Go to Post If time only weren't a factor, everything would be done. - Schnabel [more]
Unread 29-07-2008, 11:07
soccerguy2010's Avatar
soccerguy2010 soccerguy2010 is offline
FRC #1816
soccerguy2010 is an unknown quantity at this point
Plastic gears?
Our team is looking for plastic gears available online. The exact dimensions are: 12 pitch with 14.5° pressure angle. Our main problem is finding a source with the selection we need. Is there a good source that would carry this size gear?
Unread 29-07-2008, 11:28
Joining the 900 Meme Team
FRC #0079
Re: Plastic gears?
If you decide to use plastic gears make sure you don't put any sudden loads on them. We tried to use it in 07 and ended up spraying plastic teeth all over our shop when the arm came down fast.
Unread 29-07-2008, 12:37
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
Re: Plastic gears?
Check out WM Berg. They have a ton of choices, but not sure if they have what you are looking for.
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 29-07-2008, 14:16
REVving up for a new season
FRC #2848 (All-sparks)
Re: Plastic gears?
www.sdp-si.com all you need for the hard to find transmission components.
and their website has reciently gotten better.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 29-07-2008, 14:55
tennispro9911 tennispro9911 is offline
Alumni
AKA: Matt
FRC #2053 (TigerTronics)
tennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to behold
Send a message via AIM to tennispro9911
Re: Plastic gears?
Beware of plastic gears, although they are lighter. Make sure they can handle the applied loads.
2053 Alumni
Unread 30-07-2008, 01:34
JM987's Avatar
JM987 JM987 is offline
High Rollers
AKA: Josh Mauro
FRC #0987 (High Rollers)
Team Role: Driver
JM987 has a spectacular aura aboutJM987 has a spectacular aura aboutJM987 has a spectacular aura about
Send a message via Yahoo to JM987
Re: Plastic gears?
try rushgears.com
Check Out Our Website!
HERE!
- 2009 Las Vegas Regional Winners (thanks to 1622 and 1013)
- 2009 Las Vegas Regional Chairman's Award Winner
- 2008 IRI Winners (thanks to 330, 67, and 68)
- 2008 Archimedes Division Finalists
- 2008 Las Vegas Regional Chairman's Award Winner
- 2008 Las Vegas Regional Winners (thanks to 39 and 1013)
- 2008 San Diego Regional Finalists
- 2007 FRC World Champions (Atlanta thanks to 190 and 177)
- 2007 Newton Division Winner
- 2006 Las Vegas Regional Winner
- 2005 Las Vegas Regional Winner
Unread 30-07-2008, 02:23
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Plastic gears?
I took a glance at SDP when I first saw this thread, and from what I saw, they don't carry plastic gears under 16 DP.
2001-2004: Team 100
2006-Present: Team 254
Unread 30-07-2008, 11:29
Re: Plastic gears?
I stand corrected. They have loads of plastic gears but 16DP is the minimum.
Unread 30-07-2008, 23:30
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: Plastic gears?
Mcmaster has a lot. They are expensive as heck. Consider yourself warned.
You might try Boston gear.
-Vivek
"we don't build robots, we build people"
Source for large pitch plastic gears Kirk Technical Discussion 1 13-01-2008 00:00
plastic boxes Suzy General Forum 6 12-01-2003 03:27
Plastic Spur Gears Joe Canavan Technical Discussion 2 25-11-2001 01:45
Plastic Chain Mike Martus OCCRA 0 10-10-2001 21:58
