Go to Post But seriously? White paper.. CD.. upload.. You get what I'm sayin'! :) - Elgin Clock [more]
Unread 24-07-2008, 12:07
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rivet Nuts and Rivet Studs
These things are neat and I haven't heard much of their use on FIRST robots. Do any teams have experience using these on their machines? What do you perceive as the good and bad of them?
Rivet nuts and rivet studs require a special tool to install -- McMaster-Carr sells a hand-operated tool for about $100. They install like regular pop rivets, but are threaded on the inside or have a protruding stud.
I've been using them for some projects at work where we have blind holes and we can't cut access holes to reach hardware inside of tubes and the like. They're a bit expensive, but like PEM products, they eliminate the need for nuts or bolts in some locations.
Thoughts?
--Madison--
...down at the Ozdust!
Unread 24-07-2008, 12:14
acdcfan259's Avatar
acdcfan259 acdcfan259 is offline
Brainssss....
AKA: Jake Carroll
FRC #1027 (Mechatronic Maniacs)
Team Role: Driver
acdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond reputeacdcfan259 has a reputation beyond repute
Send a message via AIM to acdcfan259
Re: Rivet Nuts and Rivet Studs
We used them on this years robot. We had bad experiences with them. I know they fell out and had to be replaced. I think we eventually ended up coming up with a different solution (to whatever the problem was, I forgot).
Unread 24-07-2008, 12:45
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
We've used nutserts in the past... are they the same thing? We used them to mount our AM transmisions and didn't have any problems whatsoever. You can spot them in this picture. (that's our 2007 robot, I don't recall any being on the 2008 robot)
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Team 118 used them all over their bot. Perhaps they can chime in on their experience.
If its good enough for NASA its good enough for me!
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 24-07-2008, 15:08
I started using them many years ago. I needed to add hardware to a leaky (RF) transmitter to get the second harmonic down. (A Hot Water 101 for those of you who remember back that far.) The nurling that is formed when the hand tool is used proved to be perfect for making contact between the covers and the chassis. The real trick, just like PEMs is to use the right size drill bit. As I remember, McMaster has both aluminum and steel.
Unread 24-07-2008, 15:27
Gary B.'s Avatar
Gary B. Gary B. is offline
FRC #0692 (The Fembots)
Gary B. has a spectacular aura aboutGary B. has a spectacular aura about
We have used them in the past with fairly good results; especially for light duty. They work well for blind locations as you mentioned and in thin material where you can't tap a hole. If your application is light, harbor freight has an assortment pack for ~$10 which is much more expensive than rivets. But if you are planning for a connection that you can remove without having to drill it out each time, they can be quite useful.
http://www.harborfreight.com/cpi/cta...temnumber=2972
Unread 24-07-2008, 16:24
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
We've used a couple of riv-nuts here and there.
I really like them and think they are a fantastic idea. They can be especially useful when mounting something to thin-walled tubing. The tubing wont get crushed if you tighten the bolt too hard. I feel like any situation where a riv-nut is possible, it should be used because why worry about a nut and a bolt when you could just worry about the bolt?
Of course, because of the flange, you wont want to use them when you want the two parts to be flush.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 24-07-2008, 19:24
Billfred's Avatar
Billfred Billfred is online now
1293 used them in 2006 to allow access into the ball elevator if need be. It was one of the few parts of the shooting mechanism that worked well. There wasn't much load on the rivet nuts, but they were just what we needed for the application. 1618 has the equipment to do them, but we have yet to have the right application.
Unread 24-07-2008, 20:39
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
We've never used them on 237's robots but we do use them on some of our plastic injection molding robots where I work. They are used on our smaller robots on the lighter duty axis to attach linear bearing rails and brackets.
The ones we have are ribbed on the outside so they "bite" in the hole as you tap them in place with a hammer. Hole size is critical as Al said, otherwise they won't grab. We don't use/have a tool to insert them. Once they are tapped in place the bearing rail is installed. As the screws are tightened the rivet nuts expand and hold in place for good. We use rib washers* and Loctite too, either 222 or 242, depending on the size of the screw. Vibration and loosening fastners is something we're very worried about with our equipment due to the constant movement of the robot and the press and even vibratory bowl feeders when used.
*Rib washers are these things. I've never seen them used anywhere before other than all of our equipment. Might be a European thing . Rib washers aren't anything you'll find at Home Depot or Lowes either. We never use regular split lock washers.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 24-07-2008, 22:20
DonRotolo's Avatar
Back to humble
FRC #0832
We used Rivnuts two years ago, but found they are really for light/moderate duty only. Anything subject to impact stresses, particularly in aluminum, will make them loosen.
Sure beats having to try to put a nut inside a piece of square tubing, 24 inches from the end...
Unread 27-07-2008, 00:19
Dick Linn's Avatar
no team (Synergy)
There are any number of "rivet" type inserts and studs and fasteners that have very good application possibilities. This is especially true for high speed assembly of mass-produced commercial products where labor costs are high. If you don't mind going out and fund-raising to get the $$$ to buy some of the (sometimes) required insertion tools, great. To my mind, they are great for fastening thin panels where you have no access to the back, and not enough thickness to tap a hole. They do prevent a loose nut from going missing in electronic components as well.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 27-07-2008, 22:53
MasonMM's Avatar
MasonMM MasonMM is offline
AKA: Mason Markee
FRC #0118 (Robonauts)
MasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond repute
We had good success this year using 10-32 aluminum rivet nuts mounted into 1/8" and 1/16" box aluminum. We put a fairly large load on them when we attached our upper body to the lower body through just 4 of these. Its loose now after a season of wear, but still holds the 'bot together.
We did have problems when using locktite to hold the threads though. The rivet nut would slip in its hole before the locktite would break when trying to remove a bolt, causing the rivet nut to just spin freely. The only way we found to remove it then was to clamp the two surfaces together, putting more pressure on the flange of the rivet nut and thus holding it in place enough to remove the bolt.
In a non-FIRST robot, I have had problems with rivet nuts rattling loose in serious off-road conditions, but this shouldn't be a problem when rolling on carpet as long as your initial hole is the correct size (just like others have said).
Unread 29-07-2008, 15:21
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
I used about a dozen 1/4-20 nut rivets on this year's robot for mounting chain tensioners and mechanical stops to our arm. It was my first experience using them, and it worked quite well. Both applications were places where we had a large tube with wires inside, which I could not (or did not want to attempt) to drill a through-hole in. They were very light-duty applications, as any forces would be applied parallel the bolt, in an inward direction. I would not use them in any situation where the bolt could conceivably be pulled out, or where a significant moment could be applied. They're just not that durable, and the aluminum ones in particular can strip very easily.
Jeff Waegelin
Unread 29-07-2008, 23:42
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Team 980 uses Riv-Nuts where we rather not just use a rivet. If you use them, you won't have to deal with nuts that fall into the least accessible places on the robot.
When we want easy access under a lexan panel, we'll use Riv-nut/fastener combos there.
Try 'm, you'll like 'm!
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 30-07-2008, 00:57
JM987's Avatar
JM987 JM987 is offline
High Rollers
AKA: Josh Mauro
FRC #0987 (High Rollers)
Team Role: Driver
JM987 has a spectacular aura aboutJM987 has a spectacular aura aboutJM987 has a spectacular aura about
Send a message via Yahoo to JM987
our team uses rivets to attatch our wheel tread to our drive wheels.
we also use them on the roller wheels at the end of our claw.
Check Out Our Website!
HERE!
- 2009 Las Vegas Regional Winners (thanks to 1622 and 1013)
- 2009 Las Vegas Regional Chairman's Award Winner
- 2008 IRI Winners (thanks to 330, 67, and 68)
- 2008 Archimedes Division Finalists
- 2008 Las Vegas Regional Chairman's Award Winner
- 2008 Las Vegas Regional Winners (thanks to 39 and 1013)
- 2008 San Diego Regional Finalists
- 2007 FRC World Champions (Atlanta thanks to 190 and 177)
- 2007 Newton Division Winner
- 2006 Las Vegas Regional Winner
- 2005 Las Vegas Regional Winner
Ribbit Rivet... DonRotolo Technical Discussion 39 17-03-2008 18:12
Acme Threaded Rods and Studs Arkorobotics Technical Discussion 6 01-02-2007 16:48
pic: Lightning Robotics Pop Rivet logo Joe J. Extra Discussion 4 02-07-2006 19:18
Slotted Nuts and Shifting sanddrag Technical Discussion 6 07-03-2004 13:04
Screws, Nuts and Bolts.... archiver 2001 10 23-06-2002 23:32
