Go to Post Changing lives as a key volunteer is not a right reserved for the "elite" among us anymore. - HurdFIRST [more]
Unread 24-06-2008, 20:48
tennispro9911 tennispro9911 is offline
Alumni
AKA: Matt
FRC #2053 (TigerTronics)
tennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to behold
Send a message via AIM to tennispro9911
Re: Need help to find a tool, kinda urgent
Well, if you want to cut 1/2" or up to a foot or so, just buy a waterjet for the "cheap" ones I think its in the 80-90k range.
2053 Alumni
Unread 24-06-2008, 21:11
AdamHeard's Avatar
Lead Mentor
It's probably best if you take a step back and tell us what you are trying to do.
Are you wanting to end up with a sheet of X thickness 27 x 37 as the final product (those dimensions make me think it is for a base)? Or are you wanting something about that size that you will cut/finish with some other process?
What determines the thickness? and what are you using this for?
EDIT: reread some posts... So, you are just looking for a machine to cut those thicknesses in general?
Unread 24-06-2008, 21:28
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
A few more useful questions:
  • Exactly what is it for? (To give us an idea of the level of fit and finish.)
  • How many pieces?
  • What's the budget?
  • Do you need a special kind of aluminum (or will 5052-H32 sheet work, for example)?
  • Does the as-fabricated heat treatment matter? What about cold work (strain hardening)?
  • Do you care about edge profile (e.g. straightness, flatness, burrs, etc.)?
  • Do you need only squares and rectangles, or will you maybe need curvilinear or concave shapes in the future?
  • Do you want to do it yourself, or are you willing to have an outside shop handle it?
  • If you end up with a machine, what will you use it for in the future?
Unread 24-06-2008, 22:47
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
My fault for the inconsistency in posts
I need it for the robotics team to cut sheets of aluminum in the offseason.
The budget is about 200-900 dollars
The aluminum will mainly be 6061 and if possible 7075.
The edges need to be square
I just need sqaures and rectangles
I want to do it myself
The maximum thickness needed is 1/8"
The bottom line is: I just want something that will cut sheets of aluminum
thanks for all the help cd
R.C.
MadTown Robotics Team 1323
Unread 24-06-2008, 22:54
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
What kind of tolerances? Will there be a secondary operation, or are you cutting to size?
The answers to those two questions will determine whether or not you can buy a shear, or if you are SOL.
2001-2004: Team 100
2006-Present: Team 254
Unread 24-06-2008, 22:56
acdcfan259's Avatar
acdcfan259 acdcfan259 is offline
Brainssss....
AKA: Jake Carroll
FRC #1027 (Mechatronic Maniacs)
Team Role: Driver
acdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond repute
Send a message via AIM to acdcfan259
Hacksaw?
Unread 24-06-2008, 23:00
R.C.'s Avatar
Yeah hacksaws are great, almost everyone on the team cuts crooked.
tolerence +- 1/8, just cutting to size
R.C.
Unread 24-06-2008, 23:03
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
If your maximum thickness is going to be 0.125", then it sounds like you are going to be working with sheet metal forming tools. As such, 6061 and 7075 are actually pretty bad when it comes to "cold" sheet metal fabrication. 5052 would be a better bet, especially if you want to put any bends or edge flanges on it.
If you just want to cut the edges, look for a sheet metal shear; you can find one in your price range that can shear pieces three to four feet wide. However, trying to shear a piece that thick across the entire length of a shear may be too much for a manual one. In that case, you will need to find a local machine shop that specializes in sheet metal turret/punch, laserjet, or waterjet fabrication.
Art Dutra IV
世上无难事,只怕有心人.
Unread 24-06-2008, 23:08
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Might also look into having someone saw it. Remember, safety FIRST!
http://www.tipsbytom.com/index.php/cutting-aluminum/
Unread 24-06-2008, 23:27
Cory's Avatar
AKA: Cory McBride
I was going to suggest this, but table saws are a tool that we don't let our kids get anywhere near, due to how many accidents occur while using them. I'd be VERY reluctant to endorse using it for a purpose it was never intended. You could end up seriously injured extremely quickly.
2001-2004: Team 100
Unread 25-06-2008, 00:55
REVving up for a new season
FRC #2848 (All-sparks)
I design table saws on a daily basis and I can tell you that while it may be possible to cut aluminum on them. IT IS NOT RECOMMENDED. Besides the fact that the blade spins much to fast you will also need a really expensive carbide tooth cutter (don't use grinding disks)
That being said I think the tool you really want is a band saw. While a shear is a nice tool to have in your shop if all you are worried about is roughing out your sheets, a metal bandsaw using a guide/fence will get you where you need to go. I would look for a used GROB or other industrial variable speed band saw. Most likely something with ~20" will be fine for most standard stock you will buy.
The major problem I see with this route is that power requirements vary. They will go from 440v three phase to 220v single phase. Just make sure you have the right electric service for the unit you would consider.
On a side note - depending on the number of these you want many metal supply houses will have the ability to cut 1/8 aluminum well within your tolerances. And if you ask nicely they may even do it for you. Do you really need the ability to do this all the time, ie. do you really need to buy a tool. If you do then you will get much more work out of a band saw then a shear.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 25-06-2008, 01:44
Cory's Avatar
AKA: Cory McBride
He's going to need a bandsaw with a 40" throat to do that. That's a $5,000+ machine.
We have a JET shear similar to this. I generally hate JET tools, but we don't use it very hard, and it's served us well. I've never tried to shear a full sheet of 0.125" aluminum, but I've sheared 1/8" 6061 6" long or so before and it handles it with no problem. If you get enough people to jump on it hard enough, you'd probably be ok
2001-2004: Team 100
Unread 25-06-2008, 02:19
dtengineering's Avatar
AKA: Jason Brett
While I can't say that I have personally cut aluminum sheet on a table saw, that was going to be my first suggestion for this particular application. Given the following caveats, I see no fundamental reason why it would not work.
As pointed out the table saw can be quite dangerous if you don't know what you are doing. Not, perhaps, as dangerous as driving a car when you don't know what you are doing... but even experienced table saw users can be sometimes caught off-guard by the occasional kick back. Likewise, just as driving a car can be done reasonably safely with the appropriate level of skill and/or supervision, so can using a table saw.... it doesn't mean accidents will NEVER happen... but we should no more ban appropriately mature students from using the table saw than we should ban them from using a car. Skill and supervision are the keys here.
Jim's link provides a really neat idea on dealing with the high tooth speed... use a smaller diameter blade. With carbide teeth it should work just fine and I can't see any reason why it would be more dangerous than cutting a thick piece of acrylic, maple or teak, or even a large piece of plywood. The article cites an increased tendency for kickback, but normal table saw operations already require the user to make plans to mitigate kickback risks.
If you aren't experienced with a table saw, though... don't cut wood on it, let alone aluminum. All tools deserve respect, but the table saw demands it.
Jason
P.S. I'd expect it might be a bit loud....
Unread 25-06-2008, 02:44
MrForbes's Avatar
AKA: Jim
On the safety issue...as said by others, you need to be very careful with a table saw, which is why I suggested finding someone who would do the cutting for you.
The older fellow who runs the shop our students work in missed most of the 2007 build season because he cut off part of his thumb on the table saw in his shop. But table saws are not the only dangerous equipment used for wood working, and accidents can happen in strange ways...another fellow I know lost a finger on a miter saw, cutting wood, somehow the safety shield broke and the broken shield severed his finger.
Also be careful with a shear if you use one...yet another friend broke his artificial foot using one when we were cutting some relatively thin sheet steel on his manual shear. Not painful, so much as expensive, but still it shows that you have to be very careful no matter what equipment you're using.
I don't have any scary plasma cutter stories, but I'm sure there are some.
Unread 25-06-2008, 09:08
Brandon Holley's Avatar
Once upon a time I saw a kid cut off part of his pinky using a miter saw...he was cutting an ~8" piece of aluminum extrusion, without clamping it down (yes holding it by hand). The saw caught it and whipped it around, it landed on his pinky. Saws need respect.
I've cut aluminum sheet on a table saw before. It is certainly not the best thing to do, but it did work, and I didn't lose any digits or limbs. It wasn't the best experience, and I do not recommend it. It was quite loud though.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
URGENT! We need help with the accelerometer lkdjm Electrical 5 11-02-2005 16:42
URGENT! We need help with the accelerometer lkdjm Technical Discussion 0 08-02-2005 14:35
Need help with Data recovery [urgent] plutonium83 Chit-Chat 7 11-01-2005 10:35
need some urgent help (REPOST) archiver 2001 1 24-06-2002 01:01
URGENT: i need help!!! Ydnar 3D Animation and Competition 4 14-03-2002 22:37
