Go to Post Only think of Gracious Professionalism as a standard to work toward personally. Never use it as a gauge to point out someone else’s shortcomings. - Rich Kressly [more]
Unread 02-08-2008, 00:04
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: Securing gears on shafts
eclips would probably be a good solution. I haven't used them before. I still don't think I have enough clearance for the locking collars.
What do you think about gorilla glue? It is a gearbox so there should be no side load on the gears. Wouldn't a few dabs of gorilla glue work?
thanks, Vivek
"we don't build robots, we build people"
Unread 02-08-2008, 00:11
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
For most purposes, a decent Epoxy will hold better than gorilla glue. In either case, if you choose to do so, make sure all parts are completely grease-free before application.
you could also use a small roll pin, if you have the machining capabilities to do so (which you probably do, if you are custom making a gearbox) as the Tough box did this year.
How much clearance do you have?
If there is not enough clearance between the gears for shaft collars, but more than 1/16 of an inch, small spacers (cut from tube stock, or from the IGUS bag) have worked well for us in the past, with either shaft collars where there is more clearance, or the gearbox walls to hold all the parts together.
Unread 02-08-2008, 00:52
vivek16's Avatar
AKA: vivek
By clearance I mean a gear from another shaft in the gearbox comes too close to the hex shaft which would need a collar/spacer. Sorry if that doesn't make sense. It makes sense to me but I have the gearbox memorized.
After talking to Chris lyddiatt from 1114, I've decided to go with roll pins. Although, more ideas would be appreciated if teams have found any creative ways to secure gears.
thanks, Vivek
Unread 02-08-2008, 00:54
Joe G.'s Avatar
AKA: Josepher
Oh, I thought you meant that two gears on the same shaft needed to be very close together.
Roll pins should work fine.
Unread 02-08-2008, 03:50
thatmorman's Avatar
thatmorman thatmorman is offline
David
AKA: David
FRC #1510 (Wildcats)
thatmorman will become famous soon enough
Send a message via AIM to thatmorman Send a message via MSN to thatmorman
set collars work very nice, but they are heavy. one solution that is a little more cheap is zip ties. it doesn't necessarily look nice, and its not the most affective, but it works in most situations...
David Cobbley
Captain & Mechanical Leader
Team 1510
I <3 inventor & anyone in FIRST
Unread 02-08-2008, 12:14
Dick Linn's Avatar
no team (Synergy)
Snap rings would be good. You could also just use tubular spacer sleeves or thrust washers, depending on your setup. (One year the kit of parts contained a right-angle gearbox and required sleeves to locate the pinion over the larger helical gear.)
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 02-08-2008, 19:41
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
I don't know if it has been mentioned already (possibly by a different name) but I have often seen circlips function well to keep things on shafts in place. Nylon spacers also work alright (assuming they don't grind on anything). If you have the space, a custom shaft can often be designed to have a high spot that secures the side of one or two gears too. I like circlips though because they are easily removable and take up little space on a shaft.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 02-08-2008, 21:12
vivek16's Avatar
AKA: vivek
How do you machine the groove needed for a circlip(snap ring, e-clip, etc)? Do you need a special lathe bit or will a triangular insert dealie suffice?
thanks, Vivek
Unread 02-08-2008, 21:38
Aren_Hill's Avatar
Build Nifty Things
Special bit is a requirement sad to say
A guy who likes robots.
Unread 02-08-2008, 22:26
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
You don't need to resort to expensive insert systems for a basic operation like this. Grinding a cutting tool to cut a retaining ring groove is a fundamental lathe skill that you will want to practice. Based on the size of the retaining ring you are using, determine the groove width and depth. These standard dimensions can be found in Machinery's Handbook (if you don't have a copy, get one; it is possibly the most useful reference manual you will get in a long time). For certain size shafts, you can also look up the dimensions here.
Once you know the groove width, use a bench grinder to grind a piece of HSS tooling to the width of the groove. You basically want to grind the HSS to the shape of a parting (cut-off) tool, but shorter (there is a nice tutorial showing how to grind a parting tool here). The length of the cutting portion of the tool does not need to be significantly longer than the maximum depth of the groove. Grind in a 7-10 degree rake to the top of the tool, and appropriate relief angles to the sides and face (so only the tip of the tool actually cuts and contacts the sides of the groove). Mount the tool bit in a holder, and you are good to go.
Unlike carbide inserts, HSS tool blanks go for about a dollar each if you are a careful shopper.
-dave
Unread 02-08-2008, 23:02
run the trap!!!
Team Role: Human Player
I'd like to try these some time. They can securely lock a gear/sprocket/whatever to a shaft. preventing both slippage and side to side movement.
The best part? No machining or accuracy required the trantorques will expand to fill over-sized holes.
-Philip J. Fry
Unread 03-08-2008, 07:52
AdamHeard's Avatar
Lead Mentor
He has already told us that a clearance issue exists (like in the AM toughboxes). The larger gear of gear cluster A (arbitrary name) is too close to the shaft of the large gear of gear cluster B for any spacer or collar to be added (The small gear of cluster B is on the same shaft as A). Please correct me if I am wrong, but this is what I am imagining.
A roll pin like in the AM gearbox is the least labor intensive solution I can imagine that doesn't have the possibility to move. I have used the press on retaining clips like Travis suggested, but they have the possibility of drifting (You could still use them, just be prepared to verify the alignment often). Snap rings would also work very well, have a lower profile than roll pins, and look better. They do require machining that is a tad more difficult, but still is a pretty simple machining operation.
Unread 06-08-2008, 22:39
DonRotolo's Avatar
Back to humble
FRC #0832
This is a point worth repeating. Just because you can buy pre-made lathe tools doesn't mean you cannot make your own. In fact, there are times when making your own provides a far superior result. Making your own lathe tools is not at all difficult, as long as you follow some basic rules, and having that skill will serve you very well throughout your life.
Pre-made tools are best used when you need something that will last a long time, such as for a production run or an operation you'll repeat many times (like cutting screw threads). For short sample runs - and in FIRST, is there anything else? - unless you happen to have the right tool, grind your own.
FIRST is here to help you learn these skills. Go at it!
Over the years I have forgotten the details of most tools, but I DO know where to look them up, and that's just as good. I have a good tool grinding attachment for my grinding wheel, allowing for decent precision, and with just a little understanding of the principles, you can eyeball something if necessary. Pre-made tools in my shop are limited to 3 carbide jobbies and a parting tool.
Remember, you can use an e-clip even in a square shaft* - it's the groove that needs to be round, not the outside of the shaft. (*not recommended, but possible anyway)
Don
Unread 07-08-2008, 00:33
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Our team is a big fan of E-clips (OK, me personally). Work great for as thick as the are. However, if you just need to space out two gears in a gearbox, Delrin spacers would be better--no need to cut into the shaft.
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 07-08-2008, 09:22
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
You don't need to resort to expensive..
-dave
You just dispelled my NASA stereotype that your post would have started with:
Install the piece of billet into the 7 axis CNC....
Like Dave and others have said, learning to make your own tools is a great experience.
Securing interrupt-driven timers Orborde Programming 3 10-02-2005 15:52
Unsafely securing Anderson connector? Andy A. Electrical 20 16-04-2003 22:11
Securing Drill Motor Coupler Ralph Lambert Motors 17 08-02-2003 01:54
shafts, gears and wheels.... archiver 2001 13 24-06-2002 04:09
What is your favorite method for attaching gears to shafts? archiver 2001 13 24-06-2002 04:00
