Go to Post Don't waste the opportunity because you were too focused on "winning" the championship. - Don Wright [more]
Unread 25-07-2008, 13:27
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: pic: drive base idea
Originally Posted by dbell View Post
Yes, Only the 2 center wheels are powered.
To answer the comments about 6wd vs 2wd:
This drive base design was meant to be simple and light. Part of meeting this goal meant not powering the corner wheels.
For 3 out of the past 4 years, 1519 has used a 2wd drive, powering the center wheels only.
We have had good success with this design. The only drawback of this drive system is, like IKE points out, it cant climb ramps.
I like 6wd, but this design is meant to be the simple, light, stick-with-what-we-know design.
DB
I edited out a lot of your post, but I would like to challenge you that if you are spending the time to do an upfront design, figure out how to power at least 4 of those wheels. There are some extremely simple and cheap ways out there and then you will drive better and be able to climb ramps (or bumps).
We have excluded teams in the past (06, and 07) as picks for having only the center 2 wheels driven from our elimination selection list. If you need some pictures of how to get 2 more to drive, let me know and I will send them your way.
Unread 25-07-2008, 14:41
run the trap!!!
Team Role: Human Player
Who says there will be ramps next year.... or bumps... (or dry land for that matter)
On a more serious note... Is that a sprocket or a gear on the center wheel?
If you aren't gonna power the outer wheels why not get rid of chains all together and incorporate the wheel directly into the tranny?
What trannys are you planning to use anyways? The kit ones perhaps?
-Philip J. Fry
Unread 25-07-2008, 14:59
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Thanks to everyone for their comments.
Somehow the description didn't get posted when i uploaded the picture. What you see weighs 19 lbs. I haven't decided what gearboxes to use, but i have AM toughboxes or DeWalts in mind. The frame is 1x1x3/16 square tube, and will be welded.
I was not planning on using 80-20 because it would make it heavier than i want this design to be.
The angle aluminum that supports the axles is 3/16 inch thick.
InfernoX14 explained dead axles.
Do you mean done in CAD, or built?
I will probably continue CAD of this design and similar ones until 2009. I don't know when i'll be 'done'.
They are custom 6 inch aluminum wheels with roughtop or similar tread material.
They are 'poor mans omnis'. I'd like to get away from using them too, as are heavy.
Poor mans omnis are a lot cheaper than regular omni wheels, and they slide laterally very well, but not better than omnis.
Ryan, thanks for your advice about torquing the frame. Where would you recommend putting the round tube?
Comments are welcome
DB
I saw your request. I have go run some errands and then draw it up. Really, a few inches inside the frame will work. I'll try to autocad it up quickly.
EDIT: As promised, here is a drawing. Of course, you can move the tubes to wherever you want, but towards the ends makes it the strongest, however, having it on the very end may not be the best idea because your mechanism may not be able to work properly.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 25-07-2008, 16:30
dbell dbell is offline
Mentor for team#3937 (Breakaway!)
AKA: David Bell
FRC #1519 (Mechanical Mayhem)
dbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to behold
I agree, center wheel drive is limited because it cannot climb ramps. However in a game without such obstacles (eg. 2002, 2005, 2008) center wheel drive is fine. Other years, some teams have used a drive system that cannot negotiate obstacles, and have still done well. eg: cheesy poofs in 2004. They could hang on the bar without climbing the stairs.)
Figuring out how to power the corner wheels is not the issue. With a few more sprockets, some chain and moving the inner rails, i could have a 6wd. However, this design is not 6wd, its a design similar to what 1519 has used for 3 years.
I'd like to point out a few things
-We don't know the 2009 game and we don't know what kind of drive system will be best for this game.
-Both 6wd and center wheel drive have their advantages and disadvantages.
I'm planning on using either Dewalts or AM toughboxes.
Its a 36 tooth sprocket.
Interesting idea... To be honest, i didn't really think about a direct drive that way. Mounting the tranny output shaft to a wheel is easier said than done. Especially on the toughboxes. It would be pretty easy for something like the Banebots p80 long shaft. But because the toughboxes have such a short shaft, you would need an extension. something to think about.
With all the comments from everyone, I think i'll start working on another design...
DB
Unread 25-07-2008, 17:08
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
DB
AM makes an extended shaft for the supershifter. It actually wouldn't be too complicated at all to modify that shaft for a toughbox. If you want further info, download the cad files of both and look at how similar they are.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 25-07-2008, 19:06
AdamHeard's Avatar
Lead Mentor
We did that this year, a pretty simple operation to do on the lathe.
Unread 25-07-2008, 20:53
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Now, don't automatically go thinking that a lighter chassis is a better chassis.
I explained in another post that having a relatively heavy chassis isn't always a bad thing. It basically forces you to make a lighter manipulator, basically meaning that your CG will be closer to the ground.
For the past two years our chassis (...I've never used the plural form of chassis) have been in the range of 80-90 pounds. We haven't tipped once in those two years.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 25-07-2008, 21:43
REVving up for a new season
FRC #2848 (All-sparks)
Just a little lesson here.
1 x1 x 1/8" aluminum tubing weighs 0.5132 lbs per foot
1x1 80/20 weighs .5097lbs per foot
so in this case your design weights more than with 80/20 now this doesn't take into account the hardware weight. Also 1x1x 3/16" is not a common size for tubing typically it comes in 1/16 or 1/8"
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 26-07-2008, 11:11
AKA: David Bell
Thanks for the specs. I confirmed those weights here and here.
Thanks for pointing this out!
Now that i look at my CAD i realize i made a mistake. The square tubing is actually 1/8 thick, not 3/16. It was those dead axle angle brackets that are 3/16. My bad.
I guess i thought 8020 was heavier, and never bothered to weigh it. Although this design with 8020 weighs pretty much the same as a design with 1x1x1/8 tubing, the hardware is the killer. I was planning on TIG welding the square tubing frame, which adds only a very few ounces, and provides a very strong bond. the 8020 brackets are a little heavier. 12 of these brackets would weigh about 1 lb. and still probably wouldn't be as strong as a weld. Then again, a pound or two is a small price to pay for the ease of use that 8020 provides.
I'll certainly look into a direct drive for the super shifters and toughboxes.
I'm guessing this is the long shaft you were mentioning.
DB
pic: DeWalt drive base dbell Extra Discussion 16 18-09-2007 17:10
pic: 114 drive base CAD CraigHickman Extra Discussion 4 15-12-2006 00:31
pic: 195 Drive Base Tom Bottiglieri Robot Showcase 24 16-02-2006 12:50
pic: 254 completed drive base CD47-Bot Robot Showcase 1 26-02-2004 16:34
pic: 1083 drive base CD47-Bot Robot Showcase 11 24-02-2004 14:04
