Go to Post The problem was too many penalties with too much room for judgment. - dbSparx [more]
Unread 24-07-2008, 15:08
Re: Rivet Nuts and Rivet Studs
I started using them many years ago. I needed to add hardware to a leaky (RF) transmitter to get the second harmonic down. (A Hot Water 101 for those of you who remember back that far.) The nurling that is formed when the hand tool is used proved to be perfect for making contact between the covers and the chassis. The real trick, just like PEMs is to use the right size drill bit. As I remember, McMaster has both aluminum and steel.
Unread 24-07-2008, 15:27
Gary B.'s Avatar
Gary B. Gary B. is offline
FRC #0692 (The Fembots)
Gary B. has a spectacular aura aboutGary B. has a spectacular aura about
We have used them in the past with fairly good results; especially for light duty. They work well for blind locations as you mentioned and in thin material where you can't tap a hole. If your application is light, harbor freight has an assortment pack for ~$10 which is much more expensive than rivets. But if you are planning for a connection that you can remove without having to drill it out each time, they can be quite useful.
http://www.harborfreight.com/cpi/cta...temnumber=2972
Unread 24-07-2008, 16:24
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
We've used a couple of riv-nuts here and there.
I really like them and think they are a fantastic idea. They can be especially useful when mounting something to thin-walled tubing. The tubing wont get crushed if you tighten the bolt too hard. I feel like any situation where a riv-nut is possible, it should be used because why worry about a nut and a bolt when you could just worry about the bolt?
Of course, because of the flange, you wont want to use them when you want the two parts to be flush.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 24-07-2008, 19:24
Billfred's Avatar
Billfred Billfred is online now
1293 used them in 2006 to allow access into the ball elevator if need be. It was one of the few parts of the shooting mechanism that worked well. There wasn't much load on the rivet nuts, but they were just what we needed for the application. 1618 has the equipment to do them, but we have yet to have the right application.
Unread 24-07-2008, 20:39
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
We've never used them on 237's robots but we do use them on some of our plastic injection molding robots where I work. They are used on our smaller robots on the lighter duty axis to attach linear bearing rails and brackets.
The ones we have are ribbed on the outside so they "bite" in the hole as you tap them in place with a hammer. Hole size is critical as Al said, otherwise they won't grab. We don't use/have a tool to insert them. Once they are tapped in place the bearing rail is installed. As the screws are tightened the rivet nuts expand and hold in place for good. We use rib washers* and Loctite too, either 222 or 242, depending on the size of the screw. Vibration and loosening fastners is something we're very worried about with our equipment due to the constant movement of the robot and the press and even vibratory bowl feeders when used.
*Rib washers are these things. I've never seen them used anywhere before other than all of our equipment. Might be a European thing . Rib washers aren't anything you'll find at Home Depot or Lowes either. We never use regular split lock washers.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 24-07-2008, 22:20
DonRotolo's Avatar
Back to humble
FRC #0832
We used Rivnuts two years ago, but found they are really for light/moderate duty only. Anything subject to impact stresses, particularly in aluminum, will make them loosen.
Sure beats having to try to put a nut inside a piece of square tubing, 24 inches from the end...
Unread 27-07-2008, 00:19
Dick Linn's Avatar
no team (Synergy)
There are any number of "rivet" type inserts and studs and fasteners that have very good application possibilities. This is especially true for high speed assembly of mass-produced commercial products where labor costs are high. If you don't mind going out and fund-raising to get the $$$ to buy some of the (sometimes) required insertion tools, great. To my mind, they are great for fastening thin panels where you have no access to the back, and not enough thickness to tap a hole. They do prevent a loose nut from going missing in electronic components as well.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Ribbit Rivet... DonRotolo Technical Discussion 39 17-03-2008 18:12
Acme Threaded Rods and Studs Arkorobotics Technical Discussion 6 01-02-2007 16:48
pic: Lightning Robotics Pop Rivet logo Joe J. Extra Discussion 4 02-07-2006 19:18
Slotted Nuts and Shifting sanddrag Technical Discussion 6 07-03-2004 13:04
Screws, Nuts and Bolts.... archiver 2001 10 23-06-2002 23:32
