Go to Post Just that the robot battery wont catch fire if you drop it the wrong way. Those LiPos pack quite a punch. - dellagd [more]
Unread 31-07-2008, 01:36
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
RC Refresh Rate
Does anyone happen to know how often the RC will scan the code?
I'm trying to estimate how long something will go by saying increment the counter every loop but i don't know how often it refreshes so therefore i don't know how many increments i want it to count to....
Thanks in advnace
Unread 31-07-2008, 08:17
GRS GRS is offline
FRC #1764
GRS is an unknown quantity at this point
Re: RC Refresh Rate
The 2007 & 08 RC's execute the user code around 28-32 times per second, depending on the amount of time the code takes to execute.
Unread 31-07-2008, 09:55
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
Re: RC Refresh Rate
    if (statusflag.NEW_SPI_DATA)      /* 26.2ms loop area */
    {                                 /* I'm slow!  I only execute every 26.2ms because */
                                      /* that's how fast the Master uP gives me data. */
      Process_Data_From_Master_uP();  /* You edit this in user_routines.c */
      if (autonomous_mode)            /* DO NOT CHANGE! */
        User_Autonomous_Code();        /* You edit this in user_routines_fast.c */
Stuff in Process_Data_From_Master_uP() will be run every 26.2ms. Same with User_Autonomous_Code() (when the robot is in autonomous).
It doesn't vary much to matter, if you have code that makes it take longer than 26.2ms to run it, it will explode.
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 31-07-2008, 16:31
popo308's Avatar
AKA: Brent
Re: RC Refresh Rate
Originally Posted by whitetiger0990 View Post
Thanks! Thats exactly what i was looking for... I thought i had seen that in the code before but when i went to look for it i couldn't find it
Unread 31-07-2008, 16:37
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Re: RC Refresh Rate
Can we figure out the loop time for the 2009 controller or do we have to wait for the default code?
TEAM 2230 ZECHARIA'S ANGELS
2009 Microsoft Israel FRC Regional Winners!
2009 Microsoft Israel FRC Regional Chairman's Award Winners!!!
2008 Microsoft Israel FRC Regional semi-finalist.
2008 Microsoft Israel FRC Regional Delphi's "Driving Tommorow's Technology" Award winner.
2008 Robot Driver
2007 GM/Technion Israel FRC Regional semi-Finalist.
2007 GM/Technion Israel FRC Regional Xerox Creativity Award winner.
2007 Robot Driver.
Unread 31-07-2008, 16:47
Re: RC Refresh Rate
Based on the information I've been able to scrape together about the new control system, I'm not sure "loop time" is going to be a valid concept. It looks like it'll be more like the way EasyC works: if you want to keep track of time, or do something every so often, you'll have to use real timers.
Unread 01-08-2008, 18:32
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: RC Refresh Rate
Just to head off any programming headaches, the User_Autonomous_Code() function is, in fact, only run once per autonomous mode. It doesn't even loop. It instead has a while loop in it that the execution stays in until autonomous mode ends. There's a section in this other while loop that has the same update rate, but it's technically incorrect to say that User_Autonomous_Code itself is run every 26.2ms.
Also, the new controller could still be running tasks in fixed time loops. At least, it's easily possible to do so on a Labview RT controller, though there are certainly other control methods they could be using. But for measuring elapsed time, it'd certainly be easier to start a timer and watch the elapsed time value instead of trying to count loops.
Gyro Rate Gary Bonner Programming 12 22-03-2008 16:49
Compression Rate pyr0b0y 3D Animation and Competition 2 15-02-2008 21:43
Help!! Refresh my memory!! Mike Rush General Forum 1 14-01-2003 22:43
refresh my memory archiver 2000 2 23-06-2002 22:40
Does this forum refresh? Erin General Forum 1 01-06-2001 12:19
