Go to Post The rules are the rules, but if the rules get so ridiculous some of us may choose not to play anymore and that is the bigger shame. - Paul Copioli [more]
Go Back   Chief Delphi > Technical > CAD
Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Unread 10-07-2008, 15:22
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: Any one know UG NX5?
OK, circling back around...
So, nobody I've approached at GM or UGS/Siemens have been able to identify a function that imports a point set as just a set of points. The point import options are buried in the spline and surface generation functions. For the record, here is the solution I came up with in case it is of use to anyone else.
Create data file
- Take your two columns of XY data and paste it into an new excel sheet. Add zeros for Z. There should be no column headers, just point data.
- Save it as a tab delimited text file with a .dat suffix
Set-up NX
- Open your file and move the WCS to the origin that you wish to use.
Import the points as a spline
- Insert -> Curve -> Spline
- Select the "Through Points" option
- Select the "Points from File" option - accept the other defaults
- Choose the data file you made earlier - You should see the point cloud at this point
- Select OK to generate the spline
Extract the point definition from the spline
- Insert -> Datum/Point -> Point Set
- Select the "Spline Defining Point" option
- Select the spline
- Refresh the screen (F5) to see the points created
- Delete the spline to leave just the points
You may all now laugh at the NX users.
Mark
Brick walls are for other people. - Randy Pausch
WHY???? No one will EVER know Chief Pride Chit-Chat 7 31-10-2007 08:05
Will air pressure in venue affect path of ball? (was: DOES ANY ONE KNOW ????) RoboDriver Technical Discussion 5 17-01-2006 23:02
Any body know any Alphawolf829 Off-Season Events 0 28-03-2003 15:30
Does any body know any good ways of doing this archiver 2001 0 24-06-2002 00:27
Does any body know any good ways of doing this archiver 2001 2 24-06-2002 00:27
