Go to Post and don't overestimate the ability of an unskilled fool with exotic tools! - MissInformation [more]
Unread 08-07-2008, 01:24
Browzilla Browzilla is offline
Fearless Leader
AKA: David Vriezen
FRC #2530 (Team Inconceivable)
Team Role: Electrical
Browzilla is on a distinguished road
Send a message via AIM to Browzilla Send a message via MSN to Browzilla
Help with rangefinder sensor (RobotC)
Now that we're heading into our second year, we're attempting to implement some sensors into our robot. Better now, than during next season see, because then we know what we're doing. Moreso, anyway. Anyway, we have a Parallax Ping)))), and it's wired up to Digital IO 1 and 2. But we can't seen to get it to work in the code. It shows values between 0 and 1 in debug.
Anyone have any ideas or experience in this area?
Unread 08-07-2008, 02:41
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Help with rangefinder sensor (RobotC)
The Ping))) outputs a measured distance by outputting a pulse of a certain time. With our controller, finding this time and converting it back to a distance will be pretty hard.
We're trying out some Maxbotix Ultrasonic sensors, and they seem to work well, and they're easy to connect and program. We're using the analog out on the Maxbotix ones, and it gives a clear, steady signal. I highly recommend them to any team because of my experience so far.
If you still want to try the Ping))), search Chief Delphi for it. I know there have been teams that has used this sensor before, and you can possibly find some code to get it running. Here is the instruction manual for the Ping))).
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 08-07-2008, 09:22
Fearless Leader
AKA: David Vriezen
We've already found some code for it in MPLab and EasyC, but couldn't port it over to RobotC.
To be honest, we're really only using the Ping because it was what our local RadioShack had.
Anyway though, we've seen the sample codes, read the manuals, and it still doesn't seem to work.
Unread 08-07-2008, 10:17
I haven't used RobotC, but it appears they support a "Sonar" sensor, which probably works the same as your ultrasonic sensor.
Unread 09-07-2008, 01:57
Fearless Leader
AKA: David Vriezen
Yep. It didn't seem to work.
It seems RobotC may be easier to get of the ground with, but possibly less functional overall. Or harder to implement more advanced features, or something.
ROBOTC help Shivang1923 Programming 3 09-02-2008 13:19
Help with Gear Tooth Sensor RedOctober Electrical 3 27-01-2006 18:38
Help with Gear Tooth Sensor RedOctober Technical Discussion 0 26-01-2006 20:22
Help with sonar sensor supertw Electrical 3 24-01-2006 23:41
Need help with Sensor Hop_of_752 Programming 5 06-02-2004 23:43
