Go to Post We might not be as good as 217, or the other traditional "powerhouse" teams... but we are better because of them. Jason - dtengineering [more]
Unread 22-06-2008, 19:31
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Victor turning on and off under load, with non-IFI microcontroller
I think it was a bad motor. It was a FP motor from a few years ago (white case) The Victor was brand new, the wire was brand new, and the battery was charged.
For the Victor blinking, I think it was caused by a messed up signal from the controller because the vibration from the motor caused the controller to lose power from the AA battery pack.
This is all theoretical, but that's the best I can come up with.
I have also used Victors with VEX controllers before without issues. But this is a different VEX controller, different Victor, different motor, and different battery.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 23-06-2008, 23:36
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Originally Posted by pludodog View Post
When I vary the output with the motor disconnected the victor goes from red to orange to green as expected. When I connect the motor and give the speed controller a speed the speed controller flashes orange rapidly, and the motor makes a clicking noise, as if it were turning on and off quickly, but doesn't move.
Any idea what could be causing this?
I had this exact same problem today while assembling a small electrical board controlled by an EduRC. The problem turned out to be the 12V battery - it's voltage was around 9V and it wouldn't take a charge. Probably something messed up internally, a cracked cell, perhaps.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 28-09-2009, 08:07
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
We had the same thing happen with a vex and victor, blinking lights once you hit 5 amps.
Turns out is was a low battery for the motors. Vex and voctors are working well together.
Doug Leppard
RPM under load Demothesis Motors 1 12-01-2008 22:30
Issues with non working victor constant orange led dani190 Control System 10 21-12-2007 22:32
**FIRST EMAIL**/Championship Updates - Load In and Load Out and Finale Ticket Inform AmyPrib FIRST E-Mail Blast Archive 3 21-04-2006 11:08
Turning motors on and off in the KitGearbox? Andrew Blair Kit & Additional Hardware 4 31-12-2005 10:33
Victor turning off zeep25 Electrical 10 23-02-2004 18:35
