Go to Post Ok, so you are going to use a robot to hold all of those rivets together? - gblake [more]
Unread 25-06-2008, 18:19
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
Crab Drive
After our rookie season, we decided to take on building a crab drive. It has taken us a while since none of us knew inventor, it is also fairly primitive. The sprockets used to connect the wheel modules are missing, (they refused to go parallel with each other...) and there is no chain or screws yet. We would like some feedback on our design. Pictures are posted on http://s296.photobucket.com/albums/mm173/rshanor/
Thanks
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 25-06-2008, 18:24
EricH EricH is online now
Re: Crab Drive
Thanks
Regarding the sprockets...
Constrain them using the "flush" constraint. That should get the connecting sprockets coplanar/parallel to each other. Then mate them to the wheel assemblies.
So far, it looks good; I'm a little puzzled why there is a ring around the wheel. Is it to provide a rotational platform?
Unread 25-06-2008, 18:37
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Crab Drive
Cool, looks a bit like wildstang's crab design.
How much does it weigh as shown?
Will it be welded, or will it use the angle brackets as shown? If you use the brackets, its in general a good idea to have at least two bolts mounting it to each surface, so that they cannot rotate. It looks like there are several places with only one bolt hole.
Unread 25-06-2008, 18:41
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Re: Crab Drive
Crab Drive is a little iffy to me. Other then high maneuverability there aren't many advantages IMO. I mean if you lose one motor or chain it's game over for the match. Also it's a lot of work to build. I find that keeping a chassis simple is better and often lighter.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
RMS11's Avatar
Safety!!!!
AKA: Rick
Team Role: Driver
Re: Crab Drive
That ring will be used to mount the module to the lazy susan. As of welding, we hope to if we can find a location to weld at. We have not yet calculated weight yet, we are going to cut weight anter we build our 1st design.
Unread 25-06-2008, 18:43
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: Crab Drive
That is very impressive. Especially from a rookie. You guys are definitely one of the up and coming young FIRST teams.
What sensors are you going to use to get the wheels to re-center? Or are you going to rely on driver skill?
Unread 25-06-2008, 18:59
AdamHeard's Avatar
Lead Mentor
Re: Crab Drive
It looks like a really solid start for a crab drive. You have the overall concepts down, but there is a decent amount of detail work that can be improved.
Even with the bottom support for the module, I wouldn't use such a small shaft for the module rotation: It could potentially be taking a lot of load. Also, what is your method for attaching the shaft to the module?
I would definitely get it welded. It will be stronger than those L brackets by far, and won't loosen like the bolts will (You'd have to be rechecking the bolts constantly to be safe).
There doesn't seem to be a tensioner for the steering chain loop, what do you plan on doing?
I would try to make the bottom row of outer extrusion extend all the way into the corners for maximum strength. I see how it may interfere with that ring some, but you'll have to work that out. Since you are taking a lot of the module's load at the bottom with that turntable, the structure really needs to be strong there. I can see how the plate would strengthen it, but I would have the extrusion go the whole way just to be sure.
Don't let my comments get you down, it is definitely a promising start.
Good luck, and keep it up until you get a truly great design.
Unread 25-06-2008, 19:04
Joe G.'s Avatar
AKA: Josepher
Re: Crab Drive
You can do this fairly easily in inventor, by setting the material through iProperties, and then viewing the physical properties of the completed assembly
I suggest looking at wildstang's 2007 design. It is of the same basic design, but you can probably pick up a few ideas from it.
Unread 25-06-2008, 19:10
RMS11's Avatar
Safety!!!!
AKA: Rick
Team Role: Driver
Re: Crab Drive
We didnt think we needed a tensioner. We can tension by hand and there should be about 180 degrees of contact i think...
Unread 25-06-2008, 19:13
RMS11's Avatar
Safety!!!!
AKA: Rick
Team Role: Driver
Re: Crab Drive
We were going to mount a POT on the verticle shaft. Still need to work on a mount though...
Unread 25-06-2008, 19:22
Re: Crab Drive
Depends on exactly how it's set up. It is quite possible to have a motor go out and still be able to drive (e.g. 118 or 111). It is a lot of work to build, yes, but if they build one post-season, then it'll be a little easier.
There are easier ways to get maneuverability, but you can lose lots of power. Any drive system (or any system for that matter) that is designed during the offseason has an element of risk; the rules or game design may force a different setup.
And, in this case, there are definite advantages, if not to applying it for the 2009 game, then simply to doing it. For one thing, they're learning CAD. For another, they're thinking about new tricks to try in their second year. If they do build it, then it'll be a good experience and a pretty good freshman introduction.
Unread 25-06-2008, 19:40
RMS11's Avatar
Safety!!!!
AKA: Rick
Team Role: Driver
Re: Crab Drive
Thanks for the support.
Unread 25-06-2008, 19:41
That guy
AKA: Dennis
Re: Crab Drive
True, I'm so use to doing things the same way every year when it comes to drive trains. It is good for learning how to build and for using CAD. I was just talking about the drive it self.
Unread 25-06-2008, 20:03
AdamHeard's Avatar
Lead Mentor
Re: Crab Drive
I'm not sure what you mean by tension by hand. Do you mean try to stretch the train onto the sprockets? that won't work.
you could do *exact* center to center distances, but that would be difficult with all the different parts, and once the chain stretches it wouldn't work.
Really, you should be a tensioner in there, and position it so you get more wrap on the globe motor. Also, the globe motor output shaft should be supported.
As for the replies to the thread, he's designing crab drive, he already decided that. Help him with that, or don't reply.
Unread 25-06-2008, 20:36
Joe G.'s Avatar
AKA: Josepher
Re: Crab Drive
its a good idea on any chain run of this distance, regardless of wrap. Chains stretch considerably, and do crazy things under power. If you are planning on having seperate chains running to each module, and mounting space is a concern, then you can use this design, with a sprocket floating within the chain
http://www.youtube.com/watch?v=6fLf71xlVhE
If it is just one piece, then you will probably need a idler to get enough wrap around the globe anyways.
Crab Drive HELP!!*** GGCO Technical Discussion 18 08-01-2008 19:27
Crab Drive nukelear1991 Programming 13 21-12-2007 18:02
pic: Crab Drive Joe_Widen Extra Discussion 3 23-04-2006 15:49
Crab Drive Joe_Widen Technical Discussion 9 21-04-2006 21:50
Crab Drive Collin Fultz Technical Discussion 3 04-09-2002 16:35
