Re: AutoCAD Copy/Paste Problems
Just kidding of course, but yep. That's the case. Your text is mirrored. Not sure how it got pasted in that way unless when you pasted it in you changed some of the options - or they were already set "wrong". Best way to paste something in (such as a block) is just to Ctrl-V it in approximately where you want it (paste) & hit enter about 3 times. (The 3 things you are "entering through" control your rotation & scale. Your command line may look similar to this after doing that: Code:
Command: '_pasteclip Insertion point: X scale factor <1> / Corner / XYZ: Y scale factor (default=X): Rotation angle <0>: If everything looks like the above, you should be golden. Quote:
(The same works if you copy something from another drawing into your drawing - yo uwill notice it will come in as one entity) To convert that block back into single lines to be able to edit again, click on the box, & then hit your explode command or (Modify > Explode). Your block will now be restored to 4 individual lines. Any more AutoCAD (2D) questions you have, or if what I've said so far hasn't been clear enough feel free to PM me. I've been using AutoCAD 2D for about 10 years now, so it's like second nature this kind of stuff. lol w00t! Last edited by Elgin Clock : 31-07-2008 at 10:47. |
| EasyC Copy & Paste | aeasson | Programming | 6 | 24-01-2008 16:48 |
| Copy and Paste Rules | Yan Wang | Rules/Strategy | 2 | 13-01-2006 16:04 |
| Mechanical Desktop 2004 DX/AutoCAD 2004 and AutoCAD 2005 | coastertux | Inventor | 4 | 14-06-2005 09:27 |
| pic: #1213 Undo Copy Paste | CD47-Bot | Robot Showcase | 1 | 14-02-2004 18:37 |
