Go to Post If you're in Israel, it might be a long flight to the nearest Walmart - MrForbes [more]
Unread 20-06-2008, 07:37
steveg's Avatar
steveg steveg is offline
Livin' the Dream
AKA: Stephen Guerrera
steveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to behold
Send a message via AIM to steveg
Re: Help Programming a Quadrature Encoder
Originally Posted by Bomberofdoom View Post
You mean there's a difference between putting the encoder on the left side or the right side of the gear/wheel?
What Bill is getting at is that while the A signal of the encoder on the left side of the drive train might be leading, the encoder on the right side of the drive train might be lagging. You can check the signals coming out of the encoders with an oscilloscope, or what I usually do is just hook it up, look at the encoder counts in a terminal, and reverse the sign bit if necessary.
Steve Guerrera
-2003 T.R.I.B.E. 237
2004-2008 Nutrons 125
Boston Regional Mentor
MIT Grad Student
Unread 20-06-2008, 07:48
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
Generally the data sheet for the encoder will specify which signal leads which.
For example, it may say... A leads B in a clockwise rotation.
So if it's turning clockwise then A will come first followed by B. Conversely if it's turning counter clockwise the B will come first followed by A.
I highly recommend downloading and reading this excellent white paper on quadrature encoders. It explains the A versus B, and provides mostly functional code. The sample code does have 2 bugs, but you should be able to find them. If not PM me. Our team has been using this methodology for the last 2 or 3 seasons very successfully.
http://www.chiefdelphi.com/media/papers/1490
Read it, I think you will see the lights go on in your head and you'll have a much better understanding.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 20-06-2008, 10:40
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Part of why a robot seems to drift to the left or right when driving near full speed is that motors have a "bias". This means that they spin more efficiently in one direction than the other. Now I will point out, the CIM motors in the KOP are not a good example of this because they have very little bias, but they do have some. The reason you notice the effect of this bias is because usually one motor is turning CW while the other is turning CCW to drive a robot forward. So...... one encoder will be going CW while the other is going CCW for the same direction of drive.
Again, this is really simple to handle in the ISR. For the same direction of travel make sure both encoders are incrementing, and decrementing for the opposite direction.
Read through Kevin Watson's encoder code, this is all spelled out clearly.
Quadrature shaft encoder source billbo911 Kit & Additional Hardware 7 06-01-2008 19:52
Encoder help E_Unit Electrical 5 16-02-2007 11:02
Turning a gear-tooth sensor into a quadrature output encoder Jared Russell Programming 4 18-01-2006 22:19
Encoder help Windward Programming 21 14-01-2006 15:10
shaft encoder help stephenthe1 Programming 2 03-12-2004 16:09
