Go to Post They hit us, we hit them, it happens. Build your robots to take a hit and it doesn't matter. - Greg Needel [more]
Unread 27-07-2008, 20:37
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Inventing a wireless button pushing device for a taxi driver
Introduction: I was called by our financial mentor at Team Fusion Saturday night and he told me one of his friends, that runs a taxi around the area, wanted me to make something. I, of course, said sure! I'm always open to a challenge. Anyway, the guy brought his taxi to my house today and I looked at what he needed.
He explained to me, when he gets a dispatch, the touchscreen computer in his taxi will beep, and he has to push the button within 10 seconds in order to take the dispatch. For the audio relay, he is using a simple baby monitor that will go to his house. However, finding a readily available wireless device to push the button for him is a bit more difficult. I already decided the easiest and simplest way to do this is to use a simple servo and an arm to mash the virtual button. Designing the whole mechanism seems like it will be pretty simple, but a bit tough to build. However, the problem I have now is deciding which micro-controller to use and how to wirelessly connect the servo to a button inside his house.
End of Introduction...
All right, so I have a few questions...
What is a cheap and effective way to connect any two micro-controllers to each other. I was looking at some Parallax radios, but they are pretty expensive.
What is a good, cheap micro-controller to use that I know how to program? (PBASIC and C just as good as programming our robots, so not totally fluent)
Also, I need to keep in mind to keep the power requirements down to a minimum. I believe it was a Ford van. I don't know if Ford's have always-on 12V receptacles or not, so I may have to come up with a way to use a battery in it that will have to last at least 12 hours.
So to sum it all up. I need a 2 cheap micro-controllers and radios that are capable of sending a signal to push a virtual button on a touch sceen. One set for inside the house (Transmitter) and one set for the car (Receiver). It all needs to be portable and power efficient. I plan on putting a transistor in to shut off the servo when not being used to cut down on the power a little bit.
I know this is all confusing, but some information or tips would be great.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 27-07-2008, 20:51
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Inventing a wireless button pushing device for a taxi driver
Look for a cheap transmitter/receiver with one servo for an r/c car, use the steering servo to mash the button.
Unread 27-07-2008, 21:16
jimbot's Avatar
jimbot jimbot is offline
FRC #2083
jimbot will become famous soon enoughjimbot will become famous soon enough
Would an r/c car transmitter have the range to reach from the house out to a car? Good call on the r/c car.
"Though similar in apperance, unlike a firecracker, dynamite should not be held in ones hand when lit. Ohhhh..."
Unread 27-07-2008, 21:28
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
I would use 2 PIC16F819 microcontrollers programmed in Picbasic(very similar to pbasic)
They would communicate with each other over a RF serial moduleLike this
The receiver side would just drive a servo
Unread 27-07-2008, 21:29
RyanN's Avatar
RyanN
It is a very good call, but I don't know the distances an R/C can can reach. It would probably be enough, but the transmitter will be way overkill for what this guy needs. I'm thinking I can get all the electronics and parts for like $120. I looked at towerhobbies.com and their cheapest transmitter was $52... receivers were almost $100.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 27-07-2008, 21:42
DonRotolo's Avatar
Back to humble
FRC #0832
You can get a really cheap R/C transmitter and 'vehicle' with at least one servo from Radio Shack for very cheap, maybe $30-40. If you optimize the antennas (position them parallel to each other, with minimal metal in between) 100 feet shouldn't be a problem.
Thinking outside the box, consider using wires. 100 feet or 24 gauge speaker wire is very cheap, make it weatherproof and as he gets into the taxi to actually drive to the call he can toss it out the window, awaiting his return. Or maybe protect it somehow, but the key is don't be afraid of wires - perhaps as an inexpensive test only... Press the button, a slow motor (or a weak solenoid) pushes a "finger" against the touchscreen. Power by wall wart, simple pushbutton, some kind of clip-on holder in the van...
Don
RyanN's Avatar
RyanN
Binome, the radios sound great! $10 for a transmitter and receiver. The micro-controller also looks good.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 27-07-2008, 22:02
RyanN's Avatar
RyanN
I'm looking at a PICAXE 8 Proto Kit. I can get the kit for $4.95 and the PIC for $3.95. Then the programming cable will be $6.95.
I'm also looking at PICBASIC. I see the "real" version is $100, but I found some other 3rd party alternatives. Any recommendations?
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 28-07-2008, 13:16
Chaos204's Avatar
Chaos204 Chaos204 is offline
AKA: Jordan
FRC #0204 (Eastern Robotic Vikings)
Chaos204 is on a distinguished road
Send a message via AIM to Chaos204
I am just throwing this out there to be careful of. if it is a touch screen make sure whatever you plan on poking it with will activate the screen. Some touch devices use heat others use capacitance, i am not an expert or anything but before you go out and buy stuff make sure it can be activated by a stylus or other non-finger poker.
2005 PARC FINALIST
with 84 and 176
E. R. V. is on its way
Unread 28-07-2008, 13:32
RyanN's Avatar
RyanN
Yep, already thought of that... It's physical force that activates it.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 28-07-2008, 14:26
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
I just read this thread and read you used the word mash for the pressing of the button. I would like to suggest some sort of a system(perhaps just some padding) to cushion the blow. Touch screens can be nice, but they can be fragile too. Try to make sure that you don't end up damaging the screen in the process of helping him. I know that isn't necessarily what advice you are looking for, it is just the best I can give.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 28-07-2008, 14:57
REVving up for a new season
FRC #2848 (All-sparks)
have you thought about something like this?
http://www.allelectronics.com/make-a...6-AMP/-/1.html
the range would be questionable but if the guy is fine with his baby monitor you could just use one of these with the controller attached to a 12v solenoid with a rubber finger mounted to press the button.
This could be a less than $50 solution with no microcontroller required.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 28-07-2008, 15:31
RyanN's Avatar
RyanN
That sounds like exactly what I'm looking for. Less work, and more professional looking. Thanks Greg!
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 28-07-2008, 16:12
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
I was going to suggest getting one of those and a power-lock solenoid from a junkyard. Put a nice cushy tip on the unlock knob and away you go.
Unread 28-07-2008, 22:29
Gdeaver Gdeaver is offline
FRC #1640
The solenoind from an old mechanical door bell has a rubber tip and takes little power. Good call on the all electronics part.
Driver Question for stacking clean399 Rules/Strategy 4 27-01-2007 21:44
Serial Driver and 2K6 Encoder Driver Not compatible Tom Bottiglieri Programming 6 12-02-2006 01:11
Ideas for using the NI USB-6009 DAQ device Andrew Schuetze National Instruments LabVIEW and Data Acquisition 0 05-01-2006 22:55
