Go to Post Someone tried throwing out a perfectly good fleece blanket! It even had the quadratic formula on it! WHY ON EARTH WOULD YOU THROW AWAY THE QUADRATIC FORMULA?? - Karibou [more]
Unread 23-06-2002, 22:27
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Try this instead - 4 big balls on top of 2 goals
Posted by Raul at 1/7/2001 11:08 PM EST
Engineer on team #111, Wildstang, from Rolling Meadows & Wheeling HS and Motorola.
In Reply to: 4 big balls on top of the goals
Posted by Peter VanWylen on 1/7/2001 2:57 PM EST:
We built a goal already. And guess what - if you lay the goal on its side, the wood base orients it with a PVC pipe in the middle on top such that it is impossible to balance the big balls on it. However, you could slide two goals together and create the bowling alley trough effect you were talking about.
Raul
: From reading the rules, I don't see that this is specifically prohibited. The rules say that big balls must not be supported by a robot, and that they must be on top of the goal.
: So, why not tip over the goal, and put 3 or 4 big balls on "top" of the goal, as it lies sideways -- like how they store bowling balls at a bowling alley. I'm guessing that as soon as I mention this possiblity, a rule will come out against it, but who knows.
: So, from reading the rules as it is, do people think that this is legal. If it is, it could dramatically change the strategy.
[IMG] code is Off
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Gus can put the big balls on the goals on the bridge!!! archiver 2001 0 24-06-2002 01:30
Team 188 Pictures - four big balls anyone? archiver 2001 6 24-06-2002 01:03
robot which can put balls on top of goals on bridge archiver 2001 4 24-06-2002 00:48
goals and balls Strath General Forum 0 14-02-2002 22:34
