Go to Post Well our closest regional is a Hawaii, it's a bit hard for us to drive 8000km (5000 miles) across the pacific... - timytamy [more]
Unread 27-07-2008, 23:56
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Adjustable Way of Dropping the Center Wheel
Well, every drivetrain created in FIRST is unique and different. I thought of a way to adjust the amount of drop in the center wheel.
The first drawing is the part of the frame, the second part is the adjustable part. The drop is an increment of 1/16". 1-16 to 1/4.
R.C.
MadTown Robotics Team 1323
Unread 28-07-2008, 00:01
REVving up for a new season
FRC #2848 (All-sparks)
Re: Adjustable Way of Dropping the Center Wheel
I really like your thought process here, and it is defiantly an interesting solution. The question I have is how often do you think you will have to change your center wheel displacement? Probably not very often during a competition but if this was for a development platform or practice bot I could see this coming in handy. Nice job.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 28-07-2008, 00:02
AdamHeard's Avatar
Lead Mentor
That's certainly one way to do it. I like it.
In 2007, 294's center wheel sat in a block on each side that was sitting in a slot. The bottom of each block was tapped, a bolt came up from the bottom of the frame into it. Tightening the bolt would pull the wheel farther down. Similar to how 294/968 tensioned their outer two wheels in 2006, but rotated 90 degrees. However, we quickly realized during the season that it wasn't very useful.
Unread 28-07-2008, 00:06
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
We used a pnueumatic center wheel. When we wanted to raise it, we put more pressure in; lower it, drop the pressure.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 28-07-2008, 00:08
Herodotus's Avatar
Herodotus Herodotus is offline
Mountain Dew Bandolier Man
AKA: David Resowski
FRC #0910 (Foley Freeze)
Herodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond repute
I really like the idea, but I will echo what the others have said, as you probably won't have to adjust it much during the season. However I could see the idea being applied to different areas where adjustment is needed.
I am always doing that which I cannot do, in order that I may learn how to do it. - Pablo Picasso
--My Life in FIRST--
2009 Detroit Xerox Creativity Award
2009 Detroit District Finalists - Thanks to 1856 and 2620
2009 Kettering District Quarter-Finalists - Thanks to 1504 and 1025.
2008 Kettering Kickoff Champions - Thanks to 67, 1075 & 2619
2008 MARC Finalists - thanks 67 & 226
2008 Great Lakes Finalists - thanks 66 & 217
2008 Western Michigan Semi-Finalists - thanks 2337 and 1504
2008 GLR Judges Award Winner
2007 Curie Division Champions - thanks 330 and 1270
2007 ARC Champions (13 and 0, plus scoring a double-keeper!) - thanks 1625 and 313
2007 MARC Champions - thanks 1732 and 1023
2007 Xerox Creativity Award - Western Michign
2006 I.R.I. Champions - thanks 71 and 1625
Unread 28-07-2008, 00:10
That's 330's strategy, except that the wheel is already dropped.
Unread 28-07-2008, 00:23
R.C.'s Avatar
The reason for this is that we dropped our wheel last year at 1/8", but this year it needed more but we were stuck with an 1/8 because of the way we did it. So in postseason i tried this and we lowered it to 3/16" and the frame turned like a champ.
R.C.
Unread 28-07-2008, 00:34
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Well one situation when a pneumatic actuated center wheel is nice is if the game requires alot of pushing power then you can make it so all 6 of your wheels are on the ground at once. That obviously would make it very hard to turn especially if your wheels are wider than an inch. Then when you wanted to turn you could increase pressure and push the center wheel down farther and spin around very nicely.
However if your not going for that as others said you probably wont move them much once you find a nice offset that works for your robot.
Unread 28-07-2008, 00:59
Uh... not pneumatic actuated, pneumatic. There is a difference. Pneumatic actuated is a cylinder attached to the wheel; pneumatic is like a car or bike tire; i.e. air-filled. You can't change the pressure mid-match, though a nail on the field might change it for you.
Unread 28-07-2008, 04:19
RyanN's Avatar
RyanN
Yea, I forgot to mention that. Our's is already dropped as well. Of course this year we went with AM Performance wheels, so no more pneumatic. Saved us a lot of weight. We were like 105lbs this year.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 28-07-2008, 07:39
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Cool. One thing to be careful of when testing a chassis during the build season is to have proper weight and surface (i.e. carpet). We have built many chassis that seemed crazy manueverable on concrete, and then added mechanisms and put it on carpet and voila, it turned like a 10 ton dump truck.
You can also change the "drop" by lifting the front or rear wheels. These are often easier as this will only effect tension on the chain loop to them as changing middle wheel drop often includes messing with multiple chain loop tensions.
Unread 28-07-2008, 18:07
R.C.'s Avatar
We found this out the hard way, we could turn on the concrete with the arm, so we didn't drop the center wheel enough. Competition time comes and boom, we can't turn unless in low gear.
R.C.
Unread 29-07-2008, 18:37
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
{kinda off topic} because we usually only had to turn right 1557 used a two wheel drive in the front with two skyway wheels side by side to each other in the back left and a caster in the back right that was raised about an 1/8th inch so when we turned the robot would lean to the right and make turning a breeze.
Unread 31-07-2008, 10:34
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
I remember hearing that Truck Town had a pneumatic actuated center drop in '06. From what I heard they would have all 6 wheels on the ground when pushing, and could 'pop' their center wheels down with pneumatics when needed for turning.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 04-08-2008, 22:25
R.C.'s Avatar
How much stroke on that piston???
R.C.
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
Adjustable Shooter Nitroxextreme Technical Discussion 2 20-01-2006 19:33
pic: 885 Right-center wheel and drive assembly CD47-Bot Robot Showcase 2 30-04-2004 18:27
center-wheel drive Mercutio Technical Discussion 27 02-02-2004 21:19
