Go to Post I've done enough preaching to the choir. Let's carry on changing the culture. - StevenB [more]
  #31   Spotlight this post!
Unread 05-08-2008, 20:26
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: New Speed Controller Announced
Originally Posted by Cory View Post
It won't be so awesome for the teams who will have thousands of dollars in effectively useless Victors once FIRST transitions fully into the new control system.
eBay! Just because Victor 884s might not be allowed in FRC in future seasons would not mean they've lost all use. They are really good speed controllers, and there are always other people (especially Battlebots community) who would buy them.
I'm extremely concerned with the size of all the components of the new control system. All these pieces together are absolutely massive compared to what we've been using.
Gone are the days of giving the electrical and controls people a cubic foot of space and telling them to make it work...
Art Dutra IV
世上无难事,只怕有心人.
  #32   Spotlight this post!
Unread 05-08-2008, 21:22
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Obviously your mechanical people have been spoiling you. They have been giving you far too much volume
Christopher H Husmann, PE
"Who is John Galt?"
  #33   Spotlight this post!
Unread 05-08-2008, 21:42
dpraedan dpraedan is offline
AKA: Peggy
FRC #0190 (Gompei & the HERD)
dpraedan is an unknown quantity at this point
Send a message via AIM to dpraedan
I would be inclined to say that these controllers use the standard R/C PWM wiring scheme the Victors employ, seeing as a) the digital sidecar for the new system has standard PWM outputs and b) the PDF explicitly states it uses the standard R/C PWM servo interface.
  #34   Spotlight this post!
Unread 05-08-2008, 23:13
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Since when is big the new small? First the radios, then the maxi breaker panels & distribution blocks, then the new control system, and now the speed controllers...
  #35   Spotlight this post!
Unread 05-08-2008, 23:33
I have been estimating 6 lbs and about 1/2 cubic ft. for the control system alone. You can back into the size from the picture knowing that the pin spacing on the header is 0.1 inch or judging the two RJ 45 jacks. I am guessing that it is at least 1/2" wider and 1" longer than Victors.
16kHz is still audible to students and I can tell you from experience that 15,734 Hz is annoying to anyone under 50 and some over 50. I question the choice of switching frequency vs. the inductance of the motor windings though. Testing will confirm this.
  #36   Spotlight this post!
Unread 05-08-2008, 23:42
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Maybe more teams will use the old Victors, they are still available.
R.C.
MadTown Robotics Team 1323
  #37   Spotlight this post!
Unread 06-08-2008, 10:58
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
It's beginning to look a lot like Christmas...
The flyer (pdf) I read said 20kHz. Am I mistaken?
As to claims of linearity, that depends on what you mean. The output may actually be very linear, but the system need not respond in a linear way.
My experience in automotive systems is that when you go from low PWM freq (100-400Hz) to higher PWM freq (10-20kHz), the motors do not respond the same, especially at low duty cycles.
For example, if, in order to get a system moving, we needed say 20% duty cycle at 100Hz, we would need to bump the duty cycle up to 30-40% at 10kHz PWM freq.
This was very puzzling but we eventually attributed this our mechanical system's time constant. At 100Hz, the mechanical system's time constant was such that the system had time to react during a single PWM pulse -- These "full on" pulses provided a kick to get the motors and gears turning. At 10kHz, the system can only react to the average not the individual pulses, so it required more on time to get things rolling.
It does not say in the flyer but I hope that the H-bridge is configurable in ways that are feedback loop friendly. What I mean is that you can drive motors via an H bridge in several ways.
  1. ON = 12V, OFF = Open Circuit
  2. ON = 12V, OFF = MOTOR LEADS SHORTED
  3. ON = 12V, OFF = -12V
#2 is very nice for feedback control of large arms for example.
#3 sounds very strange at first, but it can provide some very nice control features as well (thought it can be tough on the electronics) in this case
  • "OFF" for the motor is accomplished by outputting 50% 12V & 50% -12V.
  • "50% Forward" is accomplished by outputting 75% 12V & 25% -12V.
  • "25% Reverse" is accomplished by outputting 38% 12V & 42% -12V.
As I said, it seems strange but it has some very nice behaviors. This type of control is called locked anti-phase motor control and I discuss this issue at length here
Once they implement CAN, I hope that they also consider some other control friendly strategies:
  • using current messurements to allow for velocity (and even position) control without the use of encoders or other sensors. I discuss this here: What Dr Joe Wants for Christmas... (Man, I love referencing myself ;-).
  • implementing PID control onboard the speed controller (send it your gains and from then on just give it a desired position -- let IT figure out what the PWM outputs should be)
  • Diagnostics, diagnostics, diagnostics. At a minimum teams will know if a speed controller has become unplugged -- I guess that feature alone would have changed the outcome of about 20% of the FIRST tournaments ever held. But open your mind a bit and you can imagine diagnostics that tell you if your motor is overheating, if your mechanism is binding up, if your wheel treads need to be replaced, etc. etc. The mind reels at the possibilities.
It is only August, but it is looking more and more like Christmas to me...
Joe J.
Team #88, TJ2
  #38   Spotlight this post!
Unread 06-08-2008, 12:04
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
I notice that this press release comes from Luminary Micro, and not from FIRST. They are bold enough to announce that they "will be included in the FIRST Robotics Competition's (FRC) official Kit of Parts (KoP) and distributed to over 1,700 teams in the upcoming 2009 international FRC." This "announcement" has not yet been acknowledged or confirmed by FIRST. But I have heard rumors that the content for the 2009 KOP, and the associated rules about what is legal to use on the robots, have not yet been finalized. Therefore, I would surmise that this announcement may be a bit premature.
I have heard tales of some members of the GDC that are devious enough to pull an item out of the KOP specifically because the community got unauthorized advance knowledge of a part, and started to do pre-design and pre-build work before the season officially started. After all, wouldn't it be interesting if the entire community got all spun up about a rumored new "capability" that was then never actually included in the KOP? That would be an excellent way to divert their attention away from what was actually going to happen.
Nah, something like that would never happen.
-dave
  #39   Spotlight this post!
Unread 06-08-2008, 12:17
AdamHeard's Avatar
Lead Mentor
I weary of the new system just because it is new, but a lot of these features are very interesting to me. I'm really interested to know more about the sensor feedback.
-dave
Brandon, can you ban his account? Please....?
  #40   Spotlight this post!
Unread 06-08-2008, 12:19
Klake's Avatar
Klake Klake is offline
Custom Robot Builder
AKA: Keenan Lake
FRC #0494 (Goodrich Martians)
Team Role: Electrical
Klake is an unknown quantity at this point
One thing that I noticed (and do not like) is that there is no ventilation for the drive MOSFETs or etc inside. Driving 20amp motors will get them warmed up and those look like they will be nice and toasty.
  #41   Spotlight this post!
Unread 06-08-2008, 12:24
Joe,
I was referencing a previous post with the 16 kHz. At this and higher frequencies, the combined inductance and series resistance will produce a low pass filter that will serve to limit rise times and produce triangle waves instead of the the expected square waves. Glad to see you back on the forum.
Perhaps Richard, if you are reading this, can give us a handle on motor winding inductnce. I would think it would be pretty high, on the order of 100 mH. I won't be able to do any measurements for several days.
  #42   Spotlight this post!
Unread 06-08-2008, 12:42
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
While the new control system (including these speed controls) is more capable than the old one, the increase in physical size is a lot. We would not be able to comfortably fit these components on any of our previous four robots.
  #43   Spotlight this post!
Unread 06-08-2008, 14:12
Where did you "notice" this? It's contradicted by the Jaguar's reference sheet, and the ventilation grille on the top is recognizable as such in the posted image.
  #44   Spotlight this post!
Unread 06-08-2008, 16:27
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
From the tech at the Luminary booth here at NI Week.....
-full current sensing and feedback for position control, when they unlock the feature in '010
-onboard PID, you tell it the constants and it goes to work
The unit has a cool limit switch feature also built in. you can wire a limit switch directly to the esc for both directions of operation as a built-in software stop.
The standard pwm connection still applies for now. the CAN interface is either disabled or now allowed for our use, though the demo unit they were running was linked up via ethernet cable. looked pretty slick.
Woody said we'd be able to use victors this season to carry us through the transition. The most exciting news, is that both the FIRST rep and the NI rep said the price point for the Jaguar was going to be significantly less than the victor....."we'll be happy" were his exact words!
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
  #45   Spotlight this post!
Unread 06-08-2008, 16:29
REVving up for a new season
FRC #2848 (All-sparks)
Any chance you can post some real photos of it with something for scale (a dollar bill)
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
New Vex Microcontroller announced Brandon Martus General Forum 19 07-05-2009 16:00
FRC Robot Controller/Speed Controller RoarRoar Control System 3 17-01-2008 10:41
speed controller max speed Team 668 Programming 15 13-02-2005 14:05
New Special Edition GameBoy Announced Joe Matt Chit-Chat 12 13-01-2003 21:35
