Go to Post If you can spare 2 minutes (And I know you can, because the season’s over and you’re STILL on Chief Delphi) - LVMastery [more]
Unread 27-07-2008, 20:22
kajeevan kajeevan is offline
FRC #0188 (blizzard)
kajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud of
Re: Need some help with forklifts
i know this is a lift tread but just on thing i want to bring up is that always consider arm before lift, always. proof of this is beachbot time and time again that simplicity kills all else. are team is finally making the transition and we already prototyped a strong fast arm for 09.
but to answer your question on materials we've been doing elevators every year expect for 06 and we've done custom lift frames to bosch (very expensive if your doing two). we've tried both spectra and steel cable. 1/8in steel cable uncoated works fine but the coated versions were a problem in terms of flexibility. spectra on the other hand is good if you take a lot of care in tensioning the it so it doesn't get cut up in anything. but my choice between the two would be steel cable. we used spectra on our lift this year and went through i believe 200f of the stuff. first spool had a breaking force of over a 100lbs and the other had breaking force of over 1500lbs. it was a bosch elevator forklift pulling up and gravity drop using 2 light senors for bottom and top limits so the spectra wouldn't come off the pulley. but the major problem would be spectra getting caught up every minute in the elevator because the string wouldn't tension at the same time that the elevator would drop. to keep string from getting caught in other areas we ended up using those key chain/card zippy things that act like tape measures pulling in. that had solved the problem most of the time. but if u want proof of elevator failer in action just watch some of our matches at waterloo you'll see the elevator go up and then get stuck either because it came of the pulley or getting caught.
but please please consider arm before elevator one because it'll take much less time to build second because its simple beyond belief and third its proven by 330.
Need some help with FIRST history? FIXIT Championship Event 5 25-04-2007 08:09
need some help with piston coolguybigt Chit-Chat 1 03-04-2007 15:22
Need some help with a ball launcher amateurrobotguy General Forum 5 05-02-2006 21:04
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
I need some help with scouting archiver 2001 18 24-06-2002 01:28
