Re: pic: Simple, Yet Effective Chassis
They would go in between the side plates. for further support. If you have a chance take a look at the 03, 05-08 chassis from 1126.
You mentioned lexan for the electronics, I prefer 1/4"oak plywood. It weighs less and is more resistant to flexing.
What are you trying to avoid with a stiffer material? We usually mount ours along the rails with it just resting on the frame cross braces and have never had any issue. One year we even mounted it vertically, and had no flexing problem. |
For our electronics the past 2 years we have used 1/4" corrugated plastic. I believe it weighs around .25 lbs/ft. The stuff is amazing, you can run wires through it, we even used it for our ramps in 07. I think it also costs less than Lexan as well. I highly recommend the material.
As for the above oak/lexan debate, here's some data. The other mentors and I have always asked ourselves what the real benefit of lexan over other materials was, so I just did some research. According to matweb a typical lexan sheet has a density of ~0.041 lb/in^3 whereas most solid oak hardwoods have a density of ~0.021 lb/in^3. The flex testing of lexan was done with 1/4" sheets and yielded ~65% flex resistance over with-the-grain testing of oak, yet for almost twice the weight of oak. Hence, for the application of mounting electronics I think it's safe to say that typical 1/8" thick lexan and typical 1/4" thick oak are about equal when considering "will it work". |
| pic: 968 - These parts are nice and simple! | Travis Covington | Extra Discussion | 1 | 31-01-2007 13:53 |
| pic: simple omni vex bot | colin340 | FIRST Tech Challenge | 15 | 05-05-2006 17:16 |
| Effective Coaching | Jeff Rodriguez | Rules/Strategy | 13 | 19-03-2006 16:13 |
| Effective web ads | Petey | Website Design/Showcase | 0 | 15-08-2004 20:17 |
| Effective Fundraising Letters | archiver | 2000 | 1 | 23-06-2002 23:58 |
