Re: Need help to find a tool, kinda urgent
My fault for the inconsistency in posts
I need it for the robotics team to cut sheets of aluminum in the offseason. The budget is about 200-900 dollars The aluminum will mainly be 6061 and if possible 7075. The edges need to be square I just need sqaures and rectangles I want to do it myself The maximum thickness needed is 1/8" The bottom line is: I just want something that will cut sheets of aluminum thanks for all the help cd |
The answers to those two questions will determine whether or not you can buy a shear, or if you are SOL. |
Hacksaw?
Yeah hacksaws are great, almost everyone on the team cuts crooked.
tolerence +- 1/8, just cutting to size |
If your maximum thickness is going to be 0.125", then it sounds like you are going to be working with sheet metal forming tools. As such, 6061 and 7075 are actually pretty bad when it comes to "cold" sheet metal fabrication. 5052 would be a better bet, especially if you want to put any bends or edge flanges on it.
If you just want to cut the edges, look for a sheet metal shear; you can find one in your price range that can shear pieces three to four feet wide. However, trying to shear a piece that thick across the entire length of a shear may be too much for a manual one. In that case, you will need to find a local machine shop that specializes in sheet metal turret/punch, laserjet, or waterjet fabrication. |
Might also look into having someone saw it. Remember, safety FIRST!
http://www.tipsbytom.com/index.php/cutting-aluminum/ |
#7
That being said I think the tool you really want is a band saw. While a shear is a nice tool to have in your shop if all you are worried about is roughing out your sheets, a metal bandsaw using a guide/fence will get you where you need to go. I would look for a used GROB or other industrial variable speed band saw. Most likely something with ~20" will be fine for most standard stock you will buy. The major problem I see with this route is that power requirements vary. They will go from 440v three phase to 220v single phase. Just make sure you have the right electric service for the unit you would consider. On a side note - depending on the number of these you want many metal supply houses will have the ability to cut 1/8 aluminum well within your tolerances. And if you ask nicely they may even do it for you. Do you really need the ability to do this all the time, ie. do you really need to buy a tool. If you do then you will get much more work out of a band saw then a shear. |
#9
We have a JET shear similar to this. I generally hate JET tools, but we don't use it very hard, and it's served us well. I've never tried to shear a full sheet of 0.125" aluminum, but I've sheared 1/8" 6061 6" long or so before and it handles it with no problem. If you get enough people to jump on it hard enough, you'd probably be ok ![]() |
#10
While I can't say that I have personally cut aluminum sheet on a table saw, that was going to be my first suggestion for this particular application. Given the following caveats, I see no fundamental reason why it would not work.
As pointed out the table saw can be quite dangerous if you don't know what you are doing. Not, perhaps, as dangerous as driving a car when you don't know what you are doing... but even experienced table saw users can be sometimes caught off-guard by the occasional kick back. Likewise, just as driving a car can be done reasonably safely with the appropriate level of skill and/or supervision, so can using a table saw.... it doesn't mean accidents will NEVER happen... but we should no more ban appropriately mature students from using the table saw than we should ban them from using a car. Skill and supervision are the keys here. Jim's link provides a really neat idea on dealing with the high tooth speed... use a smaller diameter blade. With carbide teeth it should work just fine and I can't see any reason why it would be more dangerous than cutting a thick piece of acrylic, maple or teak, or even a large piece of plywood. The article cites an increased tendency for kickback, but normal table saw operations already require the user to make plans to mitigate kickback risks. If you aren't experienced with a table saw, though... don't cut wood on it, let alone aluminum. All tools deserve respect, but the table saw demands it. Jason P.S. I'd expect it might be a bit loud.... Last edited by dtengineering : 25-06-2008 at 02:29. |
#11
On the safety issue...as said by others, you need to be very careful with a table saw, which is why I suggested finding someone who would do the cutting for you.
The older fellow who runs the shop our students work in missed most of the 2007 build season because he cut off part of his thumb on the table saw in his shop. But table saws are not the only dangerous equipment used for wood working, and accidents can happen in strange ways...another fellow I know lost a finger on a miter saw, cutting wood, somehow the safety shield broke and the broken shield severed his finger. Also be careful with a shear if you use one...yet another friend broke his artificial foot using one when we were cutting some relatively thin sheet steel on his manual shear. Not painful, so much as expensive, but still it shows that you have to be very careful no matter what equipment you're using. I don't have any scary plasma cutter stories, but I'm sure there are some. |
#12
I've cut aluminum sheet on a table saw before. It is certainly not the best thing to do, but it did work, and I didn't lose any digits or limbs. It wasn't the best experience, and I do not recommend it. It was quite loud though. Last edited by Brandon Holley : 25-06-2008 at 09:57. |
#13
I'm by no stretch of the imagine an expert on tools. I've been able to rough cut fairly thick aluminum with a good jigsaw and the appropriate HSS blades. You can even cut curved paths if you are careful. You will want to adjust your saw properly and generously use cutting fluid but I have found the tool to be very flexible... I didn't see this mentioned so it probably isn't the right tool for the job but might beat a hacksaw.
#14
Every once in a while topics hits me at home and I can't stand people giving advise to someone for experiences they don't have, ie cutting aluminum sheets on a table saw. For that reason I have made this list for you...
Top reasons why NOT to cut aluminum sheet on a table saw. 1) Kickback pawls don't work with metal as there is nothing to dig into as the material moves backwards. 2) The material thickness is very thin, and such you will be unable to use a modern design push stick. If you do you are likely to slip off the edge of the material. 3)The heat created during the cut, will sometimes melt the aluminum onto the the teeth of the blade rendering it useless after a short amount of time. 4)Possibility of fire. Since most table saws are not used mainly for metal there is normally a load of sawdust in the saw (sitting on the castings, in the bottom of the cabinet, etc). I have seen examples of people who cut metal on the saw causing fire with hot chips falling onto the dust. 5) Aluminum chips act very differently then saw dust, even with proper dust collection they will likely be flying in all directions. In high school a piece of aluminum went under my safety glasses and face mask and landed just short of my eye. 6)Aluminum and electricity - depending on the age of your saw there may be open connections in the unit. (At the motor, at the switch) do you really want to introduce metal to those open connections of 220v 7) Depending on who's saw it is I am not sure that they will want aluminum chips in their $500 piece of mahogany. 8) Problems with future use of the saw. The worm gears and trunions in a saw are open and it is very likely that the chips will jam up these components making it difficult to bevel and/or raise and lower the blade in the future. I bet I could keep going with more and more, but ultimately it comes down to using the correct tool for the job. You will never find a table saw manual that approves the cutting of aluminum on the saw. This is due to liability and machine design. We don't design saws to cut aluminum and while we do testing to see what will happen that practice will never be endorsed. In my mind this is similar to cove cutting wood to make moldings; People do it all the time but it is really dangerous and many people have gotten hurt doing it. I am sure there are a bunch of people who cut aluminum on their table saws but why take the risk when there are literally tons of other ways to accomplish the same task. As for the band saw, the throat required depends alot on what your starting pieces are(4x4, 4x8, etc) . Also you can get external support for the right side of the blade and get away with a smaller throat distance. |
#15
| URGENT! We need help with the accelerometer | lkdjm | Electrical | 5 | 11-02-2005 16:42 |
| URGENT! We need help with the accelerometer | lkdjm | Technical Discussion | 0 | 08-02-2005 14:35 |
| Need help with Data recovery [urgent] | plutonium83 | Chit-Chat | 7 | 11-01-2005 10:35 |
| need some urgent help (REPOST) | archiver | 2001 | 1 | 24-06-2002 01:01 |
| URGENT: i need help!!! | Ydnar | 3D Animation and Competition | 4 | 14-03-2002 22:37 |
