where to find CAD models of Dewalt gearbox?
I was wondering if anyone knows where i can find CADs of dewalt transmissions and motors or any drill transmission for that matter if there are any?:confused
Re: where to find?
i would PM roboticWanderor, he has posted a transmission render that uses dewalts recently.
Re: where to find?
Re: where to find?
I have a cad model of a dewalt, email me at rcthekid1323 [at] gmail.com
Last edited by Greg Needel : 12-07-2008 at 21:47. Reason: removed email address to prevent spam |
Re: where to find CAD models of Dewalt gearbox?
It's amazing what can be found in these very forums...
http://www.chiefdelphi.com/forums/sh...19&postcount=4 |
#7
if anyone needs it in solidworks tell me or i can upload if you guys want
#8
thanks for the site another question does anyone know the specs on the dewalt transmission with the motor on it in terms of torque speed at make efficiency. Also would you recommend which banebot gearbox are drive train worthy and if i should be using them because I have no experience with them and would like some info to go on
Last edited by kajeevan : 13-07-2008 at 10:55. Reason: sorry about spelling.....its at max efficiency |
#9
I would like to say either use the andymark am products or the dewalt on the drive, or a custom built if you have the machining abilities. To use all the small motors i recommend a gearbox from banebots:
http://banebots.com/c/MOTOR-PLAN |
#10
In general, the dewalts really only work well when used exatly like in the NBD whitepaper. If you read the whitepaper you will find much of the data and specs you are asking for.
#11
well I'm not going to be using them on a frc bot there actually for Skills Canada and I just want to get to know which are good motors for a bot about 50lbs wanting to go say 8f/s. But I want to keep the weight low by using smaller motors for the base and not cims.
#12
They're are lots of cheap drill motors that would work great for this project and would require less modification than the NBDs. Harbor Freight makes a cheap 18v drill that many battlebots builders have modified for drives over the years. They're very durable and only cost around $24. The RobotMarketPlace also stocks a large selection of quality drills. They've got trannys and drills for 12v, 14.4v, 18v, and 24v. All at reasonable prices. If you're looking for ultra high quality (and don't mind spending the money) the best drill motors and mods can be purchased from TeamDelta. Depending on how intense "Skills Canada" is, BaneBots might be good enough. They really are cheap. But don't expect them to survive high current or a lot of shock. |
#13
The CAD model of the Dewalt transmissions from team 1742 are still available on their website, though they aren't obvious to find. The download page can be found at http://team1742.com/2006%20Season/download.htm
Sorry for the inconvenience on finding them, I'll see if I can get our website admin to put a link to them on the front page so they're easy to find. ~Tim~ |
| Electrical Component CAD models | johnnysanchez | CAD | 8 | 17-11-2010 10:59 |
| Dewalt gearbox CAD file | AdamHeard | CAD | 5 | 17-07-2008 19:48 |
| CAD Models of Vex Parts | gblake | VEX | 1 | 30-08-2007 11:45 |
| pic: DeWalt Gearbox with two CIMs | MAteo9944 | Extra Discussion | 17 | 02-01-2007 05:34 |
| 3D CAD models for mechanical components | ady_mech | Inventor | 4 | 17-08-2004 18:25 |
