Go to Post I want my students to learn passion. I want them to care so much about what they are doing that they infect other people with it... be that FRC or anything else. - marshall [more]
Unread 19-06-2008, 14:37
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
pic: Simple, Yet Effective Chassis
Unread 19-06-2008, 14:40
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: pic: Simple, Yet Effective Chassis
I like it. It looks very simple and very solid and like you've left more than enough space open to mount a manipulator or what ever is going on it. I have two questions though, what's the approximate outside dimensions, and what's the offset of the center wheel if at all?
I ask that because from the render makes the base look pretty square and if it is I was wondering if you even need to offset the center wheel because in my experimentation I've found that the shorter your wheel base is the less of an offset you need.
-Dustin Benedict
Unread 19-06-2008, 14:41
dbell dbell is offline
Mentor for team#3937 (Breakaway!)
AKA: David Bell
FRC #1519 (Mechanical Mayhem)
dbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to behold
How do the six cross-members mount to the side plates?
Is the green plate on the bottom for electronics?
Did you lower the center wheel? If so, by how much?
Unread 19-06-2008, 15:11
FRC #1405
The dimensions are 27.75" x 37.75". The middle wheels are lowered by 1/8". Those big black 'end caps' attach the side plates to the front rails and back rails. The mini support braces inside attach to the 1x1's and attach to the side plates too. I did not include all the 1/2" rod supports due to i did this on my laptop and inventor freaks out as is. I also left out the idlers. There is a lexan sheeting to add the electronics and transmissions and what else you want on there.
My next design will include a transmission within the side plates. I am trying to make these designs not fabulous looking, but able to be made by any team with out much resources.
This type of design has been proven since 2005. The axle system was something I picked up from 1930. It is very unique and a great idea. The axle has a hole for a pin to go through, so in the need of repair all you need to do is pull the pin and the axle will come out with ease. The wheels will be driven from sprockets attached to the wheels.
Any other questions?
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 19-06-2008, 20:17
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Historically, have there ever been any problems with the inside 1/4" side rails flexing where they're not supported? Under normal operating conditions I'm sure it's minimal to non-existent, but what about the shock of an impact?
This looks like the perfect setup for the Stackerbox mecanum setup I've been toying with, but I do have reservations.
GitHub
Unread 19-06-2008, 20:22
FRC #1405
There are more little 1/2" rod supports spread out that I did not include. I am running inventor on my laptop, it's not the best, so I leave out the little things. There were no issues that I knew of from that.
Unread 20-06-2008, 00:16
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Looks like a good basic design. I'd suggest that teams thinking of making it, use an outside dimension of 26" x 36" because we all know how much robots grow as you add stuff....
Unread 20-06-2008, 16:40
AdamHeard's Avatar
Lead Mentor
Can you explain the rod supports and where they would go?
Unread 20-06-2008, 16:47
FRC #1405
They would go in between the side plates. for further support. If you have a chance take a look at the 03, 05-08 chassis from 1126.
Unread 21-06-2008, 23:51
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
You mentioned lexan for the electronics, I prefer 1/4"oak plywood. It weighs less and is more resistant to flexing.
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 23-06-2008, 08:42
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
That can easily be fixed with COTS spacers from McMaster tha can be added after the fact. Also the addition of bumpers reduces the required thickness of that out materiaal if you plan ahead.
Looks like a good first pass. The next step is to figure out the details which is the cross bace mounting and reinforcement. The devil is in those details and balancing ease of assembly/disassembly with robustness/rigidity.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 23-06-2008, 13:00
Best Available Data
FRC #1778 (Chill Out!)
How much does it weigh? This year we tried to find a lighter plastic solution than our usual 1/8" lexan with holes cut through under the components and couldn't find one. Have you ever tried using a thinner board?
What are you trying to avoid with a stiffer material? We usually mount ours along the rails with it just resting on the frame cross braces and have never had any issue. One year we even mounted it vertically, and had no flexing problem.
Unread 23-06-2008, 17:17
DGrohnke1023's Avatar
DGrohnke1023 DGrohnke1023 is offline
Is Looking Backward to Look Forward
AKA: The Dan
FRC #1023 (Bedford Express)
Team Role: Driver
DGrohnke1023 is a glorious beacon of lightDGrohnke1023 is a glorious beacon of lightDGrohnke1023 is a glorious beacon of lightDGrohnke1023 is a glorious beacon of lightDGrohnke1023 is a glorious beacon of light
For our electronics the past 2 years we have used 1/4" corrugated plastic. I believe it weighs around .25 lbs/ft. The stuff is amazing, you can run wires through it, we even used it for our ramps in 07. I think it also costs less than Lexan as well. I highly recommend the material.
Daniel Grohnke
2009 Bedford Express Captain
2009 - Lansing and Troy Districts, The Championship
2008 - GLR Quarterfinalist & MARC Semifinalist
2007 - GLR & Boilermaker Finalist & MARC Champion
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarterfinalist
2005 - GLR Finalist & Judges Award
2004 - GLR/DTR Semifinalist
2003 - GLR Quarterfinalist & GLR/NAT'L Rookie All Star
Unread 23-06-2008, 17:20
JesseK's Avatar
FRC #1885 (ILITE)
We usually
Keep in mind that next year's electronics may almost weigh the same, but the weight distributions will be more concentrated due to a more compact design. What we "usually" do for mounting these systems will have to at least be reconsidered next year.
As for the above oak/lexan debate, here's some data. The other mentors and I have always asked ourselves what the real benefit of lexan over other materials was, so I just did some research.
According to matweb a typical lexan sheet has a density of ~0.041 lb/in^3 whereas most solid oak hardwoods have a density of ~0.021 lb/in^3. The flex testing of lexan was done with 1/4" sheets and yielded ~65% flex resistance over with-the-grain testing of oak, yet for almost twice the weight of oak. Hence, for the application of mounting electronics I think it's safe to say that typical 1/8" thick lexan and typical 1/4" thick oak are about equal when considering "will it work".
GitHub
pic: 968 - These parts are nice and simple! Travis Covington Extra Discussion 1 31-01-2007 13:53
pic: simple omni vex bot colin340 FIRST Tech Challenge 15 05-05-2006 17:16
Effective Coaching Jeff Rodriguez Rules/Strategy 13 19-03-2006 16:13
Effective web ads Petey Website Design/Showcase 0 15-08-2004 20:17
Effective Fundraising Letters archiver 2000 1 23-06-2002 23:58
