Go to Post Kudos to you IFI, for your continued support of FIRST and its stated ideals - Racer26 [more]
Unread 24-06-2008, 17:28
markulrich's Avatar
markulrich markulrich is offline
Head Captain and LabVIEW Programmer
FRC #2129 (Ultraviolet)
markulrich has a spectacular aura aboutmarkulrich has a spectacular aura about
Is the maximum PWM value 254 or 255?
My team has always used 255 as the cut-off point for PWM values (otherwise things loop over), but whenever I look at example code I see others using 254. Why is this? Are the victors pre-calibrated to use 254? Do you get any more power by using 255?
Unread 24-06-2008, 17:44
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Is the maximum PWM value 254 or 255?
I've always used 255.
the difference should be absolutely negligibly though.
Unread 24-06-2008, 18:05
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
The IFI system was designed to reset if it saw some series of values of 255, as I recall. Someone wiser than I in these matters will elaborate.
--Madison--
...down at the Ozdust!
Unread 24-06-2008, 18:09
tennispro9911 tennispro9911 is offline
Alumni
AKA: Matt
FRC #2053 (TigerTronics)
tennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to behold
Send a message via AIM to tennispro9911
If 127 is truely exact middle then 254 should be max. In reality, I don't know. Our team has used both values at different points in time with no noticable differences.
2053 Alumni
Unread 24-06-2008, 18:42
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
I've always calculated the PWM value as being 127±127, so I say 254.
Unread 24-06-2008, 18:44
JimWright949's Avatar
JimWright949 JimWright949 is offline
The Owen Day of Seattle
AKA: Jim Wright
FRC #4542 (Titanium Talons)
JimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to behold
If memory serves, pre-2004 RCs would disable the PWM port if it saw 255. 2004 up to now can use the full 0-255 range. A signed 8 bit number goes from -128 to 127 by the way.
-Jim
Unread 24-06-2008, 18:49
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Since everything in a computer is measured in binary. In this it is a char there fore is 8 bits so can hold 2^8 possibilities, or 256, however as with everything in programing start with zero so it holds any number from 0 to 255.
"History doesn't repeat itself - at best it sometimes rhymes" --Mark Twain
Unread 24-06-2008, 18:59
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
255 is max, as an 8bit number is 256, therefore 0-255. the victors also have a deadband of +/- 5 values, so anything from 122-132 should be neutral, but i'll still do 127 just to be sure
Unread 24-06-2008, 20:02
The IFI control system will not send a pwm value of 255. If you try to set a 255, it turns into a 254.
The historical reason for this is the design of the data packets between the OI and RC. Two 255s in a row flag the start of a packet.
Unread 24-06-2008, 20:08
markulrich's Avatar
Thanks Alan! That explains a lot; using 254 is also nice because then 127 is the true middle.
Unread 24-06-2008, 22:47
There isn't any difference between 254 and 255 when used with a victor speed controller, in fact, there isn't any difference between 255 and 233. See this post on the IFI forum: http://www.ifirobotics.com/forum/viewtopic.php?t=317
Also notice that at the default calibration, the real center is 132.
Unread 25-06-2008, 14:17
markulrich's Avatar
Look at the attached chart. The PWM input is x-axis, and y-axis is estimated output (%) based on these figured from IFI:
VAULE STATE LED STATUS Pulse Width
0 – 41 Full Reverse RED 0.856 – 1.06 ms
42 – 125 Reverse OFF 1.07 – 1.48 ms
126 – 139 Neutral YELLOW 1.49 – 1.55 ms
140 – 230 Forward OFF 1.56 – 2.00 ms
231 – 254 Full Forward GREEN 2.01 – 2.12 ms
The other, darker line is the target output based on a cubic function with dead bands at the beginning, middle, and end. I am working on creating a look-up table to insert into code that could accomplish this. Any suggestions are appreciated.
Name:	target v estimated.jpg
Unread 25-06-2008, 16:15
craigcd's Avatar
craigcd craigcd is offline
FRC #2221 (RoboDawgs)
craigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant future
Are the PWM values valid for the new operating system?
Unread 25-06-2008, 17:03
markulrich's Avatar
I think these values are valid for the new operating system because I believe that the new operating system will be using the same victors from IFI.
Unread 02-07-2008, 01:50
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
from what I've read about the new control system(and anyone is free to correct me), it will be using the same Victors as previous years and therefore the 8 bit 0-255 range would still be valid
I apologize if I just restated everything that was already said... I just thought I'd get my 2 cents in
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
Robot Controller reset issue when pwm value changes wt200999 Programming 4 04-01-2008 22:15
Maximum PWM length mechanicalbrain Electrical 5 13-03-2006 23:18
Dividing PWM value - easy question jgannon Programming 1 04-02-2004 22:57
Encoder Counts/time period to PWM value Zee Programming 10 04-02-2004 01:41
Why can't you use 255 in PWM? Andrew Technical Discussion 4 29-05-2003 14:50
