Go to Post Hack saws are for hack work, the kind we don't do. - sanddrag [more]
Unread 06-07-2008, 15:43
sjeddie sjeddie is offline
sjeddie is an unknown quantity at this point
Question IFI Loader error "No programming board found"
Hi all,
I have installed MPLab along with the IFI loader for vex from the vex website. When I try to upload a demo .hex file onto the robot through IFI, it gives me the message "No programming board found..." and stops the upload. I have searched a long time for a solution but couldn't find any; please help.
Here's a screen shot.
The Controller Verification works fine, I pressed the button on the orange cable, and the PGRM status led on the vex blinks slowly. It seems to behave like this even when the vex is off, so I'm guessing there's something wrong with the cable? Then again, when I used this cable with EasyC the robot worked fine.
I am thoroughly confused , please help!
-Eddie
Unread 06-07-2008, 15:53
Re: IFI Loader error "No programming board found"
A common cause of the symptoms are not setting the IFI_Loader port to match the usb adaptor or serial port you are connected to.
I see you're using COM3, so try COM4. Many usb serial adaptors will default to one or the other.
One at a time try selecting each of the com ports under "PortSettings" had downloading.
P.S. "Controller Verification" isn't any use in just detecting if a device is attached. It's really for identifying the download protocol the loader needs to use, but if it doesn't find any controller then it just defaults.
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
Sorry, I don't know much about vex, but...
Is there a program mode the robot should be in?
Is the cable plugged in correctly?
Is the driver for the cable installed?
Has this setup worked in the past?
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Unread 06-07-2008, 16:01
Wow! Thanks for the quick replies
The problem is solved. I tested all other COM ports, and it turned out that COM7 worked. Thanks again for the help.
You guys are awesome
Unread 07-07-2008, 20:51
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
If you want to find out which COM port to use without trial and error, you can check the Device Manager and look under Ports to see which ports you have available.
To get to Device Manager, Use Windows Key+Break to open System, select the Hardware tab, click on Device Manager). Or Start--> Run-->devmgmt.msc
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
"Demo Stamp not found" error message Gatto Programming 1 07-02-2007 23:17
BattleCry @ WPI - "Lost and Found" Ken Streeter Off-Season Events 0 28-06-2006 14:30
Persistent "no robot controller found" error 1594code Programming 12 20-02-2006 20:59
IFI Loader "divison by zero" NHeclub Programming 4 17-02-2006 14:06
IFI Loader problem - "Invalid HEX file" wun Programming 9 22-09-2004 12:35
