Go to Post When you tell any of your kids that winning isn't important, or isn't [I]that[/I] important, the flapping sound you hear is your credibility flying away. - jlindquist74 [more]
Unread 17-06-2008, 22:47
Best Available Data
FRC #1778 (Chill Out!)
Displaying a 16 bit integer on PIC 16F877?
So, I've been playing around with a 16F877, and I got my hands on one of the kit gyros, and am trying to write my own code for it. I've got it mostly working, but I need to display a 16 bit integer to figure out what constitutes a 90 degree turn. But, the PIC doesn't want to do it. I can't for the life of me get it to output a 16 bit integer (that I can understand) to the debugger using a printf. I've tried %ld, but it didn't give me the right number. Is there some other trick (or formatting) I can use?
Unread 18-06-2008, 08:24
Re: Displaying a 16 bit integer on PIC 16F877?
%ld is for 32-bit numbers. For a normal int value, just use %d.
Unread 18-06-2008, 09:34
More important then knowing the type of PIC is what compiler you are using.
In C18 %ld prints in hex and expects a long (32 bits) while an int is 16 bits
In a compiler for your computer, both an int and a long are 32 bits, and both %d and %ld would print the same thing with both.
Other compilers (especially embedded compilers) will all have small variations like that, that you can only learn about by reading the manual.
Unread 20-06-2008, 12:03
Best Available Data
I'm using CCS. I ended up solving it by making all of the variables 32 bit integers, which obviously isn't the best solution. I think the problem came when I was doing 8 bit integer math and then set the result equal to a 32 or 16 bit integer. Is there a way to go about doing that?
The piece of code in question was:
angle=angle+instant
Originally, angle was 16 bit integer, and instant was an 8 bit integer. But I couldn't get a useful number, so I changed angle to a 32 bit integer, which I knew I had the syntax right, but it was still a funny number. After I changed instant to a 32 bit number it worked fine. I think I probably have to cast it somehow, but I don't really have a grasp on what casting exactly does, and why it works.
Unread 20-06-2008, 15:42
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
on a side not, you could also have done:
angle+=instant
pic: Feeling a bit Blue Steve W Extra Discussion 3 28-10-2007 23:54
pic: A "Bit" of a problem. Herodotus Extra Discussion 26 11-10-2007 01:53
16 bit math on PIC sciguy125 Programming 17 07-10-2005 02:57
integer division ImmortalAres Programming 5 11-07-2005 21:19
Integer Number powercat Programming 2 18-02-2003 11:26
