Go to Post Thank you NASA (except for Dave, his tormenting hints make us even) - Mike Schroeder [more]
Unread 03-07-2008, 10:36
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Need help with mini motors
Originally Posted by vivek16 View Post
I'm telling you, these things look like they would make wicked rollers.
With a reduction to around 800 rpm, they have 190 oz-in of torque and with the 28mm gearbox, they end up at a weight of 5.1 oz with the gearbox!
These would be really useful in a manipulator because of their relatively high power density.
-Vivek
I agree with this point with the caveat that it really depends on the game piece. Sure, you can pick up any game piece using this motor on a roller when you're sitting still. However when you're in motion the roller needs to move at a speed greater than your robot's speed, otherwise the game piece will be kicked away or forced to slide with the bot (which greatly increases your chance to be defended against). Combine that with the needed torque to pick up the game piece of the year and you should see that there are many years where a small intake motor like this just isn't feasible. Use the "Intake Mechanism" tab of JVN's 2008 Design Calculator.
The conclusion I've derived is that with a 20:1 gearbox this motor was ideal enough to pick up the tubes in '07 and 1-2 poof balls at a time in '06 if your bot drove 6ft/sec or less. I agree that they're great power for the small size and weight in these years.
GitHub
HELP EMERGENCY WITH FISHERPRICE MOTORS Team2441 Motors 5 16-02-2008 22:42
questions on window motors!!!!! need help! nwbutterfly Motors 4 19-01-2005 18:01
Some help with motors Bharat Nain Technical Discussion 2 05-03-2004 19:29
Window Motors. Need help!!!! Mohsin Motors 1 27-02-2004 13:05
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
