Go to Post Blue shirts are ALWAYS watching. And they have spies everywhere. Always be on your best behavior, and be polite to every volunteer at the event. - Andrew Schreiber [more]
Unread 06-07-2008, 15:53
Re: IFI Loader error "No programming board found"
A common cause of the symptoms are not setting the IFI_Loader port to match the usb adaptor or serial port you are connected to.
I see you're using COM3, so try COM4. Many usb serial adaptors will default to one or the other.
One at a time try selecting each of the com ports under "PortSettings" had downloading.
P.S. "Controller Verification" isn't any use in just detecting if a device is attached. It's really for identifying the download protocol the loader needs to use, but if it doesn't find any controller then it just defaults.
"Demo Stamp not found" error message Gatto Programming 1 07-02-2007 23:17
BattleCry @ WPI - "Lost and Found" Ken Streeter Off-Season Events 0 28-06-2006 14:30
Persistent "no robot controller found" error 1594code Programming 12 20-02-2006 20:59
IFI Loader "divison by zero" NHeclub Programming 4 17-02-2006 14:06
IFI Loader problem - "Invalid HEX file" wun Programming 9 22-09-2004 12:35
