Go to Post Leadership is demonstrated by initiative, examples, and spirit. Decisions are made by those who show up. The world is whatever you make of it. - Ken Leung [more]
Unread 05-08-2008, 13:47
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Re: sneak peak
Originally Posted by c9ollie View Post
i can assure you that 1/10 is as thick as it needs to be anymore more is just a waste of time and pocketing 1/4 plate is just waste of aluminum. we ran this exact setup last year with zero issues. the frame of our robot bent before these "PODs" did. also since this is a super rough draft and i havnt really got to making the spacers for it. there is more support in these PODs but im more concerned about the geartrain layout.
As you said earlier you used 1/10, was it for this type of swerve/crab setup or for a 6-wheel? As a mechanical engineer I would take the advice of fellow mech-heads and increase the width of your side plates, 1/8th is the smallest I would go with major cross bracing. Looking at your setup your main drive shaft is about 6" away from your main mounting point for those side plates, and that type of torque on 1/10" sheet won't last long. Take a look at some of the more successful crab drives of the last couple years (i.e. 71, 111, 1625), and make your modules beffey to start and slowly cut away the fat as you improve the design.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 05-08-2008, 14:34
c9ollie c9ollie is offline
FRC #0302
c9ollie has a spectacular aura aboutc9ollie has a spectacular aura about
Re: sneak peak
Ollie,
Don't forget that a 140lb robot running at 12 ft./sec imparts a pretty big side load to your module and all the force will be transmitted to the frame through the ring and a small amount to the top bearing. You can't keep your friction numbers unless all the tread is on the floor.
i understand that. we ran this same setup last year with zero issues. we even ran it without the lower support bearing for our 2 regionals. we did break 2 of the top posts but that was because of faulty welds. we redid them in billet and they held more than ok. the lower bearing is there for secondary lateral support and is not our main means of lateral stabilization. yes the forces are so great but they are so instantaneous that even if it does make something bind it will do it for such a short period of time it would be insignificant. the module is designed to be 100% support by the top post. the lower bearing is there for redundancy. i just put it where it was because i was just to lazy to redo the side panels, but it will probably be located closer to or below the axle of the wheel
Unread 05-08-2008, 14:37
FRC #0302
Re: sneak peak
progress
Unread 05-08-2008, 16:15
Dowjonesbotics's Avatar
Dowjonesbotics Dowjonesbotics is offline
Leggooo
AKA: Jeremy Downes
FRC #1230 (Lehman Lionics)
Dowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the rough
Re: sneak peak
Lol crab drive is really awe some
My account had been hacked and used by someone random for the past 2 years, my apologies for so many awful posts.
2011 New York City Regional Regional Finalist
2009 New York City Regional Team Spirit Award
2008 New York City Regional Team Spirit Award
2007 New York City Regional Team Spirit Award
2005 New York City Regional Champion
2003 New York City Regional Rookie All-Star
Unread 06-08-2008, 13:32
Re: sneak peak
I'm asking for a stress analysis. You probably won't convince 99% of us without one. Just run it in the worst-case scenario that you can think of and post the results picture, or something like that. If you can show us that it won't fail, more teams might wind up using .1" metal on their robots next year. We all win. If you don't show one, there's a good chance that the first time it breaks, someone will say, "I told you so" or "Why didn't you use..." or "What were you thinking?". We all lose. You've got the CAD files, so it should be pretty simple to run the analysis, and if you don't know how, it's a pretty good way to learn.
Sneak Peak? Boydean General Forum 3 10-04-2008 00:16
Sneak Peak at CD5? archiver 2000 1 23-06-2002 22:56
Team 639 sneak peak patrickrd Robot Showcase 0 12-02-2002 18:58
TEAM 384 Sneak Peak ggoldman Robot Showcase 4 09-02-2002 07:32
SNEAK PEAK (team 56 robot) Brian Savitt Robot Showcase 9 09-02-2002 07:21
