Go to Post ...if you don't ask, you won't get. - Billfred [more]
Unread 31-03-2008, 01:04
Aren_Hill's Avatar
Build Nifty Things
Re: pic: 1625's swerve module (better pic)
Originally Posted by A_Reed View Post
how is the lower plate supported? I know it used as a bearing surface, but it is sandwiched between plates or riding on small ball casters. I have always wondered how this work with swerve modules, I understand the rest of it but the lower support plate is the only gap in my limited knowledge of drive systems(I don't go into the kinematics...yet).
the bottom disc is simply supported by 4 tangential pieces of UMHW (ultra high molecular weight) plastic, that we keep white lithium grease on all the time to keep it slick. Rollers are more efficient but take longer to install and are heavier
A guy who likes robots.
Unread 31-03-2008, 03:21
Un Luchador's Avatar
Un Luchador Un Luchador is offline
Electricity is my pastime
AKA: Gustavo
FRC #2543 (TitanBot)
Team Role: Electrical
Un Luchador is an unknown quantity at this point
Send a message via MSN to Un Luchador
With such an effective drivetrain, it's no wonder you guys went undefeated at Colorado. I love the way you guys keep the robot chassis facing forward through the match, but still have the swerve function to put you back into position. That's very innovative.
Keep up the hard work and military-like competing guys.
Unread 31-03-2008, 06:29
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
That module looks very simular to our initial idea, except we were putting the motor/transy inside the module itself.
It's very nice looking =D
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 31-03-2008, 09:59
hillale's Avatar
hillale hillale is offline
Formerly a Winnovator
AKA: Alec Hill
FRC #3617 (Cold Logic)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
That's what we did last year, we had a cim mounted vertically through a dewalt on each of the modules. This coaxial design made maintenance much easier (though it has gone through 3 regionals and hasn't broken once). Here is a pic of our underbelly, http://www.chiefdelphi.com/media/photos/28596. I guess we don't have a closeup of the module from last year.
Unread 15-04-2008, 13:31
Aren_Hill's Avatar
Build Nifty Things
This guy weighs in at 2lbs 14oz and i coulda taken a couple more ounces out of the steel sprockets. Lighter than last years
Unread 15-04-2008, 16:42
in between teams
AKA: Luke Van Oort
Have you thought about going to aluminum drive sprockets to save a touch more weight?
This guy module weighs in at 2lbs 14oz
Is there a girl module?
Team 1219: 2009 - Mentor
Unread 15-04-2008, 17:37
CraigHickman
Posts: n/a
This guy module weighs in at 2lbs 14oz and i coulda taken a couple more ounces out of the steel sprockets. Lighter than last years
Hm, you should switch to Kevlar belting and aluminum pulleys. Then this setup would be truly frighteningly light. Out of curiosity, how many teeth does your steering sprocket have? I'm currently designing a bottom support crab, so I can finally post one that doesn't get hit with the "you're not supporting it right" complaint.
Unread 15-04-2008, 17:38
Aren_Hill's Avatar
Build Nifty Things
Yes i have but during the season i was too busy to find a supplier or someone to have them made.
Unread 22-07-2008, 16:58
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Aren, do you have a white paper on this, or at least a picture of the other side of this assembly showing the bevel gears?
I got to see this up close at IRI, & was very impressed.
Not only did it perform great on the field, but it was relatively lightweight for what it consists of.
I'm trying to convince my teammates to experiment with as many drive trains as possible over the summer with our upcoming test chassis, & want to show them this one as a great example of swerve assembly.
Unread 22-07-2008, 17:11
Aren_Hill's Avatar
Build Nifty Things
I myself do not own a camera, and if i did wouldn't have time to take pictures.
The module structure (alum parts) is almost all waterjetted parts, then welded onto a 3x3x1/8th wall tube that had bearings holes CNC'd into it.
it will have some revisions for next year if we continue to do swerve, such as better bearing support at the top. (right now 1/2" bearings are taking the thrust load....). I'm considering copying 148's wheels so we dont have to worry about retreading and steering the wheels would be easier
Unread 22-07-2008, 19:14
roboticWanderor's Avatar
roboticWanderor roboticWanderor is offline
Spark The Ancient
FRC #0418 (Purple Haze)
roboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant future
Originally Posted by Peter Matteson View Post
You're the only other team I've seen do welded tube construction wheels. I thought we were alone with that because everyong else seems to hog them out of a billet.
418 has been doing them for years, exept we use 1"x1/4" stock to make spokes instead of using plate. then we speed hole them to make them even lighter.
here is a cad of them i don't have a good picture.
pic: Team 148 Robowranglers: Swerve Module and Motors Brandon Martus Robot Showcase 27 24-02-2008 22:29
pic: 1625's arm control Aren_Hill Extra Discussion 9 15-10-2007 11:55
pic: stangs swerve module Aren_Hill Extra Discussion 8 23-04-2007 08:15
Swerve Module Question adlai Technical Discussion 8 03-04-2007 21:20
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
