Go to Post As Murphy as my witness, things happen and will continue to happen. - Pavan Dave [more]
Unread 27-06-2008, 14:23
run the trap!!!
Team Role: Human Player
Re: pic: 2009 robot idea
Originally Posted by pacoliketaco View Post
so, i have been trying to design a lighter chassis than this years robot (at ~60 lbs) and i came up with this:
by my calculations, it will move at 14.82 ft/sec high gear and 5.79 ft/sec low gear. i have also figured the weight to at at around 45 lbs.
and just for future reference, 1x2 8020 weighs about .98 lbs/ft, and 1x2x.125 aluminum weighs about .88 lbs/ft. not much of a difference when the strength is taken into account.
Great Job! The level of detail in the CAD is amazing. How'd you make the chains?
This is VERY similar to my team's last two drive trains. This kind of system is very adjustable and easy to build. It's worked great for us these last two years.
2007:
2008:
Some things to consider:
5.79 fps is probably a little two slow. We ran low gear at about his speed this year and it was useless. The slowest I would go is 7 fps.
You could save more weight with #25 chain. This system makes chain tensioning a breeze, and you could easily implement #25. We used #25 this year and never lost a chain.
I'm curious as to why you put the axles on the center line of the extrusion. It would be a lot easier to put the pillow blocks on the top or bottom. You could save a lot of machining, and replace the 1020 with 1010.
Altogether great work though. Are you gonna build a prototype?
-Philip J. Fry
Unread 27-06-2008, 21:19
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
A note on the weight.... Remember that this year's control system will weigh significantly (3-8 lbs., if I recall correctly (someone correct me)) more than in previous years. It also will require quite a bit more (continuous) space than in previous years.
Love the design. We need an overhaul on our concept of the idea of a 'working drivetrain' (currently my team is having trouble with that concept), and this is a great place for us to start!
Jacob
Unread 07-07-2008, 16:29
team2061's Avatar
team2061 team2061 is offline
Gilberto Gonzalez
AKA: team 2061 captain/mechanical
FRC #2061 (PIONEERS)
team2061 will become famous soon enoughteam2061 will become famous soon enough
2007:
2008:
i saw that u guys used pneumatic wheels on the 2007 robot...we were going to use that this year but we couldnt find a way to mount sprockets on. Were those sprockets custom or were they bought?
2007 Las Vegas Highest Rookie Seed Award
2007 Las Vegas Regional Quater-Finalist
2007 Las Vegas Best Rookie Award provided by team 1547 Where's Waldo
2007 Las Vegas Regional Rank 7 of 51 teams, 2nd Seed
Unread 07-07-2008, 18:08
pacoliketaco's Avatar
pacoliketaco pacoliketaco is offline
Alumni
FRC #1807 (Redbird Robotics)
pacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to behold
Send a message via AIM to pacoliketaco Send a message via Yahoo to pacoliketaco
thanks for all comments/suggestions. i guess i could change the sprocket on the two wheels powered directly from the transmission to something smaller. the main reason that i wanted to use 1020 and mount the axles in the center was for strength. the past three years, we had a very similar drivetrain, which i felt was excessive, but then again, it was very robust. the reason i want a light drivetrain, is that in the past three years my team had been in FRC, we havent had a complicated robot. our other systems end up to be too heavy, and we have to make accommodations by making simpler mechanisms. this year i dont want to have to worry about weight, and starting off 10+ lbs lighter will help.
2008:
2007:
i wanted to make something that was only one level of 8020, to reduce weight. in the past i noticed that a single 1010 rectangle bends too much, so i decided to use 1020. using only 6in wheels, by putting them on either the top or bottom, there was 7/16" of clearance (too little) or 3.5" (too much)
about the weight of chain, #35 chain weighs only .21875 lbs/ft, and with 9.5 feet of chain that is only 2.078 lbs. switching to #25 chain, which weighs .085 lbs/ft, would save 1.27 pounds, which isnt much for all of the added trouble. the purpose of all of my designing is prep for next year, as our team doesnt have the time/materials to build a chassis during the summer. just to see that your team seems to have built the same thing that i wanted to make, shows that i am headed in a good direction.
as to how i make the chains in autodesk, i just use the KOP download, and modify each link a little bit. i added a VERY small rectangle in the center of them, in order for an angle constraint to hold them together. or you can ground one end of a set of links, and simply drag the other end away from it, until it is straight. once you do this, you have length of straight pieces of chain, but you still need the curves. to do this, i find the distance from the center of each sprocket to each other, and make a new assembly to work out of. i then add in the links one by one, making them fit around the sprocket. then i add in the straight pieces, and put the whole assembly on the finished robot. its a lot of work, but it looks awesome =]
Pace Nalbone
Carnegie Mellon University
Mechanical Engineering Class of 2013
2009 NYC Winner - 56 and 1796
(2009 Regional Record: 18-0-7 wins/ties/losses)
pic: 2009 Control System, Mounted Billfred FRC Control System 23 01-05-2008 19:02
pic: 2009 Distribution Block Billfred FRC Control System 16 22-04-2008 17:16
Idea to elevate robot. Gboehm Pneumatics 4 14-01-2007 15:15
Real cool Robot Idea Marcel Rules/Strategy 17 27-02-2006 20:21
Robot competition business idea Swampdude General Forum 6 16-03-2005 16:05
