Go to Post We can either sit around and complain about what could have been, or we can focus on the upside of what we have and move on. - Vikesrock [more]
Unread 10-07-2008, 21:38
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
Re: Detecting Hybrid \ Teleoperated
Not that I'll have much of an answer, but the first question that will come to mind from everyone here is what programming/compiler are you using, and what version. MPLAB has two "out of the box" versions by Kevin Watson (Kevin.org -- whoa! New picture Kevin!), and Easy C. Both of them (if I remember correctly: it's been a couple of months from robo-programming) keep the hybrid/teleop mode switch out of the hands of the programmer and jumps to their respective routines and you go from there. For Kevin's 2007-and-earlier MPLAB version, you can see the switch in the main.c routine. But I wouldn't fiddle with it unless you know what you're doing.
Looking over your question again, if you want to use the "same code" for both modes, if that is what you're asking: Hybrid and teleop start in different routines. Can they not call the same routine(s) from there? And as one uses joysticks and the other (presumably) does some program-operated thinking, the stuff that is different will be in their own starting routine before or after they call the common routine(s).
Of course, this is all changing for 2009 as there is a new controller and new software coming out (hopefully before Kickoff ).
And naturally, Eric got in ahead of me, even if you weren't there a second ago!
Last edited by Roger : 10-07-2008 at 21:42. Reason: Shake my puny little fist at Eric!
Detecting Start of TeleOp Mode Danny Diaz Programming 4 26-02-2008 01:37
Keepers in Teleoperated mode burkey_turkey Rules/Strategy 47 05-03-2007 12:56
detecting life in batteries wkethman Electrical 5 07-03-2006 08:04
Detecting and handling sensor failure gracefully mtrawls Programming 9 20-04-2004 17:19
How do you tell whether your sensor is detecting a crate or the diamond plate? Greg Ross Technical Discussion 4 13-01-2003 19:02
