Go to Post your robot may have a bit of a "pimpwalk" - GMKlenklen [more]
Unread 23-06-2002, 22:28
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: size of see saw?
Posted by Ryan at 1/7/2001 9:26 PM EST
Student on team #30, Fury, from High Technology High School and CelWave.
In Reply to: size of see saw?
Posted by nick237 on 1/7/2001 5:15 PM EST:
: The sizes of 8' x 4' for the see saw ramp is on the drawing but the hight is not. there is 2" angle 6" apart but no sizes for the hight from the floor to the top flat surface of the ramp carpet when level.
: can anyone help??? and where did you see the answer.
: nick237
if you do some trigonemtery, i believe at the exact midpoint of the see-saw it will be approximately 11.9" aboe the ground. Try it, im probabbly wrong. Use 92" (8') as the hypotenuse, and 24" (2') as the vertical leg of the big triangle. Using trig you get the angle of the large triangle, and the horizontal leg. Divide 92" by 2 to get the midpoint, or the vertex of your smaller triangle (this is the point directly above the ground). Using the same angle, i got 11.9" as my vertical leg. I'm probablly wrong. Oh well another wasted year of highschool math.
-Rc
[IMG] code is Off
What size monitor do you use? Elgin Clock IT / Communications 30 10-03-2004 16:53
How to size threads on pneumo. parts indieFan Pneumatics 1 15-10-2003 08:02
Q&A Discuss: size CD47-Bot Extra Discussion 4 05-02-2003 21:33
Is there a size regulation for the pit area if we wanted to put up a banner Ragin_Kage General Forum 6 14-03-2002 15:33
A file size issue Funkymunkey90 3D Animation and Competition 2 05-02-2002 14:50
