Go to Post I dont think it matters too much what you do, as long as you do something that lets you apply what you're learning in class. - MrForbes [more]
Unread 06-08-2008, 22:39
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Securing gears on shafts
Originally Posted by dlavery View Post
Grinding a cutting tool to cut a retaining ring groove is a fundamental lathe skill that you will want to practice.
This is a point worth repeating. Just because you can buy pre-made lathe tools doesn't mean you cannot make your own. In fact, there are times when making your own provides a far superior result. Making your own lathe tools is not at all difficult, as long as you follow some basic rules, and having that skill will serve you very well throughout your life.
Pre-made tools are best used when you need something that will last a long time, such as for a production run or an operation you'll repeat many times (like cutting screw threads). For short sample runs - and in FIRST, is there anything else? - unless you happen to have the right tool, grind your own.
FIRST is here to help you learn these skills. Go at it!
Over the years I have forgotten the details of most tools, but I DO know where to look them up, and that's just as good. I have a good tool grinding attachment for my grinding wheel, allowing for decent precision, and with just a little understanding of the principles, you can eyeball something if necessary. Pre-made tools in my shop are limited to 3 carbide jobbies and a parting tool.
Remember, you can use an e-clip even in a square shaft* - it's the groove that needs to be round, not the outside of the shaft. (*not recommended, but possible anyway)
Don
Securing interrupt-driven timers Orborde Programming 3 10-02-2005 15:52
Unsafely securing Anderson connector? Andy A. Electrical 20 16-04-2003 22:11
Securing Drill Motor Coupler Ralph Lambert Motors 17 08-02-2003 01:54
shafts, gears and wheels.... archiver 2001 13 24-06-2002 04:09
What is your favorite method for attaching gears to shafts? archiver 2001 13 24-06-2002 04:00
