Go to Post If your goal is to win matches... Pick the most capable candidate. If your goal is to change lives... Sometimes you pick those that need the most change. - IKE [more]
Unread 28-06-2008, 00:52
Re: Custom Two-Speed Transmission
In order to give a good answer to your question about "optimum" speeds, I need to ask a question in return.
Why do you want two speeds on a mecanum drivebase?
2 Speed Transmission ttldomination Technical Discussion 6 02-06-2008 16:00
AM Two Speed Enhancement kramarczyk Technical Discussion 3 15-12-2007 16:24
Using two CIMs in the Banebots Transmission Justin M. Technical Discussion 15 09-01-2007 09:41
pic: Team 865 custom 2-speed gearbox geo Technical Discussion 2 20-04-2006 18:13
Two-Speed Chassis Madison Technical Discussion 11 13-12-2003 11:41
