Go to Post Excited and motivated students and teachers can do amazing things. - Wetzel [more]
Unread 14-07-2008, 14:16
Chath Maral's Avatar
Chath Maral Chath Maral is offline
User
AKA: Chathus Marlaclusos Majere
FRC #1785 (Robocats)
Chath Maral is an unknown quantity at this point
Question Bluetooth!?!
I am a new programmer with just the most basic understanding of code, and I heard the controls for next year include using bluetooth.
Now I know that "officialy" you can't say yes, if that is a rumor that is being used to intimidate then it's working well but if confirmation is available then I will ladly accept it.
Two things:
Cake==lie;
IF(char pit=="mosh","fun","work");
GO TEAM Robocats!!!
Unread 14-07-2008, 14:46
11Mort11's Avatar
11Mort11 11Mort11 is offline
AKA: Alex Joss
FRC #0011 (MORT)
11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold
Send a message via AIM to 11Mort11
Re: Bluetooth!?!
we are actually fooling around with bluetooth for the wii mote it should be pretty cool
and there was a display of that in atlanta if you went
Unread 14-07-2008, 15:16
User
Re: Bluetooth!?!
I didn't go but I think that's where the speculation came from and each year is a challenge so I think it would fit right in to their plans, whatever they are
Two things:
Cake==lie;
GO TEAM Robocats!!!
Unread 14-07-2008, 15:30
Re: Bluetooth!?!
According to the FAQ, Bluetooth isn't currently listed as a programming method.
From the document found here:
Q What type of communication does the system use?
A The new system uses proven 802.11 wireless communications. More features are being considered for future expansion including robot-to-robot direct wireless communications and wireless joystick operation.
Q Must they be tethered in order to apply/change certain settings?
A No, the new system will include the ability to do wireless programming. However, this may not be allowed in competitions (in the PITS) to avoid wireless contention with the field.
Q Will the new controller be programmable through a USB 1.1 or USB 2.0 port?
A No, it will use an Ethernet connection.
Q How do I download code to the controller?
A Using either LabVIEW or the WindRiver Workbench tools over a much faster wireless connection.
This doesn't eliminate the possibility of Bluetooth, but... I'd say it's unlikely.
The NXT unit (used by FTC and FLL) is Bluetooth-capable. The FRC controller isn't the NXT, though.
Unread 15-07-2008, 08:46
The Lucas's Avatar
CaMOElot, it is a silly place
Re: Bluetooth!?!
Using WiFi, pretty much eliminates the possibility of Bluetooth. They both operate in the 2.4GHz band and thus interfere with each other. I would not want to operate a Bluetooth device in an environment with what could be 6 or more channels of WiFi (or as low as 2 channels). Bluetooth frequency hops around the whole spectrum but with that many active channels there is no open frequencies. Hopefully the FRC/FTC(NXT) interference can be minimized by good floor planning. Maybe the WiFi will run in Bluetooth friendly mode.
Robot Inspector
Unread 21-07-2008, 09:35
greendog99's Avatar
greendog99 greendog99 is offline
FRC #0388 (Maximum OZ)
greendog99 is on a distinguished road
Re: Bluetooth!?!
Yes it is true that Bluetooth would interfere with wifi at 2.4 ghz but if using 5ghz it would minimalize the problem
Ready to take on the next challenge!
Unread 21-07-2008, 09:52
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
Re: Bluetooth!?!
At IRI the FIRST rep told us the current wireless units they are testing are 802.11a so it would be in the 5ghz range.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 24-07-2008, 17:47
Roboj Roboj is offline
no team (National Instruments)
Roboj is an unknown quantity at this point
Re: Bluetooth!?!
Bluetooth is being used in the new FTC platform as the communication path to the robot. Maybe that's what you were hearing about.
http://firsttechchallenge.blogspot.c...-software.html
Unread 27-07-2008, 17:20
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
Re: Bluetooth!?!
That's what I remember hearing too.
Since the NI controller doesn't have a bluetooth receiver, would it be possible to put some kind of bluetooth-to-ethernet adapter on the operator interface to send the signals to the bot?
Save money with PriceWombat, a shopping comparison and price tracking tool (that I made!).
Check out my hobby electronics business!
My former robotics team: Huntington County 4-H Robotics
Unread 29-07-2008, 01:20
Arthur S's Avatar
Arthur S Arthur S is offline
FRC #0004 (Element)
Arthur S is on a distinguished road
Send a message via AIM to Arthur S
Re: Bluetooth!?!
i don't about blue tooth, but as long as there is wireless program transfer onto the robot, i am more than pleased. no more being yelled at or yelling at random people standing next to the robot to hit program and run from the robot.
all models are wrong, but some are useful.
-George E. P. Box
Unread 10-01-2009, 14:39
User
Smile Re: Bluetooth!?!
Ahh whew! thanks, I wanted to use the PS3 controller though
Two things:
Cake==lie;
GO TEAM Robocats!!!
VEX Bluetooth MRClark Programming 1 27-05-2008 14:19
Bluetooth replacement for programming cable? EHaskins Programming 13 26-07-2006 03:50
Adding Bluetooth to Vex Blacklight FIRST Tech Challenge 29 19-06-2006 14:57
BlueTooth Module To Rx Port ? firetrap FIRST Tech Challenge 1 27-09-2005 22:55
Bluetooth serial cable replacement seanwitte Technical Discussion 2 13-02-2004 17:25
