Go to Post They're so cute I could just pinch their little CIM motors!:D :p - Akash Rastogi [more]
Unread 01-07-2008, 14:39
pogenwurst pogenwurst is offline
Ubuntu User
AKA: Brian
FRC #2007 (Robots of the Round Table)
pogenwurst is on a distinguished road
Send a message via AIM to pogenwurst
Mounting Maxbotix rangefinders
I know that a good number of FRC teams have used Maxbotix's excellent little rangfinders.
My team has four EZ0s -- they went unimplemented this season due to time crunch and inexperience, but I've thought up what I believe to be a solid use for them and plan to implement said use for Georgia FIRST's off-season competition.
My question, then, is this: have any teams that have used them come up with a particularly robust way of mounting and protecting them on your robot? Rangers do no good if crushed to bits.
Unread 01-07-2008, 16:48
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Mounting Maxbotix rangefinders
In 2007 we mounted one in a piece of 1.5" square tube with some plastic spacers and 4-40 screws. We also potted the board with hot glue to protect it from shorts.
Unread 01-07-2008, 16:52
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
I don't know if it counts as robust or well protected, but all I did was use a couple of zip ties to hold it to a piece of polycarbonate. That was a last minute addition, but I didn't have any issues with it.
EDIT: In 2006 I used a generous amount of hot glue to secure it to a servo. I didn't have any problems with that either, but maybe I'm just lucky.
Eric Haskins KC9JVH
Last edited by EHaskins : 01-07-2008 at 19:33. Reason: just saw a typo, CD-Spy=good
Unread 01-07-2008, 20:28
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
Our solution was to use thick double stick tape to leave them exposed, but we also mounted them 6 inches inside the robot from the edge of the bumpers/frame.
We did that because the ranger reports everything 6 inches and closer as 6 inches therefore we would know that at a reading of 6 inches we were right up against what ever the object is.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 02-07-2008, 13:07
Ubuntu User
AKA: Brian
Thanks for all your replies.
You don't happen to have a photo of that, do you?
Unread 03-07-2008, 11:05
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We got the smallest job-box that fit from radioshack and simply hot glued the sensor to back. Then we used a dremel to cut a circle in the cover of the job box.
The sensors were well protected. Our front one took a hit so hard that the job box broke off it's mountings and the sensor still worked fine, until I melted it trying to resolder a wire that I broke .
Also remember to strain relieve your wires so no force is put on the solder connections.
On another note, was anyone who used the maxbotics able to improve their "slow" response and the initial overshoot they see when going from a short distance to a long one?
We wrote software that minimized the maximum amount the sensor could change in one loop to remove the overshoot, but there have to be better options.
In addition, the sensors couldn't respond quickly enough to give accurate readings at 15 feet per second. We had to set our front sensor to stop the robot at 48 inches. By the time the sensor saw 48 inches, our front end was about to contact the other robot.
Unread 06-07-2008, 15:20
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
We had similar time-response issues. I hope the cRIO will give us a quicker response!
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 06-07-2008, 22:09
Ubuntu User
AKA: Brian
Thanks for your response, Tom.
Maxbotix's rangers update at a maximum rate of 20 Hz, so I don't think the controller change will help much in that area, unfortunately.
Maxbotix Ultrasonic Sensor Help... manderson5192 Programming 9 22-02-2008 14:25
Parallax and Maxbotix ultrasonic sensors Lucretius Programming 5 20-02-2008 14:34
Mounting m1k3 Pneumatics 1 28-01-2008 19:48
Laser Rangefinders DavidGitz Control System 14 17-05-2007 17:56
Maxbotix Sonar Sensor DonRotolo Electrical 17 04-02-2007 12:27
