Go to Post I'll just be happy if they give us a great game. - Koko Ed [more]
Go Back   Chief Delphi > Competition > FRC Game Design
Unread 22-07-2008, 20:00
Round Robin on Einstein
I think it would be great if the tournament structure on Einstein was changed to incorporate a round robin portion. I think the following structure would be an improvement on Einstein:
Have the first round be round robin. Each team plays every other team once. The two teams with the best record then play best 2 of 3 for the championship. This would require 6 matches to get through the round robin part and an additional 2 or 3 matches to crown the champion.
The biggest advantage of this system is everyone is guaranteed 3 matches (up from 2 under the current system). Since these games often play out like rock-paper-scissors, it allows each of the teams a chance to show off all their strategies. The alliances that have made it to Einstein have worked hard and deserve the chance to show everything they have, in front of the entire audience. It can be very disappointing to go out there and lose two quick matches and be done.
Another advantage is that this might make scheduling easier for FIRST. Under the current system, there are a minimum of 6 matches to play and a maximum of 9. With the round robin plan, there are a minimum of 8 matches, and a maximum of 9, which should make things more consistent year to year and easier to plan.
Here's how I think it would play out this past year.
Newton beats Galileo (like they did in the first match)
Curie beats Archimedes (like they did in the first match)
Newton beats Curie (guess)
Galileo beats Archimedes (guess)
Newton beats Archimedes (guess)
Galileo beats Curie (like they did in the finals)
Since there are awards between the matches, you wouldn't have to worry about turnaround time.
At the end, Newton has a 3-0 record and Galileo has a 2-1 record, and then play best 2 out of three. Both alliances have now seen a lot more of the other alliance and can better plan, plus you have the best two meeting for the championship, rather then in the semifinals.
About the only disadvantage that I can think of is the GDC would have to figure out a way to break ties. This could happen if there were 3 2-1 teams and a 0-3 team. An easy way would be the most points scored followed by the least points allowed, similar to the way the do it in soccer.
Unread 22-07-2008, 21:35
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Round Robin on Einstein
I like it, for the reasons stated.
Of course, you mean "alliances" and not "teams", but I understand the point.
Unread 24-07-2008, 17:06
Graham Donaldson's Avatar
Graham Donaldson Graham Donaldson is offline
AKA: Graham Donaldson
FRC #1676 (The Pascack Pi-oneers)
Graham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant future
I like it as well. For example, if we look at this year, alliances facing Galileo had very little chance of beating them 2 of 3. Suppose that the field Galileo faces in the semi's (I forget which) is better than either of the remaining two, yet does not get to play in the finals because they were forced to play Galileo.
A minor point, to be sure, but just another reason to change the system. If it works smoothly enough, maybe FIRST would considering expanding it to field playoffs, and even regionals, however unlikely in the near future.
2008 NJ Regional, 2009 Palmetto Regional: Chairman's Award Winners
2010 NJ Regional Champions (w/ 25 and 3059), 2010 VA Regional Champions (w/ 1086 & 1418)
"Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all."- Sam Ewing
"Opportunity is missed by most people because it is dressed in overalls and looks like work."- Thomas Edison
Unread 24-07-2008, 17:10
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
I like this also, maybe 1114, 217, and 148 might of lost this season to 233, 968, 60 in the finals???
R.C.
MadTown Robotics Team 1323
Unread 24-07-2008, 17:17
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I agree with Joe. The last two years, the two best alliances faced each other in the Einstein semi finals. The finals were almost anticlimactic, in some ways. I would greatly prefer this method. It would produce a more deserving champion, rather than having one alliance make it to the finals by playing a weaker division.
2001-2004: Team 100
2006-Present: Team 254
Unread 24-07-2008, 20:47
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Yeah, I really like this idea.
Plus, who cares if the matches on Einstein go on longer? They're awesome matches to watch!
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 24-07-2008, 20:56
Best Available Data
FRC #1778 (Chill Out!)
I assume you mean finalist? Wouldn't the champion be the same irregardless? That said, I think this model probably needs to tested before FIRST would adopt it. It's a pretty large change strategically, as scouting teams now need information on 3 other alliances, rather than one. I'd imagine that would create even more stress in what is already a stressful time.
That said, I think it would make for a more interesting final field, because their always seems to be unexciting matches on Einstein, and this way we should get more even (and thus more exciting) matches.
So, would an off season be willing to test this with their final four? IRI would've been a very interesting trial of this.
Unread 24-07-2008, 21:00
Cory's Avatar
AKA: Cory McBride
I meant both, really.
2001-2004: Team 100
Unread 24-07-2008, 21:20
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
I would figure many teams would do what SparX did in 2004 and 2006 when they were on Einstein. We would acquire scouting from other teams in each division on the robots coming form each division. So this change would not have much a problem for most teams that do this type of scouting.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 24-07-2008, 21:25
It is hard to play someone you've never seen before. However, I don't think this is any worse then the current system in that regard.
You'd play one alliance in which you don't have any information. Before you had your second match, you'd see the other two alliances play, so you'd have information.
As long as the rotation was set a head of time, it shouldn't be a problem. In fact, with the current system, it seems like there is a lot of confusion over who plays who first.
We've done the same thing when we were on Einstein.
Unread 24-07-2008, 21:35
tennispro9911 tennispro9911 is offline
Alumni
AKA: Matt
FRC #2053 (TigerTronics)
tennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to behold
Send a message via AIM to tennispro9911
For the sake of playing devil's advocake.
First of all, if it isn't broken, don't fix it.
I do agree that sometimes certain fields produce better winning alliances than others, but all 4 alliances on Einstein are still good enough to beat any of the other ones in a given match. It may seem to be an assured victory, but we know that nothing is ever impossible, especially from an alliance that has already won on a field.
Robots will break. I know that teams need to build robust robots, but things happen. Those robots have already played 2 or so matches in qualifying, 3 rounds to win thier field, and now you're asking them to play another 4 rounds on Einstein. 23 matches in a day is a lot for any team and any robot.
Ties. Matchups matter a lot. Matchups mean everything especially because of defense. A beats B which beats C which beats A. With close matches, this will happen a fair amount. I'd bet at least every other year you are going to have a tie, which means you need to be able to break the tie.
Can anyone think of a truely fair tiebreaker? Head-to-Head is great, but doesn't work for a 3 way tie. Points scored? ... doesn't account for defensive powerhouses. Point differential? ... much better, and this would work well in a game that is scored like this game, but in a game that is scored exponentially like 2007 and others, that can be hugely skewed by one match that an alliance scores say 128 points. Even point differential can be hugely misleading.
Also, I know no alliance would ever tank a match or anything like that, but you also can create the situation where one alliance is up 2-0 and guarenteed a spot in the finals, and another is down 0-2, and already eliminated. You make it so that a match (or two) could be played that doesn't have any chance of affecting the standings.
That said, I love the idea. I think it would be great. I'm mainly pointing out possible flaws/weaknesses so that the idea can be strengthened.
2053 Alumni
Unread 24-07-2008, 22:14
Actually, I think it's to reduce the number of matches that might need to be played. And yes, we care if they run long! Team Social (or whatever it's called) is calling, and we want our share. But we can't get it unless we leave early and miss matches. Also, NASA TV broadcasts the finals--but ends coverage before the matches end. Why? Schedule! If it's more consistent, then it'll be easier to figure out when you can switch to something else--if you're early, you can end early.
I like the idea too.
As for "if it isn't broken, don't fix it", the engineer has two counters for that. One is "If it isn't broken, it doesn't have enough features" and the other is "If it isn't broken, fix it 'till it is".
Unread 24-07-2008, 22:32
If we stuck by that saying, then we might not have that thing called evolution and innovation
I like the idea.
Unread 24-07-2008, 23:15
Cory's Avatar
AKA: Cory McBride
For the record, NASA knows that the event will never end on time. FIRST's refusal to modify the schedule to accurately reflect the end time is the reason why coverage is cut short.
2001-2004: Team 100
Unread 25-07-2008, 06:29
Koko Ed's Avatar
Koko Ed Koko Ed is online now
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
It's not the fault of the competition itself. It's the endless parade of people giving speeches, which kills me because people have been complaining about too many speeches going on for too long for years! So what's FIRSTs response? Get more speakers! Way to know your audience guys!
Einstein Pavan Dave Rules/Strategy 5 26-04-2007 23:14
EINSTEIN windup zeppelin Championship Event 96 30-04-2006 23:39
pic: Swing yer parders round n' round! Koko Ed Extra Discussion 8 26-05-2005 13:07
And the Wheel Goes 'Round and 'Round Rick TYler Technical Discussion 16 09-03-2005 17:50
Batman and Robin and Segway at Six Flags! Aignam Dean Kamen's Inventions 9 16-08-2004 00:30
