Go to Post its kind of a bad idea to implement traction control when you have no traction in the first place. - Uberbots [more]
Unread 07-23-2008, 10:16 PM
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Need some help with forklifts
Hello Cd,
I was wondering what material did you use to pull your forklift mast up and down. Last year we used fishing line and that did not work very well. Can you please put a link to your material and we were thinking of using cable? Also could you include pics of your system.
Thanks,
Rc
R.C.
MadTown Robotics Team 1323
Unread 07-23-2008, 10:23 PM
Data Nerd
FRC #0079
Re: Need some help with forklifts
We didn't use a forklift but our feather was driven by steel cable which might be an option for you. Word of warning if it has plastic coating on it that will peel off LONG before the cable fails so you may want to strip it off in the part you use to secure it down. We were useless an entire match due to striping that plastic off and not being able to raise our elevator which covered our shooter.
Unread 07-23-2008, 10:25 PM
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
We used 3/32" diameter uncoated steel cable for all stages of our lift. We initially worked with 150 lbs. test fishing line, but it stretched far too much to be useful.
--Madison--
...down at the Ozdust!
Unread 07-23-2008, 10:26 PM
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Originally Posted by rc_cola1323 View Post
Hello Cd,
Thanks,
Rc
228 has used 25 pitch roller chain on our 2007 elevator and Spectra cable on our 2005 elevator.
I'd also like to work on a design that uses timing belts sometime.
Art Dutra IV
世上无难事,只怕有心人.
Unread 07-23-2008, 10:40 PM
R.C.'s Avatar
Do you have links of where I can buy these products, thanks guys for your help.
R.C.
Unread 07-23-2008, 11:09 PM
run the trap!!!
Team Role: Human Player
Two #25 roller chains for first segment.
Two 1/16" steel cables from ACE Hardware for the carriage segment. We never broke or stretched these cheap cables. They had springs attached to one end that allowed them to stretch when the carriage reached the top.
Can't beat ACE!
Picture.
-Philip J. Fry
Unread 07-23-2008, 11:45 PM
artdutra04's Avatar
Look through "the usual sources": McMaster-Carr, MSC Direct, Grainger, or Small Parts.
25 pitch roller chain is easy to purchase, although Spectra (sometimes called Dyneema) cable is a bit harder to find. I prefer Spectra cable to steel cable; 7/64" Spectra cord has an ultimate breaking strength of above 1,000 pounds, it doesn't stretch any appreciable amount, and it's a lot lighter than steel cable at only 0.3 lbs per 100 feet. The only real downside is that it costs $1 per foot.
Art Dutra IV
世上无难事,只怕有心人.
Unread 07-23-2008, 11:56 PM
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I like spectra for a lot of things because it's so light, flexible, and relatively cheap, but we've discovered that it's pretty annoying for telescoping lifts and such. Spectra has pretty severe creep, which means that it slowly, permanently stretches when it's under load, especially a high load. So any lines that you pretension are inevitably going to get loose as the season progresses. I've since come to appreciate Vectran. It has a lower modulus than spectra, so it will stretch more under load, but it's approximately a heck of a lot more flexible and lighter than steel cable of similar breaking strength, and it has zero creep. Spectra is best purchased from kite shops:
A Wind of Change
Windstar Kites
Vectran lines are available at sailing shops:
Mauri Pro Sailing
EDIT:
Art, you're being taken advantage of if you're paying $1 a foot for spectra if you like it that much. See my links above. Buying in bulk should get you spectra for half that much.
Unread 07-24-2008, 12:07 AM
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
1251 had a lift system this year we used 1/16in thick steel cable and UHMW plastic pulleys with an 1/8th in grove to life our elevator up. The motors were the small and big banebot if my memory serves me corretly and don't quote me on this rs 440 and 550 combined in a custom gearbox. The material for the actual elevator was 2*1 1/8in wall box alumnium. 254/968 has a spool thats really cool its like spring tensioned. I'm sure Cory, Sanddrag or Travis can tell you more about it and where to get them. Some other notes about elevators don't put all the pneumatic lines thru igus on one side if you have more then 4 lines it doesn't work well and run as much line as you can inside then out of the elevator to keep everything out of the way. This will save you alot of dispair and grief during the competiton season.
http://www.chiefdelphi.com/forums/sh...=1251+robot+08
Hope that helps,
-Drew
Team 1251 The TechTigers
"Inspiring future innovators, one stripe at a time"
2004 Rookie All Star Orlando Regional
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
2013 South Florida Regional Winner
Last edited by techtiger1 : 07-24-2008 at 12:10 AM. Reason: link to robot pic for visual learners
Unread 07-24-2008, 12:24 AM
R.C.'s Avatar
Where did you get the cable from??? I'll have to ask Cory or if he could explain it here with some pics, that would be greatly appreciated.
R.C.
Unread 07-24-2008, 12:44 AM
artdutra04's Avatar
A Wind of Change
Windstar Kites
Mauri Pro Sailing
EDIT:
Thanks for those links.
I was never the person directly in charge of purchasing spectra cable when we've worked with it, and that's the price I was told. Maybe because we only bought enough for our elevator and a spare, or maybe because we should have shopped around some more. Whatever the case was, I'll be sure to keep my eyes open in the future when 190/228 purchase some.
Art Dutra IV
世上无难事,只怕有心人.
Unread 07-24-2008, 12:54 AM
AdamHeard's Avatar
Lead Mentor
I'd advise against spectra cable. Yes it is strong, but it doesn't take shock very well at all.
Unread 07-24-2008, 01:28 AM
NoahTheBoa's Avatar
NoahTheBoa NoahTheBoa is offline
AKA: Noah Tomaszewski
FRC #0968 (RAWC)
NoahTheBoa has a spectacular aura aboutNoahTheBoa has a spectacular aura about
Send a message via AIM to NoahTheBoa
This past year we used 1/8" nylon rope on ours. I was skeptical about how well it would work out, but thankfully it held up and only began to fray recently. In 2005 we used steel cable to drive our parallel arm.
Unread 07-24-2008, 02:01 AM
Smaug's Avatar
Smaug Smaug is offline
FRC #0675 (Tech High Phantom Robotics)
Team Role: Electrical
Smaug is a jewel in the roughSmaug is a jewel in the roughSmaug is a jewel in the roughSmaug is a jewel in the rough
team 675 used #25 chain and # 15 chain to lift our two stage lift
If it isn't broken, Fix it till it is ~ Baker
Unread 07-24-2008, 07:18 AM
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
I don't remember the exact name of what we used, but I know it's some sailboat rope. I think like 1/8". We never had any problems with it. It didn't stretch much either. If you have a local West Marine, that's where we bought ours from. I tried finding it on their website, but I didn't find it.
This is probably pretty close: http://www.westmarine.com/webapp/wcs...$@#$@#$@# Num=11452
Our's is blue though, so it may be a different brand. Look at the breaking strength... 530lbs. That's a lot of trackballs.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Need some help with FIRST history? FIXIT Championship Event 5 04-25-2007 08:09 AM
need some help with piston coolguybigt Chit-Chat 1 04-03-2007 03:22 PM
Need some help with a ball launcher amateurrobotguy General Forum 5 02-05-2006 09:04 PM
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 09:46 PM
I need some help with scouting archiver 2001 18 06-24-2002 01:28 AM
