Go to Post Unfortunately, you cannot always tell when some things are jokes on forums, because we only can rely on text and a limited number of smilies. - artdutra04 [more]
  #31   Spotlight this post!
Unread 16-07-2008, 11:57
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Is your frame tough enough for FIRST?
Let's see if I can get this in under the radar...
As soon as our prototype frame was completed with all components assembled, I intentionally ran it 10 fps into the concrete wall of the high school with no bumpers. Other than a ding on the outer aluminum frame at the impact points, everything was ok. Then for the production frame, we rearranged some of the 1" aluminum extrusion to allow for an open front. Again, the same quality assurance test was completed, but this time at 12fps and testing was only done on frontal impacts. The result was a small dent in the front exposed tubing, but nothing severe like we had our first year.
During front impacts of the competition season, these aluminum bars became more and more crushed, which leads me to believe they served as a crush zone that made up for the lack of bumpers. In hindsight I'm glad we had them because that meant there was less shock force delivered to the rest of the components. While I don't condone running full speed at a wall to test your frame, I definitely think quality assurance tests are quite helpful. Plus they make for great videos...
GitHub
  #32   Spotlight this post!
Unread 16-07-2008, 13:23
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Originally Posted by fuzzy1718 View Post
Everyone is talking about aluminum and plexiglas, does anyone use an all steel frame other than us?
We used Ultrasteel (thin-wall steel sheet, dimpled for added strength, bent by the manufacturer into 8"-wide C-channel) for our ramps in '07. It allowed us to make ramp panels with a very minimal aluminum frame underneath (strickly for hinge mounting). Worked great, plus it was easy to repair if it got bent--just hammer them out.
We usually use welded aluminum for our base frame. Using steel as a base frame would be too heavy--maybe small pieces to strengthen joints that aren't being welded.
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
  #33   Spotlight this post!
Unread 21-07-2008, 18:39
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Any link to the ultrasteel???
R.C.
MadTown Robotics Team 1323
  #34   Spotlight this post!
Unread 22-07-2008, 01:06
M. Mellott's Avatar
CAD God
AKA: Mike Mellott
http://www.dietrichindustries.com/ultrasteel/menu.asp
We had always wanted to use a locally-manufactured product on our robot to further gain community interest in our program and FIRST. A parent of one of our students works at Dietrich in Warren, OH and helped us aquire a supply of framing members.
  #35   Spotlight this post!
Unread 23-07-2008, 23:53
qnetjoe qnetjoe is offline
AKA: Joe Daily
qnetjoe is on a distinguished road
Send a message via AIM to qnetjoe Send a message via MSN to qnetjoe Send a message via Yahoo to qnetjoe
When it come to frames, your number one enemy is impulse (force x time). Even you most violent collision inside of first cam be modeled by
F = (2*(M*∆V))/t + M
So when design a frame you need to consider ways to maximize the time over which the impulse occurs. This reduces the force applied and thus the stress in the element. Bumper are just one method to reduce the total force acting on a frame. Rubber Cushioned Pillow Block are another.
I recommend using iso clipping inside of your cad package to check to see the effect that impulse has on your frame.
  #36   Spotlight this post!
Unread 24-07-2008, 11:22
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Originally Posted by Billfred View Post
For the good of the order (since I can't think of any such cases), what are those limited exceptions where acrylic is used? (1618 used it as side panels its rookie year, but wised up quickly following that.)
On our 2007 bot we used acrylic to hold omniwheels laterally in place since we could use a very thin sheet, had a laser cutter for it, and couldn't find any other fender washers that would do the job. Since they were omnis the acrylic never saw and force and we never had a piece shatter, even after we destroyed the wheels that were being held in place.
"History doesn't repeat itself - at best it sometimes rhymes" --Mark Twain
  #37   Spotlight this post!
Unread 25-07-2008, 23:05
R.C.'s Avatar
Does anyone have pics of their super cool frames???
R.C.
  #38   Spotlight this post!
Unread 26-07-2008, 02:15
Lions for First's Avatar
Lions for First Lions for First is offline
AKA: Devan
FRC #2365 (Lions Robotics)
Lions for First has a spectacular aura aboutLions for First has a spectacular aura aboutLions for First has a spectacular aura about
Send a message via AIM to Lions for First
http://www.phxhs.k12.az.us/images/pa..._id=1203612925
this was our frame
2008 AZ Regional: Highest Rookie Seed
5th seed alliance Cap.
Semi-finalists (thanks 125 and 842)
  #39   Spotlight this post!
Unread 26-07-2008, 03:33
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Going into the season this year we had a very pretty frame... but now that the season is over its not so pretty. We used 1/16 wall 1x1 tube for our frame. It held up pretty good for us all year. the bottom rails aren't so pretty anymore from robot arms and appendages getting under the bumpers and hitting the frame, also the bumpers were just high enough so if we accidentally hit the dividing wall in hybrid or teleop the bottom supports for the overpass would get under there and beat our frame up pretty bad... Ill have to see if i can get some pics of it tomorrow?!
  #40   Spotlight this post!
Unread 26-07-2008, 14:45
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Here's a photo of Team 190's 2008 base chassis. I's not a good general all-purpose frame; rather it was highly customized for our design strategy.
http://img142.imageshack.us/img142/7225/1003436io0.jpg
It's four motor (3 CIM, one Globe), 4WD drive (two custom omni, two Colsons). It's designed to allow our robot to drive right up against a wall, then drop the rPOD to scoot sideways into it, in order to position ourselves perfectly for our "unique" trackball strategy.
Art Dutra IV
世上无难事,只怕有心人.
  #41   Spotlight this post!
Unread 26-07-2008, 18:39
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
Cool Re: Is your frame tough enough for FIRST?
our robot's gyro freaked on us, and pushed a 250+ pound table that was not meant to move. It took two adults to just push it back! ... and the other day at the 4-H fair, we built a robot that you can ride on. the only kill switch that worked was on the actual bot itself (in the form of a breaker, the switch on the remote would only make it lose the signal.) We were unpacking our trailor, and i was using the bot to haul around crates (approximately a 100 lb. load ) when the gyro also freaked on us. It ended up taking out 2 and a half boothes. Luckily no one was there due to the fact that it was before the fair started.
I know you are thinking about why the kill switch on the remote did not work. it was because we were using a vex Robot Controller so it was never meant to operate on such a big scale.
  #42   Spotlight this post!
Unread 28-07-2008, 18:03
R.C.'s Avatar
Do you have any pics of the robot itself?
R.C.
  #43   Spotlight this post!
Unread 28-07-2008, 18:25
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
blue painted pultruded fiberglass channel, with a riveted on sheet aluminum bellypan and corner gussets.
http://photos.project1726.org/thumbnails.php?album=28
  #44   Spotlight this post!
Unread 29-07-2008, 13:52
Doctorwho's Avatar
Doctorwho Doctorwho is offline
FRC #0467
Doctorwho will become famous soon enoughDoctorwho will become famous soon enough
Team 467 Unibody Chassis. Although it has no real frame the unibody grants us an extremely light-weight and durable body.
Pics:
Construction:
http://www.team467.org/gallery/main...._itemId=511138
http://www.team467.org/gallery/main...._itemId=511236
Chassis with Skin attached:
http://www.team467.org/gallery/main...._itemId=512219
http://www.team467.org/gallery/main...._itemId=512201
http://www.team467.org/gallery/main...._itemId=512177
Final Product:
http://www.team467.org/gallery/main...._itemId=512353
http://www.team467.org/gallery/main...._itemId=512356
http://www.team467.org/gallery/main...._itemId=512365
  #45   Spotlight this post!
Unread 29-07-2008, 20:08
AKA: Samir Shaikh
FRC #4329
we call this the "Magic Carpet"
we built it in 3 days at the 4H fair using a vex controller. It was the one that took out the boothes. (it had heavy tubs on it at the time)
http://i213.photobucket.com/albums/c...picture048.jpg
And this is our 2008 robot. it was the one that pushed over the heavy table.
http://i213.photobucket.com/albums/c...8c5211e3fe.jpg
What is your frame weigh? RTTComanche17 General Forum 8 09-01-2008 11:05
Future of Education: Tough Choices or Tough Times Rich Kressly Math and Science 0 21-12-2006 09:10
pic: Tough cookkie frame Tytus Gerrish Extra Discussion 15 31-07-2006 12:48
pic: How heavy is your frame? rees2001 Robot Showcase 10 18-02-2005 22:38
