Go to Post I am always torn between running a family and running a team... I guess the difficulty is in supporting the team as a whole before the individual...or alongside the individual. - MysterE [more]
Unread 04-08-2008, 03:04
c9ollie c9ollie is offline
FRC #0302
c9ollie has a spectacular aura aboutc9ollie has a spectacular aura about
sneak peak
super rough draft
looky looky
Unread 04-08-2008, 08:01
Re: sneak peak
Very nice! Don't forget to add some cross bracing to the vertical members. And always remember that rubber tread moving next to the motor will induce some static electricity.
Unread 04-08-2008, 09:01
AdamHeard's Avatar
Lead Mentor
Re: sneak peak
How thick are those sideplates? I am almost they are currently not thick enough to be strong enough
Unread 04-08-2008, 09:14
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: sneak peak
Ditto. They look 1/32 to 1/16ish. Make em thicker. I'm not sure how thick but 1/4" is probably a safe bet.
-Vivek
"we don't build robots, we build people"
Unread 04-08-2008, 14:40
FRC #0302
Re: sneak peak
-Vivek
they are a 1/10 anything more is shear over kill and more weight. we ran 1/10th side panels last year with zero issues. the illustration rendering style has a black outline on every edge so it makes them look super thin. this is just a revamp of our current transmissions so we know they are already tough as nails. also the wheel does not rub on the motor its just packaged in a way that it looks like it does. i will get a few more renderings to show it. the top ring is just our packaging goal. also pictured in these renderings is the lower support bearing. i didnt have time to model it in the first renderings.
btw this is for our crab drivetrain.
Unread 04-08-2008, 15:29
Dowjonesbotics's Avatar
Dowjonesbotics Dowjonesbotics is offline
Leggooo
AKA: Jeremy Downes
FRC #1230 (Lehman Lionics)
Dowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the rough
Re: sneak peak
Is this what they call a swerve drive???? But hten what's a crab drive???
I'm a little confused as to the difference
Unread 04-08-2008, 15:31
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Re: sneak peak
your not already planning on using a crab drive for the 09 year, are you?
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 04-08-2008, 16:40
Re: sneak peak
It isn't exactly in the modules. You could have both of those with the same modules and different turning gearing.
It's the way it's set up. Correct me if I'm wrong, but a swerve drive has two or more sets of modules and a crab drive only has one. (Or it's the other way around.)
I'm going to say that 1/10 is too thin for stress points. What a lot of teams do is take 1/4 and put the holes in, then mill the rest of the plate out, leaving a border and a small area around each hole at original thickness to add strength. You really don't want to make a mistake and go too thin; having the thin stuff fail mid-match will take your robot out of the match. No spare means you may be out of the competition.
If nothing else, do the stress analysis and post it so that we know that you know what you are doing. If that analysis (which should probably take into account getting hit by 3 robots simultaneously from the same side) shows that it won't break, even under running conditions, then I'll retract my statement that 1/10 is too thin. If it doesn't, then we'll help you redesign so that it won't fail.
Unread 04-08-2008, 18:54
run the trap!!!
Team Role: Human Player
Re: sneak peak
I'm not as concerned about the thin-ness as I am about the lack of connections between the two sides. You really ought to add some standoffs down near the wheel, or better yet, machine the whole module out of .125" thick boxed aluminum.
You could always use steel. That would certainly strengthen the connection points.
-Philip J. Fry
Unread 04-08-2008, 23:40
Daniel courtney Daniel courtney is offline
Daniel courtney is on a distinguished road
Re: sneak peak
lol that looks like a disc brake in the wheel...or is it?
Unread 05-08-2008, 01:39
vivek16's Avatar
AKA: vivek
Re: sneak peak
I think its a gear.
-Vivek
Unread 05-08-2008, 01:59
AdamHeard's Avatar
Lead Mentor
Re: sneak peak
Yes, with the .1 thickness, some real serious cross support will need to be added for it to be strong enough. More than just some cross supports probably.
Imagine the stresses the module can take when it rapidly changes directions while the robot is moving full speed (and even worse takes a hit from another robot at the same time).
Unread 05-08-2008, 07:29
Re: sneak peak
Swerve drive and crab are very similar and often the two terms are interchanged. Many years ago, some teams developed a type of drive that could steer all four wheels but had limited turning of the running gear. It allowed the robot to "swerve" around obstructions on the field. Crab drive allows the robot to move in any direction without needing to turn the robot. The steering gear has the ability in most cases to turn more than 180 degrees and sometimes continuously. The first robot I remember with crab was a Chief Delphi robot from around '97 or '98 and there was one steering motor and a chain that wrapped around all four steering modules.
Unread 05-08-2008, 12:57
FRC #0302
Re: sneak peak
i can assure you that 1/10 is as thick as it needs to be anymore more is just a waste of time and pocketing 1/4 plate is just waste of aluminum. we ran this exact setup last year with zero issues. the frame of our robot bent before these "PODs" did. also since this is a super rough draft and i havnt really got to making the spacers for it. there is more support in these PODs but im more concerned about the geartrain layout.
Unread 05-08-2008, 13:07
Re: sneak peak
Ollie,
Don't forget that a 140lb robot running at 12 ft./sec imparts a pretty big side load to your module and all the force will be transmitted to the frame through the ring and a small amount to the top bearing. You can't keep your friction numbers unless all the tread is on the floor.
Sneak Peak? Boydean General Forum 3 10-04-2008 00:16
Sneak Peak at CD5? archiver 2000 1 23-06-2002 22:56
Team 639 sneak peak patrickrd Robot Showcase 0 12-02-2002 18:58
TEAM 384 Sneak Peak ggoldman Robot Showcase 4 09-02-2002 07:32
SNEAK PEAK (team 56 robot) Brian Savitt Robot Showcase 9 09-02-2002 07:21
