Go to Post The sponsor had a $2000 sheet of aircraft aluminum in their scrap bin? Do they also blow stacks of dollar bills off their loading dock with a giant fan? - Richard Wallace [more]
Unread 13-07-2008, 22:28
SlaminSwimster's Avatar
SlaminSwimster SlaminSwimster is offline
FRC #2614 (MARS)
SlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant futureSlaminSwimster has a brilliant future
pic: Team 2614's Cracked Plexi
Unread 13-07-2008, 22:29
JESTER357 JESTER357 is offline
FRC #0357 (Royal Assault)
Team Role: Driver
JESTER357 is on a distinguished road
Re: pic: Team 2614's Cracked Plexi
what an amazing time. i remember u bringing that up to me and saying there is no way that happened
Unread 13-07-2008, 22:43
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
One of the ways to tell the difference between acrylic (aka: Plexiglas) and polycarbonate (aka: Lexan) is the color of the edges.
Acrylic has a white edge.
Polycarbonate has a blue edge.
The producers of polycarbonate resin call this a "blueness index", if I recall correctly.
On this picture, many of the edges appear white. I only see blue edges where there are 2 layers of plastic. My guess is that we are looking at an acrylic sheet. And, of course, acrylic is much more brittle than polycarbonate.
Look at these two pages on www.matweb.com:
Extruded Acrylic
Extruded Polycarbonate
If you check out the "mechanical properties" of these two materials, they look somewhat similar in their strengths and properties, until you see the "Izod Impact, Notched" rating:
Acrylic has a rating of 0.3-1.1 ft-lb/in
Polycarbonate has a rating of 0.9 - 18.0 ft-lb/in
The higher value of the polycarbonate means that it can take an impact hit much better than acrylic.
Andy B.
Unread 14-07-2008, 10:44
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Yeah the plexi(acrylic) vs. lexan(polycarb) mistake is a bad one.
We had some high stress pieces of 3/16 lexan on or robot this year that began to break after the first regional. We replaced them with 3/8" ??? Clear stuff. They snapped in the first match at the second regional. Turns out they were plexi.
The solution ended being going back to the thinner lexan and paying closer attention to surface cracks. A bandsaw will leave gouges perpendicular to the material thickness where-as a dremel sanding drum will make the gouges parallel to the thickness and thus slightly tougher.
Noticing that this looks like a non-structural body panel, here is a little secret:
McMaster Carr sells polycarbonate film (0.02-0.04"). Attached with velcor, this makes very puncture resistant "armor" without adding much weight. Be careful if you cut sharp inside corners into it as this can initiate a tear quite easily. Also, going much less that 0.020" is pretty thin stuff and thus not terribly strong.
Unread 14-07-2008, 13:44
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
One of my friends was at a hardware store when someone asked an employee what the difference between Plexiglass and Lexan was.
The employee didn't say a word. He grabbed a hammer, a sheet of Plexiglass and struck it. The plexiglass shattered. He grabbed a sheet of Lexan and hammered on it repeatedly with no effects.
That was an amusing story.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 14-07-2008, 15:15
One year, 330 had a plastic-encased robot. Lexan wedges (pre-no-wedge rules), and a tower that had thinner Lexan on 3 sides and acrylic on the fourth. We replaced one panel all season. One good hit from a robot at our first regional of the year, going up a wedge, broke it. After that, there wasn't acrylic on the robot...
Unread 14-07-2008, 16:03
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
The employee didn't say a word. He grabbed a hammer, a sheet of Plexiglass and stuck it. The plexiglass shattered. He grabbed a sheet of Lexan and hammered on it repeatedly with no effects.
That is the exact procedure I recommended to another mentor on our team on how to distinguish acrylic from LEXAN.
Unread 14-07-2008, 18:24
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
We had a plexiglas cover over our electronics board (mounted vertically at the back of the robot) on our 2006 robot. In that position, it naturally took a lot of hits, and it looked like that after the first few matches... we learned our acrylic vs. polycarbonate lesson that way, too.
Everyone else gave you good advice, so I won't repeat it.
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
Unread 14-07-2008, 18:58
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Our Shop teacher laughed and put each one through a table saw. The acrylic shot out and cracked and polycarbonate was cut with no problems.
R.C.
MadTown Robotics Team 1323
Unread 14-07-2008, 20:30
umm...don't do that ever again. lol
Unread 14-07-2008, 21:13
R.C.'s Avatar
Yeah we weren't planning to, but we had safety glasses on =).
Thanks for the reminder
R.C.
Unread 15-07-2008, 07:49
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
This was the exact test I showed my team this past year.
1 shot with a hammer and they were convinced that polycarbonate is the way to go.
___________________
- Tennyson, Ulysses
Unread 15-07-2008, 11:28
...are there any situations where acrylic is more useful than polycarbonate?
unless the part is designed to shatter, of course.
Unread 15-07-2008, 13:29
Francis-134's Avatar
Francis-134 Francis-134 is offline
Lifer
FRC #0190 (Gompei and the Herd)
Francis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond repute
While I'm not an expert on plastics, I have found that the only advantage to plexi over Lexan is cost (a cursory inspection of Wikipedia confirms this). Plexi tends to cost much less than Lexan.
For example, the large tank's viewing screen at the Atlanta Aquarium is made of acrylic not Lexan because it's never going to come under any significant shock loads and will never risk fractuing. If it were made of Lexan, it would probably cost MUCH more money.
Email | Twitter | Facebook | YouTube | Twitch
iTunes Podcast | Snapchat
A proud alumnus of teams 134 and 40 || Mentor of Team 190 || Director of Fun for BattleCry@WPI
Unread 15-07-2008, 15:18
FRC #2614 (MARS)
Yeah we definitely learned our lesson about plexi. But a broken shield in exchange for winning the Pittsburgh Regional- totally worth it!!!!
You can sleep when your dead - Warren Zevon
Imagination is more important than knowledge -Albert Einstein
FedEx not what it's cracked up to be Bongo General Forum 25 22-02-2007 21:14
plexi glass clatek Technical Discussion 13 29-01-2006 13:01
Will plexi-glass work? MathewSmith Technical Discussion 33 08-04-2004 07:17
The Manuall will be cracked in... Justin General Forum 63 08-01-2004 23:44
Plexi-Glass walls Brett W Rules/Strategy 8 21-02-2003 22:44
