Go to Post Now stop reading CD, do your homework, eat your peas, brush your teeth, and go to bed. Any time you spend speculating as to what Dave's ravings might mean is completely wasted. - Richard Wallace [more]
Unread 11-07-2008, 23:52
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
Waterjet question - cutting through tubing
I was wondering... Can a Waterjet cut through tubing? For instance 4x4x1/8" Square Tube Aluminum? I know waterjets do great work with plate, but can they do the same things with tubing, such as cut isogrids.
And if so, would they be able to accurately cut the same pattern on the opposite side of the piece in one pass? (would this be different for different sized peices, say, 1x2?)
I know a CNC Mill would be able to do this, but just wondered if waterjet would be able to do it quicker and neater.
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 12-07-2008, 00:48
Valley Raider Valley Raider is offline
FRC #0955
Valley Raider is just really niceValley Raider is just really niceValley Raider is just really niceValley Raider is just really niceValley Raider is just really nice
Re: Waterjet question
Not really. A water jet can but after the jet of water cuts though the first surface the water starts to spread out and the second cut is not nearly as clean. We tried it once with 1 by 2 and it came out ok... We were just cutting holes for weight and we ended up just machining it. I don't think it would work for a 4 by 4 very well at all but you could try it.
Unread 12-07-2008, 00:58
bigbeezy's Avatar
AKA: Bryan
ya that makes sence.
I wonder if you could somehow block the water from cutting through the second side with like a metal plate or something and then just have the machine do a second pass (with the plate removed) to cut the other side.
Unread 12-07-2008, 01:46
HostV HostV is offline
HostV is an unknown quantity at this point
Well don't it make sence for the only first and very short period of time? I believe that can't work always...
HostV - VPS Hosting - http://www.hostv.com
Unread 12-07-2008, 02:03
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
Triple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant future
you can put a 4x4 or a pair of 2x4s inside the box and cut the four sides individually. it will be decent and if you are powdercoating, you will never know it wasnt milled.
mike d
See Ya
Unread 13-07-2008, 15:04
Brandon Holley's Avatar
Re: Waterjet question - cutting through tubing
There must be some way to keep the pressure low enough to cut through the 1st and not the 2nd. No?
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 13-07-2008, 17:08
Dick Linn's Avatar
no team (Synergy)
I would imagine that the best way would be to cut each side separately. If the top was cut above water and the bottom submerged, you might not have a problem, especially with a slower travel and lower pressure.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 13-07-2008, 19:15
DonRotolo's Avatar
Back to humble
FRC #0832
Anyone who runs a waterjet will know how to do that.
This Thread has a link to some photos showing an Xbox cntroller cut up by waterjet - demonstrates that thick objects can be cut as well.
Unread 13-07-2008, 19:22
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
If you look at the X-box cut into an X photo, you can see how poor the finish is on the exit cut, relative to the entry cut.
If you tried to do both sides in one shot, that's probably what's going to happen. If it was solid, you could cut something 12" thick if you really wanted to, and had a big enough pump, and the exit cut would be pretty decent.
the block of wood inside the tubing sounds pretty easy and simple to me.
2001-2004: Team 100
2006-Present: Team 254
Unread 13-07-2008, 19:24
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
I don't really think sticking something in there will stop the water. Waterjets can cut through 8" thick steel like butter.
-Vivek
"we don't build robots, we build people"
Unread 13-07-2008, 20:23
Cory's Avatar
AKA: Cory McBride
-Vivek
Mike is a waterjet expert. If he says you can put a 4x4 in there, it's good enough for me
2001-2004: Team 100
Unread 13-07-2008, 21:03
ducttapedude ducttapedude is offline
AKA: Peter
FRC #0233 (The Pink Team)
ducttapedude has a spectacular aura aboutducttapedude has a spectacular aura aboutducttapedude has a spectacular aura about
Send a message via AIM to ducttapedude
If I remember right, the waterjet has the capability to cut through that much steel, but adjusting settings on pressure/speed can change a lot of things you do with it.....I think. so, set it for 1/8th aluminum is a fairly fast pass. and 4 inches of wood is a lot....
not sure on this stuff, but if that makes any sense.
Think Poof
Unread 13-07-2008, 21:25
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
-Vivek
I believe that the purpose of the wood would not be to stop the water, but to create the same effect as a solid piece of metal. If the jet dosen't have any room to spread out, it will retain its power all the way through the tubing.
Unread 13-07-2008, 22:05
AdamHeard's Avatar
Lead Mentor
He says to cut the four sides individually, so It probably isn't going all the way through. The wood must be doing something to the water to keep it from cutting through.
Either way, I'd take his word on waterjetting.
Unread 13-07-2008, 22:31
all hail Passmore
Thanks Cory, but I am no expert.
I have played with waterjets for about the last ten years and have tried many different operations.
The wood will disperse or defuse the water to the point that it wont go thru the second wall, which allows you to flip the part and get a nice cut on both sides.
You doo need to play with the cut speed and pressure as it is much like voodoo, works great one time and no so great the next.
I will try and bring a sample to IRI if possible.
mike d
See Ya
pic: Frame ready for welding, special thanks to Con(Trapp)tions at Waterjet Cutting of Indiana. Towns1024 Extra Discussion 8 29-01-2008 10:43
pic: 1889's waterjet nest Tytus Gerrish Extra Discussion 7 17-01-2007 15:42
Showcase of waterjet cutting Peter Matteson Technical Discussion 3 07-01-2007 23:21
pic: Waterjet nastiness Dermilogical Effects -face Tytus Gerrish Extra Discussion 12 10-06-2005 22:34
Pneumatic Tubing Question Ryan Dognaux Pneumatics 2 31-01-2004 20:23
