Go to Post It's too late to turn back - the only way is forward. Together - with a plan. - JaneYoung [more]
Unread 29-07-2008, 11:42
Dick Linn's Avatar
no team (Synergy)
Re: segway project: where to get torsion springs (around 20-40ft/lbs)
Here's a torsion spring calculator: http://www.engineersedge.com/calcula...spring_pop.htm There are a couple links to spring suppliers as well.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 29-07-2008, 11:55
kajeevan kajeevan is offline
FRC #0188 (blizzard)
kajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud of
i have a question about your segway are you using first parts to power the wheels like tough boxes and cims.
Unread 30-07-2008, 17:48
dfukuba's Avatar
dfukuba dfukuba is offline
Technical Advisor
AKA: Daniel Fukuba
FRC #0008 (Paly Robotics)
dfukuba is just really nicedfukuba is just really nicedfukuba is just really nicedfukuba is just really nice
Send a message via AIM to dfukuba
The spring will only be "unwound" from one end at a time. there will be a stop at the other end, while one of the cams rotate the end of the spring.
the scooter uses npc t-64s with a123 batteries 4p10s.
i have found "machined springs" made by heli-cal. They look pretty sweet, they actually have a hub on both ends of the spring. that would be a wonderfull way to make the mehcanism, but i would need to find someway to get one with out ordering in bulk.
Unread 31-07-2008, 07:33
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Call them and ask them if you can get a sample of two parts, and offer to pay shipping. Bet they say yes.
Springs?? (10 lbs. at 22 ft/s) KarateDog171 Technical Discussion 35 24-01-2008 18:37
where to get... Rickertsen2 Technical Discussion 1 18-02-2004 08:00
looking for a torsion spring tml240 Technical Discussion 1 03-02-2004 12:51
Torsion Spring Specs ateene Technical Discussion 0 22-01-2003 15:42
Can we really get 225 in-lbs from the drills? archiver 2001 2 23-06-2002 22:48
