Go to Post I'm missing JVN's build log this year ! - lynca [more]
Unread 01-08-2008, 22:39
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Securing gears on shafts
Hello,
I was wondering if there were any ways to secure gears on shafts. I don't mean along the axis of rotation (that is easily solved by hex/keyway broaching gears or carefully welding). How would I keep a gear from sliding along a hex shaft if it was already broached to the correct size?
I have thought of tack welding, roll pins, spacers, and set screws in the place of roll pins.
I ruled out tack welding because it would be nice to be able to reuse the gears in a case of emergency, and I don't have the clearance in some parts for spacers.
I am probably going to resort to using set screws but I was wondering how some other teams secured their gears on shafts.
thank you, Vivek
"we don't build robots, we build people"
Unread 01-08-2008, 22:58
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Securing gears on shafts
Get gears with hubs. Drill a hole in the hub, tap it, and setscrew the gear to the shaft. It's probably a good idea to locktite the setscrew, just to be sure
Unread 01-08-2008, 23:12
vivek16's Avatar
AKA: vivek
unfortunately, I already got gears without hubs. I was wondering if there was anything like an e-clip for hex shaft?
thanks, Vivek
Unread 01-08-2008, 23:17
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
You could still machine a snap ring or e-clip/retaining ring groove on a hex shaft.
You could also try one of those push-on style self locking rings.
Lastly, they sell clamping collars with hex bores which may work.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 01-08-2008, 23:21
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
seconded on the collars. A round bore collar would also probably work okay.
Unread 01-08-2008, 23:42
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
We use McMaster.com, go to their site and type in "aluminum collar". Click on About aluminum collar and there you go, the best method, we used 20 aluminum collars this year on our robot for multiple purposes.
R.C.
MadTown Robotics Team 1323
Unread 02-08-2008, 00:04
vivek16's Avatar
AKA: vivek
eclips would probably be a good solution. I haven't used them before. I still don't think I have enough clearance for the locking collars.
What do you think about gorilla glue? It is a gearbox so there should be no side load on the gears. Wouldn't a few dabs of gorilla glue work?
thanks, Vivek
Unread 02-08-2008, 00:11
Joe G.'s Avatar
AKA: Josepher
For most purposes, a decent Epoxy will hold better than gorilla glue. In either case, if you choose to do so, make sure all parts are completely grease-free before application.
you could also use a small roll pin, if you have the machining capabilities to do so (which you probably do, if you are custom making a gearbox) as the Tough box did this year.
How much clearance do you have?
If there is not enough clearance between the gears for shaft collars, but more than 1/16 of an inch, small spacers (cut from tube stock, or from the IGUS bag) have worked well for us in the past, with either shaft collars where there is more clearance, or the gearbox walls to hold all the parts together.
Unread 02-08-2008, 00:52
vivek16's Avatar
AKA: vivek
By clearance I mean a gear from another shaft in the gearbox comes too close to the hex shaft which would need a collar/spacer. Sorry if that doesn't make sense. It makes sense to me but I have the gearbox memorized.
After talking to Chris lyddiatt from 1114, I've decided to go with roll pins. Although, more ideas would be appreciated if teams have found any creative ways to secure gears.
thanks, Vivek
Unread 02-08-2008, 00:54
Joe G.'s Avatar
AKA: Josepher
Oh, I thought you meant that two gears on the same shaft needed to be very close together.
Roll pins should work fine.
Unread 02-08-2008, 03:50
thatmorman's Avatar
thatmorman thatmorman is offline
David
AKA: David
FRC #1510 (Wildcats)
thatmorman will become famous soon enough
Send a message via AIM to thatmorman Send a message via MSN to thatmorman
set collars work very nice, but they are heavy. one solution that is a little more cheap is zip ties. it doesn't necessarily look nice, and its not the most affective, but it works in most situations...
David Cobbley
Captain & Mechanical Leader
Team 1510
I <3 inventor & anyone in FIRST
Unread 02-08-2008, 12:14
Dick Linn's Avatar
no team (Synergy)
Snap rings would be good. You could also just use tubular spacer sleeves or thrust washers, depending on your setup. (One year the kit of parts contained a right-angle gearbox and required sleeves to locate the pinion over the larger helical gear.)
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 02-08-2008, 19:41
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
I don't know if it has been mentioned already (possibly by a different name) but I have often seen circlips function well to keep things on shafts in place. Nylon spacers also work alright (assuming they don't grind on anything). If you have the space, a custom shaft can often be designed to have a high spot that secures the side of one or two gears too. I like circlips though because they are easily removable and take up little space on a shaft.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 02-08-2008, 21:12
vivek16's Avatar
AKA: vivek
How do you machine the groove needed for a circlip(snap ring, e-clip, etc)? Do you need a special lathe bit or will a triangular insert dealie suffice?
thanks, Vivek
Unread 02-08-2008, 21:38
Aren_Hill's Avatar
Build Nifty Things
Special bit is a requirement sad to say
A guy who likes robots.
Securing interrupt-driven timers Orborde Programming 3 10-02-2005 15:52
Unsafely securing Anderson connector? Andy A. Electrical 20 16-04-2003 22:11
Securing Drill Motor Coupler Ralph Lambert Motors 17 08-02-2003 01:54
shafts, gears and wheels.... archiver 2001 13 24-06-2002 04:09
What is your favorite method for attaching gears to shafts? archiver 2001 13 24-06-2002 04:00
