Go to Post I just like that PVC is the most basic need of humankind according to that diagram. Whatever would we do without it?! - Po-ser [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 29-06-2008, 20:56
SlaminSwimster's Avatar
SlaminSwimster SlaminSwimster is offline
FRC #2614 (MARS)
SlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant future
How do you scout?
Hey,
2614 was a rookie team this year so we didn't do to mcuh scouting, but we plan to next year. how do you scout? Is it all about formulas and excel or just which robots look the best? How do the questionaires that everyone asks the other teams on thurs. get used? Also anyone on a smaller team how do you manage scouting with not as many people? Any advice/ hints would be great.
You can sleep when your dead - Warren Zevon
Imagination is more important than knowledge -Albert Einstein
Unread 29-06-2008, 21:01
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: How do you scout?
Originally Posted by SlaminSwimster View Post
Hey,
Actually if you just scour the numerous threads populating the Scouting section you may find plenty of the answer you seek from many teams over the years. Lot's of good info to be had.
Good hunting!
Unread 29-06-2008, 21:18
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
Last year our scouting was really simple:
What auton did
Number of laps
Number of hurdles
Balls placed/ knocked off at end
Penalties
Any problems (i.e. did they break)
Comments (did they play defense much)
This is basically answering how does their robot compare to others and how can they compliment our robot.
We had everyone fill out the paper forms and then had someone enter that info into a database that could be easily checked.
Sorry, I'm not sure what our pit questionare was.
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 29-06-2008, 21:25
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
Find a veteran team in your area and scout with them. Just ask, most veterans would be glad to show you the ropes.
I can't tell you how much we learned by doing that.
Unread 29-06-2008, 21:45
flyingcrayons's Avatar
flyingcrayons flyingcrayons is offline
Team 1089 Alum. RU Class of 2015.
FRC #1089 (Team Mercury)
flyingcrayons has much to be proud offlyingcrayons has much to be proud offlyingcrayons has much to be proud offlyingcrayons has much to be proud offlyingcrayons has much to be proud offlyingcrayons has much to be proud offlyingcrayons has much to be proud offlyingcrayons has much to be proud offlyingcrayons has much to be proud of
we had a sheet that included a robot's performance in a round. usually we recieved 3-4 sheets a robot. also a major role in our decision was seeing how a robot fit with our gameplan.
Unread 29-06-2008, 22:49
Yep. They show you how they do it, both teams get data and sort.
I'm a fan of Excel sheets for this, because you can print one version and keep the rest for data analysis. Don't like the analysis results because they don't match what you're seeing? Change one master number and get a different sort.
Unread 29-06-2008, 23:25
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
The Thursday questionnaires are primarily used for the first couple matches before actual scouting data has been collected (combined with some generic notes on performance from practice day, which are taken with a grain of salt). They are also useful for seeing what teams still have work to be done (shows both that they won't be at 100% and that they have potential to improve).
Match data is what's incredibly useful for both match planning, and more importantly, creating pick lists for the elimination rounds (which should be done even if you aren't likely to be in the top 8). Take data on all game aspects, such as all scoring, penalties, etc.
Try to keep match notes as objective as possible, to provide consistent valid data regardless of note taker. Some subjective data should be taken (such as if the team appeared controlled, or were they struggling around the field), but keep it minimal.
Unread 30-06-2008, 00:30
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
To OP:
Dont forget that selection strategies are at the very least just as important as scouting. Selecting a great alliance and limiting the strength of an opposing alliance will serve the same purpose.
I have also found that observing matches of teams is one of the best ways of scouting.
Much attention is paid on stats, but in a 3 on 3 game, it gets skewed quite a bit sometimes. At championships in '08, a lot of good teams through strategy played the defensive role not scoring as many offensive points as they were capable of doing.
Unread 30-06-2008, 00:39
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
which is why one of our scouting data points is "defensive maneuvers".
Unread 30-06-2008, 09:05
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
Watch as many matches as possible! You will easily be able to rank the top 24.
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
Unread 30-06-2008, 10:14
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
It is important that you get data you can rely on.
Make sure the scouts are well-trained, know what they are doing, and know what they are looking for.
If you don't like the idea of putting info into an excel spreadsheet, we made a spreadsheet on paper that covered all matches for every team and then organized them in a three-ring binder.
One of the things we look at is whether a team was defended by another team and what team that was. If a team scores well in all of their matches except one where they were defended, then that speaks a lot about the team that was defending.
Use data from the practice matches only to loosely determine strategy on Friday. Use Friday data for selecting partners and use Saturday to solidify those selections.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 30-06-2008, 12:26
acdcfan259's Avatar
acdcfan259 acdcfan259 is offline
Brainssss....
AKA: Jake Carroll
FRC #1027 (Mechatronic Maniacs)
Team Role: Driver
acdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond repute
Send a message via AIM to acdcfan259
This extremely important. This year we had people who really didn't want to do the scouting, and we got very unreliable inconsistent data.
Unread 30-06-2008, 13:46
In addition to the valuable data, make sure all your students pay attention to special driver's characteristics and how they cooperate with their qual. alliance partners. Trust me, that is a huge part of selection.
If there are any teams in your area attending an off season and actually scout, ask them if you can join in and learn how they function, its better to be prepared before next season's competitions.
Unread 30-06-2008, 22:14
akeisic's Avatar
akeisic akeisic is offline
Systems and Strategy Mentor
AKA: Andrew Keisic
FRC #4201 (The Vitruvian Bots)
akeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to all
No matter what you system you derive, I think there's a balance you need to strike between the Excel spreadsheets and the paper notes. The Excel sheets make quick work of all the calculations, but is slow to navigate. The paper version is just the opposite.
Team Overdrive (FTC #74) had the most amazing scouting I've seen first hand. They had a sheet for every team out there with a pasted on picture of the robot. They manually recorded the happenings of each match (see other's comments for typical criteria) on each team's sheet. They then tallied the raw data in Excel and made printed their ranking sheet for their team representative to assist in alliance selection.
What they did there is pretty typical, but what set the scouting apart was they kept the paper versions filed in an portable accordion file that their captain kept ready at the field. As we progressed through the elimination rounds, we simply pulled the paper of the teams we were about to play and had all of the information at our finger tips - including autonomous routes. We were then able to strategize on the spot and did well as a result.
I was impressed so much, that I hope to emulate their system with my team this upcoming year.
Mentor: FRC 4201 - The Vitruvian Bots
Awards with FRC 294 - Beach Cities Robotics
2014: LA FRC Champions
2012: LA FRC Finalists
2011: San Diego FRC Finalists
2010: San Diego FTC Finalists, San Diego FRC Champions, LA FRC Finalist, FRC World Champions
2009: LA FRC Finalist
2008: San Diego FRC Champions, LA FRC Finalist, LA FTC Champions, LA VCR Champions,
2007: San Diego FRC Finalist, San Diego FTC Champions, FTC World Champions
Unread 01-07-2008, 01:03
astephen68's Avatar
astephen68 astephen68 is offline
Build, Scout, Drive
AKA: Stephen
VRC #0478 (Mustang Robotics)
Team Role: Scout
astephen68 is just really niceastephen68 is just really niceastephen68 is just really niceastephen68 is just really nice
When you scout depending on the situation, you should have a few things in mind: How do i get the information i need that it's a quick process of checking or circling the answer, do i really need this data or not, Because in a match there is only 2:30 for you to get the answers on that team so you need to be processed. My team for scouting this year used a excel database which we input the data from every team from papers and at the end of the day discussed what teams we need to focus on the next day.
Soutern Ontario Championship
-Finalists
-Winners of the Drivers Challenge
-Finalists
[IMG] code is Off
How do you notice that you spent too much time in Autodesk Inventor? Chris Herold CAD 14 20-02-2009 00:02
How do you feel about how the Autodesk award winners were decided? R Stephenson Inventor 43 02-06-2007 20:45
How many of you are either Life Scout or Eagle Scout in First spadercool Chit-Chat 18 23-05-2005 18:06
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
How did you learn how to use Inventor? Greg McCoy Inventor 26 24-05-2003 01:55
