You send me into orbit.
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 01-07-2008, 21:23
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: How do you scout?
We have generally done a web based system so that we can do multiple inputs while simultaneously having the field team access the data. It really helps when we can put up a wi-fi network (yeah, yeah, 2009) so that we don't hae to run between the stands and the pit. It also allows us to share the data easily with anyone interested.
You can check it out at http://gearheadcrossing.org/2008/
Mark
Brick walls are for other people. - Randy Pausch
Unread 03-07-2008, 13:35
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
How do I scout?
...carefully
I finally compiled and ran a Wii homebrew program (check out the scene), and several nifty graphics libraries have been released recently. If all goes well, we'll have some wifi within the next half year (pleeeease!), so I can combine the DS scouting with an automatically updating Wii database program that displays in the pits Now, to me at least, that would be epic!
Unread 04-07-2008, 19:25
Devon27 Devon27 is offline
FRC #0027 (Team Rush)
Devon27 is an unknown quantity at this point
In addition to our normal scouting (posted earlier in this thread) this year we used overhead projector transparencies with the field, overpass, and starting areas printed on them and drew on the transparencies where the robot went in hybrid. We then sorted the sheets by team allowing us to see if a team had more than one auton/hybrid strategy and approximately where they went and what they did on the field.
Devon -- Team RUSH 27
2009
Kettering District Event Entrepreneurship Award, Lansing District Event Chairmans Award, Michigan Chamionship Chairmans Award
2008
Detroit Regional Finalist, Detroit Regional Chairmans Award, Great Lakes Regional Motorola Quality Award, Championship Motorola Quality Award
2007
Detroit Regional Entrepreneurship Award, West Michigan Regional Chairmans Award, West Michigan Regional Entrepreneurship Award
RIP John Lafata--Forever 27
Unread 04-07-2008, 23:45
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
1 sheet for each team with enough data for 8 matches.
Find 7 people to scout (you might have to be one of them).
6 of them will be scouters and 1 will be a manager (could be you).
Each match, the manager sorts through the 50-some-odd sheets and finds the 6 that are competing (not as hard as it sounds), and hands them out to the 6 scouters. It's easiest to designate 3 as RED scouters and 3 as BLUE scouters for the sake of being able to find your robot.
Then after the match, the sheets are exchanged and put back into order.
On Friday night, we either Black List or Green List robots depending on their performances. Black list means that you are done with the robot and they will not be considered for the final list (barring a miracle). Green list means they will continue to be scouted on Saturday. Hopefully you will end up with 30-ish green robots. Sort these green robots into order from best to worst. You may end up with more than one catagory (I.E.: Hurdlers and Speed, Ramp and Ringers, etc).
On Saturday, we scout just like normal and about an hour before the the final match starts, the scouting leader (you) and MAYBE 1 or 2 others that have been scouting with you make final revisions to the list created the previous night.
We also make a list of teams that we would decline if we are in picking position.
I kind of adopted this tactic from 269. I modified it slightly for use with 171 and so far, it's worked wonderfully. We are contemplating using a PDA-based scouting system but with the new control system for next year, it may need to be a wired system.
The system would replace the finding, distribution, and exchanging of scouting sheets and instead, leave that to the scouter.
As for creation of the scouting sheet, I try to keep things as simple as possible for the sake of my scouters. If certain fields are unimportant, not considered in the end, or are covering the same thing as other fields, then the sheet needs to be revised.
For instance, some scouting sheets I have used include fields that rate driver skill, robot attributes (speed, agility, etc). But I have found that in the end, if I work with the sheer numbers they put up (if they hurdle 6 times, is driver skill relevant?), I can get a better list. I also make sure to include a comment section if the scouter feels the need to take notes, or notify me of something regarding the robot.
It is also important for the person running scouting operations to keep the coach and drivers of their team informed so they can come up with a viable strategy. If I'm not scouting, then I try to run down to the pits with the sheets for the teams in our match. If I am scouting or managing, then I give the information via cell phone.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 04-07-2008, 23:49
That's pretty much a perfect summary of how we scout as well. One tip to help you out: have post-its or tabs to sort team numbers.
Unread 06-07-2008, 16:49
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
Originally Posted by akeisic View Post
No matter what you system you derive, I think there's a balance you need to strike between the Excel spreadsheets and the paper notes. The Excel sheets make quick work of all the calculations, but is slow to navigate. The paper version is just the opposite.
This is good advice. You want the facts- how many hurdles, how many laps, what it does in hybrid, etc., but you also want other details about it, things you can't just capture in the numbers.
When I was talking to our scouters about what I wanted to know about other robots as a coach, I made up this example of a "scouting report" on a team that could have been written up quickly, but gave good data:
Team XXXX:
An average robot.
Is capable of hurdling, but has a lot of trouble with ball control.
Needs to pick up ball from against wall.
Average speed.
Auto is capable of crossing 3 lines and knocking off 1 ball, but is fairly inconsistent.
High COG.
Several penalties- crossing the plane, interfering with a hurdler, entanglement.
Very fragile robot- broke during two matches.
Cannot place trackballs.
For defense ideas:
Keep balls away from walls,
Hit on left rear corner.
Other things that are good to include on the scouting sheet, no matter the year:
- a picture of the robot, so you can bring an image to mind when you talk about it
- how many years of experience the team has
- how many years of experience the drivers have
- how many hours of experience the drivers have
- if any, how many regionals has the team been to this season? results?
All of these things can be important, but some things end up outweighing others. Think about how a robot would interact with your team, if they would be partners, how you can strategize against them if they will be on the opposing alliance, etc.
To answer some of your other questions:
- On Thursday, our team only does "pit scouting", which consists of taking pictures of each robot and asking each team questions about their robot (based on the above stuff). It's usually pretty accurate if you bear in mind that the numbers are probably inflated (they're used to practicing by themselves, not playing under match conditions with 6 robots on the field). You can use this to get a head start for Friday matches, and compile it with the data you collect during qualifications.
- On Friday/Saturday during matches, our team uses a system of 7 scouters; one for each robot and one lead scouter to compile all the data. In the past, when we've had fewer scouters, we've tried it with one person per alliance, but that gets tricky and you get less data. You can have people swap out if you want.
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
Unread 07-07-2008, 19:47
AnthonyN1983's Avatar
AnthonyN1983 AnthonyN1983 is offline
Skunkworks
FRC #1983 (Skunkworks)
Team Role: Scout
AnthonyN1983 can only hope to improve
Send a message via AIM to AnthonyN1983 Send a message via MSN to AnthonyN1983 Send a message via Yahoo to AnthonyN1983
So pretty much, my name is Anthony Nguyen and i was the head scout for skunkworks team 1983. This past season was my first year with the team and my first year scouting. If you like I could send you our scouting plan/manual for last years game. The items that it includes are: scouting sheets, robot directory, how to compose a scouting notebook, excel spreadsheets, graph(s), pit scouting sheets, blahblahblahblah and the list goes on.
But all in all it is a very good start for any team who wants to scouting. But i have to warn you, it is not fully edited, so there is going to be a LOT of grammar errors as well as redundancy.
If you are interested, send me a message back with your email address.
Anthony
(>_<) Anthony Nguyen (>_<)
Skunkworks Team 1983, Scout, Systems Integration Member, Photographer, (Partial) *Mascot*
2008 Microsoft-Seattle: Engineering Inspiration Award Winner, Regional Winner (Accompanied by amazing alliance partners 2046 and 949), Delphi Driving Tomorrow's Technology Winner
2008 Oregon: Entrepreneurship Award and Safety Award Winner and Quarter-Finalist (thanks 492 and 2130)
Unread 07-07-2008, 21:55
Blue_Mist's Avatar
Blue_Mist Blue_Mist is offline
will return to 766 soon!
AKA: Mika Lai
FRC #0766 (M-A Bears)
Blue_Mist is a jewel in the roughBlue_Mist is a jewel in the roughBlue_Mist is a jewel in the rough
Since our team is pretty small and most people stayed at the Pit, I did almost all of the scouting for our team. Before each regional I wrote up scouting sheets that were basically one continuous table, with one copy as the Master that stayed at the Pit, and a few other copies that floated with the scout(s).
Each row was one robot and each column information on said robots. Each row was a different width depending on my speculation of what teams would be scout-worthy, based on past experience: say, 254 would get more space than a rookie. The first column would be team number and name, and then the name our team uses, say Team 192, GRT, we would refer to as Gunn instead, or Team 100 Woodside/Carlmont rather than the Wildhats. The second and third columns were Game Play, with checkboxes for (2nd Column) Auton, Laps and Control, and (3rd Column) Hurdle, Place and Remove. Each category had space after it for notes. The last column was Reliability, and that we left blank, for notes. I printed these out and let pencil and paper work their magic. Each scout I could gather would mark down and note robots and then bring their sheets back to the Master sheet, and that way the Master was always available. Feel free to PM me if you want the actual sheet. (It's a little scary; Silicon Valley and Davis were four months ago but I can put this down directly from memory...)
We never did set up an analysis system, but before each of our matches, I would mentally analyze each robot that we were working with or against and gather the other two robots on our alliance and discuss strategy with all three drive teams.
Pit Scouting was crucial here. I drew each robot in its team number and name space, and in this way was able to keep track of each robot on the field. Some teams take photographs as a parent did on our team, but I found the drawings easier to edit in case a team dramatically changes their robot. I also asked questions all three days, and while the numbers are a usually little inflated, most rapidly deflate when compared to match scores for individual robots.
"There's no finer engineering than pit engineering." -kaszeta
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot." -Amanda Morrison
'09
Unread 07-07-2008, 22:00
AKA: Ellen McIsaac
Another suggestion I just thought of for if your team is so small that you can't afford to devote more than, say 2 or 3 people to scouting:
On Thursday, have your scouters do pit scouting. Have them watch matches on Friday and Saturday to contribute to the pit scouting, but set up a partnership with a larger team that has an established system. A lot of teams are happy to share their data, so you can get all the number facts from them that you might not have quite enough people to gather, but you can supplement that with qualitative and more subjective data that you can use for analysis.
Ellen McIsaac
Unread 07-07-2008, 22:06
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I've seen 842 have a laptop with their (fantastic) scouting data on it available in their pit for viewing....
Unread 08-07-2008, 12:32
AndyB's Avatar
AKA: Andy Burchardt
We did this at the Wisconsin Regional. We only 4 or 5 kids to scout so we offered to team up with team 2194. They were more than willing and I think we both enjoyed the lightened workload.
Unread 08-07-2008, 15:32
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Our scouting team did the best they've ever done this year. They had paper sheets for each match with all the pertinent information - robot number, auton lines, pens, regular lines, hurdles, herds, even a map that showed the robot's course in autonomous.
Then they had a pre-made spreadsheet that they entered the data into and could sort with drop-down sort boxes. Finally, they had a couple folks going around taking pictures of all the robots. We viewed those pictures as we discussed each robot.
At MARC where we didn't have the resources to do a full scouting, we had 3 people watching what happened and feeding the info real-time to a person entering the data on the computer. That way we had it immediately sorted when team selections came right after the last match.
On thing that was helpful to me at MARC was that the formulas were set up to calculate average score in auton and normal modes over the course of the competition. So we were able to look at all-around good robots, and were able to see that some robots got by on the strength of their auton, and others the strength of their hurdling.
Unread 08-07-2008, 21:20
Clinton Bolinger's Avatar
Clinton Bolinger Clinton Bolinger is offline
FF - PureMichigan
FRC #2337 (EngiNERDs)
Clinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond repute
We did something very similar at MARC as well.
Our scouting team had 6 people scouting, one for each robot on the field.
There was one scouting sheet per team, that had all of their matches listed.
After a few matches the scouting sheets were passed to a person entering the data through out the day, then back to the scouters.
The excel sheet would create printable Match Overview sheets that were delivered to drive team before each match. Which included real time statistics (average, Min, Max, and Rank) for Team Contribution, Hybrid Lane Markers, Hurdles, and Laps. The Match Overview sheet would also insert the team name and picture of the robot. As well as the estimated scores for the red and blue alliance.
Our scouters did an amazing job of scouting and they system worked very well. Although it had one fatal flaw, since each sheet was based on individual teams and not matches, the sheets had to be passed to the data entry person then back to the scouters. Ultimately our scouting system caused us to miss a potential 1st round pick (HOT Team 67). At MARC HOT did not do that well in the first few matches (which we had entered) but after match 19 their performance on the field kept increasing and was missed.
So for our next competition (Kettering Kickoff) we will have 6 sheets (automatically generated from the match schedule) one for each robot position (Red 1,2,3 and Blue 1,2,3), with 4 matches on each page. Once the all 4 matches have been played the sheet moves to the data entry person and then gets filed away.
If any one cares to see it in action at Kettering Kickoff, feel free to swing by our pits.
-Oris-
EngiNERDs - Team 2337
Unread 08-07-2008, 23:20
klrswift klrswift is offline
AKA: Kevin Swift
FRC #0910 (Foley Freeze)
klrswift has a spectacular aura aboutklrswift has a spectacular aura aboutklrswift has a spectacular aura about
Send a message via AIM to klrswift
I have noticed that most of you have said that you use 6 people per match, one per robot on the field. We have done it a bit differently. Usually, we assign a number of teams to each person that isnt in the pits, whether they are parents, students, siblings, etc.
The advantage of this approach is that you get to know the teams that you are watching. You are able to note their progress through the qualifying rounds, whether they are better or worse at the beginning and end. That is something that is not as easy when you are just gathering stats. This approach also allows scouts to not have to watch every round, and are able to get up and take a break.
A HUGE disadvantage of this system is that you can easily be forced to watch 2 teams in 1 match. This is fixed by asking someone who doesn't have a robot to watch that match to help. I am working on a way to sort the teams so that this can be minimized, but it is also difficult if your scouts aren't all there at the beginning of the day.
Another problem ive noticed is that scouting is seen as an undesirable job, which is a far nicer way to say what was said to me about it by one of our other alumni. Be sure to emphasize the importance of scouting and strategy to your scouts, otherwise they will see it as a chore and not do a good job.
Unread 08-07-2008, 23:31
good point. First of all, we also include 2 or 3 people overseeing the entire field. These certain people are highly skilled at identifying and interpreting a robot's performance, driver skills, and just about everything you can imagine. I highly suggest that teams do this. Its something insanely useful. PM me if u have more questions about it.
Second, basically what riles up our frosh scouters is the usual "Scouting wins us regionals" talk. And swear to god it has won us regional even with a mediocre bot.
[IMG] code is Off
How do you notice that you spent too much time in Autodesk Inventor? Chris Herold CAD 14 20-02-2009 00:02
How do you feel about how the Autodesk award winners were decided? R Stephenson Inventor 43 02-06-2007 20:45
How many of you are either Life Scout or Eagle Scout in First spadercool Chit-Chat 18 23-05-2005 18:06
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
How did you learn how to use Inventor? Greg McCoy Inventor 26 24-05-2003 01:55
