Go to Post Our behavior – both good and bad – is contagious. Set a good example, behave in a mature, reasoned, professional manner and we will find that others around us will too. - dlavery [more]
Unread 24-07-2008, 22:55
dbell dbell is offline
Mentor for team#3937 (Breakaway!)
AKA: David Bell
FRC #1519 (Mechanical Mayhem)
dbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to behold
pic: drive base idea
Unread 24-07-2008, 22:57
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
Re: pic: drive base idea
I am guessing by the looks this will be 2WD right?
Also, will your actual frame material be 80/20? This would definitely be a good base to use that with.
How thick plate do you plan to use for the bearing mounts for the front and rear wheels?
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 24-07-2008, 23:03
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Well... it doesn't necessarily have to be 2WD. The front and back wheels could just be on dead axels. I thought of a chassis and drive train that work like that, as well.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 24-07-2008, 23:07
cooker52's Avatar
cooker52 cooker52 is offline
Cookie
AKA: Seth Cook
FRC #4272
cooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant future
Send a message via AIM to cooker52
Dead Axles? Never heard of that before...
If it is going to be a two wheel drive, may I suggest you use omni wheels on the corner wheels. This will improve your maneuverability greatly and prevent that skip the robot has everytime you turn.
It's looking pretty good. When do you think you will be having more of it done?
I will never be able to leave 1501. Trust me, I did and I came back.
“If you worried about falling off the bike, you’d never get on.” Lance Armstrong
Monocoque, what a beautiful thing.
Unread 24-07-2008, 23:10
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
That's cool DB, i was thinking about what it would be like if we turned the center wheel drive we had upside down. And what center wheels are those, they don't look like what we have?
1058 PVC Pirates 2016 - xxxx
Unread 24-07-2008, 23:14
Tapoore's Avatar
Tapoore Tapoore is offline
AKA: Tom Poore
Tapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of light
I believe that they are actually "poor man's" omnis (regular KOP wheels covered with pool hose so they can slide sideways easily)... Although I was hoping to get away from using them
- www.mechanicalmayhem.org -
* 2015 Granite State District Event Champions
* 2013 Einstein Finalists
* 2006, 2010, 2011 Granite State Regional Champions, 2009 Chairman's Award
* 2012, 2013 North Carolina Champions
Unread 24-07-2008, 23:15
Bearings are in the wheel and sprockets are mounted directly to the wheel. The shaft doesn't spin. Dead and live axels have their advantages. If you do dead axels right, you can just remove to bolts holding it in place and the shaft can just move out of the way, making wheel replacement very easy.
What 1519 has done in the past is cut vacuum tube and zip-tie it to the corner wheels. They still get a bit of forward traction, but it greatly reduces the side scrub.
Unread 24-07-2008, 23:16
AKA: Brendan Browne
But aren't they cheaper and don't they turn easier than omis??? But then again, we can always use something with more quality.
Unread 24-07-2008, 23:59
phr34kR's Avatar
phr34kR phr34kR is offline
AKA: electrical/mechanical/Pneumatics
no team (symbiOHSis)
phr34kR is an unknown quantity at this point
Send a message via MSN to phr34kR
Hi, I was wondering for a 2wd with six wheels can you lower the two centre wheels as you do with six wheel drives and is this anymore effective than omni wheels (or improvised ones).
Tim
YAY won 6 out of 8 New Zealand VEX competitions!(and only killed Three servos in the process)
at least we made the semis
Its not a hole its a controlled leak...
Winners of the New Zealand excellence award (yay going to Dallas)
Unread 25-07-2008, 00:14
Tim
You can lower the center wheels on any 6WD. Now, if those are not the driving wheels, you may as well do a 4WD setup, but that's beside the point. It's pretty effective, but both methods (6WD "drop" style and 6WD coplanar, which has the omni wheels at the corners) have their fans. You'll want to experiment to find out which is better.
I'd also suggest powering more than two wheels.
Unread 25-07-2008, 00:50
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Although the normal KOP chassis is setup this way, I would avoid using the current configuration. A corner hit on the chassis can easily warp the frame out of alignment. Adding crossbars (making an X in the middle of the frame) or using round tubing instead of square tubing linking the left and right sides will greatly strengthen your frame. Of course, you will have an upper frame and bumpers to help out, but with a little effort, this could save you a lot of time at competition.
We have been using a square outer rail and middle round tubing for the past 4 years, and we've never had a frame issue. It was well abused at IRI and it only came back home with some small dents.
Round tubing is structurally stronger than squared tubing, and you cannot torque it very much without breaking a weld.
Before everyone says that the KOP frame is very tough, I want to say that this is my personal opinion and I do not want to discourage the use of the KOP frame. I personally like custom frames with round tubing. Auto manufactures use it for a reason, and so do many teams. I would love to hear some input on this as well.
For the wheel setup... If you drop the center wheel about 1/8th of an inch, you shouldn't need omni wheels on the outer corners. We've never had issues turning. Actually this year it turned too much. As for the dead axles... I assume you mean that the axles don't spin, but you have a sprocket bolted to the wheel that spin on the axle. If that is so, we did exactly that this year and didn't have any issues... actually, we have done this for the past 4 years. Our base design has stayed mostly the same with improvements each year. This year we identified a problem with using roll pins, and having them shear, so we're probably going to use larger ones next year or come up with a better way to attach the wheel to the shaft. We're also looking into stronger chain. We were pushing the limits of the #25 chain.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 25-07-2008, 08:42
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Maybe not on all 4 corners though. Some teams have had problems in the past (us, for example) with controlling our robot by having a six wheel drive with 4 omni's. 2 omni's would probably be ideal, either on the front or in opposite corners. I'd also suggest powering at least the rear part of your drive, throw a sprocket and chain on that bad boy and you'd be good to go.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 25-07-2008, 09:09
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
This guy brings up some good points. One other thing to keep in mind is if it is a flat game or not. Omni's on both ends weren't terribly freindly for climbing ramps (06, 07). Also if only the middle wheels are powered, it is really easy to get the robot stuck if the front or rear gets propped up a little. Many center only powered robots experienced this phenomenom this year with the bumps created by the inner wall supports (08).
As the drove over the bump it lifted the inside drive wheel off the ground and the machine then swerved directly into the wall. From the stands it looked like poor driving. In reality it was just a little vehicle dynamics issue.
I have another thread going on 6WD dynamics. There is a good link to a paper that explains making your robot turn. My recommendation would be power to at least 4 wheels or have your powered wheels at 1 end of the chassis. This brings a whole new set of dynamics issues though (whip oversteer).
Unread 25-07-2008, 11:12
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
http://www.chiefdelphi.com/media/papers/1443
Mark
Brick walls are for other people. - Randy Pausch
Unread 25-07-2008, 11:46
AKA: David Bell
Thanks to everyone for their comments.
Somehow the description didn't get posted when i uploaded the picture. What you see weighs 19 lbs. I haven't decided what gearboxes to use, but i have AM toughboxes or DeWalts in mind. The frame is 1x1x3/16 square tube, and will be welded.
Yes, Only the 2 center wheels are powered.
I was not planning on using 80-20 because it would make it heavier than i want this design to be.
The angle aluminum that supports the axles is 3/16 inch thick.
InfernoX14 explained dead axles.
Do you mean done in CAD, or built?
I will probably continue CAD of this design and similar ones until 2009. I don't know when i'll be 'done'.
To answer the comments about 6wd vs 2wd:
This drive base design was meant to be simple and light. Part of meeting this goal meant not powering the corner wheels.
For 3 out of the past 4 years, 1519 has used a 2wd drive, powering the center wheels only.
We have had good success with this design. The only drawback of this drive system is, like IKE points out, it cant climb ramps.
I like 6wd, but this design is meant to be the simple, light, stick-with-what-we-know design.
They are custom 6 inch aluminum wheels with roughtop or similar tread material.
They are 'poor mans omnis'. I'd like to get away from using them too, as are heavy.
Poor mans omnis are a lot cheaper than regular omni wheels, and they slide laterally very well, but not better than omnis.
Ryan, thanks for your advice about torquing the frame. Where would you recommend putting the round tube?
Comments are welcome
DB
pic: DeWalt drive base dbell Extra Discussion 16 18-09-2007 17:10
pic: 114 drive base CAD CraigHickman Extra Discussion 4 15-12-2006 00:31
pic: 195 Drive Base Tom Bottiglieri Robot Showcase 24 16-02-2006 12:50
pic: 254 completed drive base CD47-Bot Robot Showcase 1 26-02-2004 16:34
pic: 1083 drive base CD47-Bot Robot Showcase 11 24-02-2004 14:04
