Go to Post If you're destroying game pieces left and right, you're doin' it wrong. - Ian Curtis [more]
Unread 30-07-2008, 17:48
dfukuba's Avatar
dfukuba dfukuba is offline
Technical Advisor
AKA: Daniel Fukuba
FRC #0008 (Paly Robotics)
dfukuba is just really nicedfukuba is just really nicedfukuba is just really nicedfukuba is just really nice
Send a message via AIM to dfukuba
Re: segway project: where to get torsion springs (around 20-40ft/lbs)
The spring will only be "unwound" from one end at a time. there will be a stop at the other end, while one of the cams rotate the end of the spring.
the scooter uses npc t-64s with a123 batteries 4p10s.
i have found "machined springs" made by heli-cal. They look pretty sweet, they actually have a hub on both ends of the spring. that would be a wonderfull way to make the mehcanism, but i would need to find someway to get one with out ordering in bulk.
Unread 31-07-2008, 07:33
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Call them and ask them if you can get a sample of two parts, and offer to pay shipping. Bet they say yes.
Springs?? (10 lbs. at 22 ft/s) KarateDog171 Technical Discussion 35 24-01-2008 18:37
where to get... Rickertsen2 Technical Discussion 1 18-02-2004 08:00
looking for a torsion spring tml240 Technical Discussion 1 03-02-2004 12:51
Torsion Spring Specs ateene Technical Discussion 0 22-01-2003 15:42
Can we really get 225 in-lbs from the drills? archiver 2001 2 23-06-2002 22:48
