnePing	11
int sonicValue;
void main(void){
DefineControllerIO ( 4, 1 ,1 ,1 ,1 ,1 ,1 ,1 ,1 ,1 ,1 ,0 ,0 ,0 ,0 ,0 ,0 ) ;
	while(1==1)
                Wait(1);
4 = Number Of Analog Ports //First ports are always analog
1 = Input
0 = Output
Unread 18-06-2008, 17:31
Thanks again. I still am reading off of port 16 when port 11 is what is in the code. Also, it seems that is the only configuration I can find that works.
It is odd.
Parallax and Maxbotix ultrasonic sensors Lucretius Programming 5 20-02-2008 14:34
Ultrasonic sensors on digital ports 3-6 problems wt200999 Programming 14 13-02-2008 08:13
Ultrasonic range sensors for Vex Robot OneCoolDude Programming 1 01-12-2007 09:22
can we use ultrasonic sensors? GMKlenklen Electrical 20 15-01-2007 14:34
Gryo, Camera, Accelorometer, Ultrasonic, and Gear Tooth Sensors in one program EHaskins Programming 8 22-05-2006 12:08
