Go to Post Raw students in, pure engineers out. - ebarker [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 25-06-2008, 12:02
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: CAD: Making a cam mechanism
Originally Posted by Greg Needel View Post
anyway the question I have for you is how critical is the cam to have a follow cam profile? You could just use a cylinder piece of stock and drill the rotation hole offset from the center and get a cam effect. If you use a 3in piece and drill it .5 in off center you will get the same extreme's that you are looking for.
I guess I am wondering if the quick transition is actually necessary.
A very slow transition is what I'm after actually. The application for the cam is to act as a lock against a sliding Stackerbox transmission that acts as a low-maintenance chain tensioning system. The cam itself will have very little force put on it since the 4 bolts from the transmission will be tightened into the sliding plate, but the cam is necessary to make the overall tensioning system more reliable.
A symmetric cam may work just as well as what I want, but if I can have my cheese and eat it too then for now I will. In all actuality, to create the actual lock from 1/4" aluminum plate (I'm also looking into hardwoods) on a CNC, it will take either two passes for setup, or the final 90 degrees of the cam will have to be manually cut.
GitHub
CAD/CAM/CAE Projects available, register your interest. eProjects CAD 0 26-02-2008 21:34
FIRST in CAD/CAM newsletter & Engineering TV again Elgin Clock FIRST In the News... 0 18-01-2008 09:05
CAD-CAM and Dewalts Bill_Hancoc Technical Discussion 3 31-01-2006 02:08
CAD/CAM softwear Veselin Kolev Inventor 3 11-12-2004 23:17
cnc/cad/cam help chbix Technical Discussion 12 07-07-2004 22:40
